Spin coating small PCB?
2012-04-12 by waynehcausey
Any experience with spin coating small PCBs?  Equipment, RPM, photoresist, etc.
Wayne
Re: [Homebrew_PCBs] Spin coating small PCB?
2012-04-12 by KeepIt SimpleStupid
>Wayne
Re: Spin coating small PCB?
2012-04-13 by designer_craig
Wayne,
I used to spin all sorts of boards.  Used Shipley AZ111 for the resist.  This was a solvent based, I would pre wet the board then spinn off the excess.  I have also tried the AQ3000 water borne resist and that works just as well, possibly a little better.
Small boards are not a problem nore are double sided boards.  As the boards get larger it becomes harder and harder to get them centered on the spin table.  Also the slinging forces between the center and outer edge vary greatly as the board gets bigger.  I think the largest board I did was 8" x 8" though I would bet I could have done 10 x 10.  Rectangular boards are the hardest to do.
My first spinner was built from some sort of fractional HP motor and and aluminum plate, mounted in a cardboard box -- you do have to trap the excess resist that gets thrown off or you will have a mess. My latest unit is a little nicer and built from an old computer fan and a wood framed box with a splatter shield.
https://picasaweb.google.com/115378886522213655693/DYIPCBs
Second photo is a short movie
Board is held on with double stickey tape.
Craig
--- In Homebrew_PCBs@yahoogroups.com, "waynehcausey" <wayne.causey@...> wrote:
> Wayne
2012-04-13 by David
Craig,
Seriously impressive method of applying photo resist, certainly food for thought!! Beats the laminator method hands down!! How do you dry the board after? [and keep dust off it!!]
David
--- In Homebrew_PCBs@yahoogroups.com, "designer_craig" <cs6061@...> wrote:
> Wayne,
> Craig
> --- In Homebrew_PCBs@yahoogroups.com, "waynehcausey" <wayne.causey@> wrote:
> > Wayne
2012-04-13 by sailingto
Now that is just too cool!!!
This is a method to coat standard old PCB boards to use in photo resist?  I understand photo resist does better than TT, but have not tried photo resist due to cost of factory boards, etc.
Craig - can you provide more info on this method?  Cost? Where to buy chemicals?  As asked, how to drive dust free?
The boards are then handled as regular factor coated boards?
Thanks for any and all info,
Ken H>
--- In Homebrew_PCBs@yahoogroups.com, "David" <dgh2259@...> wrote:
> Craig,
> David
> --- In Homebrew_PCBs@yahoogroups.com, "designer_craig" <cs6061@> wrote:
> > Wayne,
> > Craig
> > > Wayne
2012-04-14 by designer_craig
With the AZ111 the solvents flashed off quite fast but you did have to bake the board for 15 minutes at I think 120 or 15O F to harden the resist.  Dust wasn't a problem any more than it would be for dry film.  One did have to watch the stringers that formed like cotton candy from the drying excess resist as it departed the spinning board.
Craig
> Craig,
> David
> > Wayne,
> > Craig
> > > Wayne
Spin coating has been around for years.  In the early semiconductor days it's how they would coat the wafers for processing.
You can get micron accuracy with photo resist processing the best you are going to do with TT is about 600 -1200 dip if you are lucky.
I don't believe the Shipley AZ111 is availabe anymore but there are similar products.  I did buy some Genesis AQ3000 a couple of years back to give it a try.  It is water based and worked as well if not better in the spin coater than the AZ111.  I found it on ebay but had to buy a quart for about $65.  Other than ebay I have not found a low cost low volume distribution cannel.  It doesn't help that most PCB fab houses use dry film, so the market is not there any more.
Once coated and baked you just use the a film master and a UV light source to expose the board.  Development for the AZ111 and the AQ3000 were sodium carbonate based solutions.
Craig
> Ken H>
> --- In Homebrew_PCBs@...m, "David" <dgh2259@> wrote:
> > Craig,
> > David
> > > Wayne,
> > > Craig
> > > > Wayne
2012-04-15 by sailingto
Thanks for the info Craig - I'm sure photo resist is better than TT, but I'm comfortable with TT, it does what I need. I use large pads and traces so they don't lift while soldering..... for the 3 or 4th time<:) - it seems most of my boards wind up being prototypes as I tend to change as I build/solder on the board.  Remove, change, replace components, etc.
Ken H>
> Craig
> > Ken H>
> > --- In Homebrew_PCBs@yahoogroups.com, "David" <dgh2259@> wrote:
> > > Craig,
> > > David
> > > > Wayne,
> > > > Craig
> > > > > Wayne
2012-04-19 by designer_craig
FYI -- spinner construction details.
The spin coater recently built was constructed from a 4"x4" computer fan. I found one with a metal frame at the local surplus outlet, would guess a plastic frame fan would also be fine.
I cut the housing frame down from its normal 1" thickness to about a 1/2" then I cut all the blades off the hub.  Screwed what remained of the housing to the bottom of the splash guard box.  I cout out about a 6' dia piece of aluminum for the spinner table and bonded it to the the fan hub with some JB weld epoxy  (don't use the quick setting stuff as the bond is not very good). Make sure you get it centered so you don't have to do too much balancing later on.
An old wall wart for power and a push button the regulate the speed. Once you spin a couple you will know by the sound and look that you have the correct speed.
Craig
> Wayne
2012-04-19 by bebx2000
I made one following your original post. It works great, but I found that the viscosity of the material being spun is important.
Baxter
Re: [Homebrew_PCBs] Re: Spin coating small PCB?
2012-04-19 by Derward Myrick
Back in the early 1960s I worked at a small electronics co. that did contract work for NASA.
They used an old record player turntable as their spin coat  device.
Derward Myrick  KD5WWI
Subject: [Homebrew_PCBs] Re: Spin coating small PCB?
  Baxter
