> It does not have to be fine, unless you are at microwave and above frequencies. A course mesh is good enough, 1/4" is fine.
> Some pcb packages have a mesh fill option.
> Malcolm
> Â
> I don't suffer from insanity I enjoy it!
> Mene, mene, tekel, upharsin
> The writing is on the wall.
> From: sailingto <sailingtoo@...>
> To: Homebrew_PCBs@...m
> Sent: Thursday, March 15, 2012 5:21 PM
> Subject: [Homebrew_PCBs] Re: ground planes
> Â
> I had wondered about the photo etch method and if it had this problem.
> The mesh method is mentioned - do you mean use a very fine mesh pattern for the solid ground plane? I'm not sure how to do this in Eagle or ExpressPCB programs. Sounds like a good idea - mesh fine enough it "looks" solid on transfer?
> With the normal transfer, the ground plane "looks" like it has good toner transfer - very black. BUT, on etching it doesn't look so good with many tiny holes showing.
> Thanks for the suggestions and info - I might have to try photo - etching. That does seem to have better results.
> Ken H>
> --- In Homebrew_PCBs@yahoogroups.com, Malcolm Parker-Lisberg <mparkerlisberg@> wrote:
> > Use a mesh pattern, rather than solid. It happens because the electrostatic charge migrates from large areas.
> > Malcolm
> > ÃÂ
> > From: sailingto <sailingtoo@>
> > To: Homebrew_PCBs@yahoogroups.com
> > Sent: Thursday, March 15, 2012 3:15 PM
> > Subject: [Homebrew_PCBs] ground planes
> > ÃÂ
> > Does anyone have problems getting large ground plane areas to stay good 'n solid with copper? I've been having a bit of problem with large ground plane areas using toner transfer method. If I do a board without a large ground plane, the traces look good - trace size ranges from .015" to .050" or so.
> > I clean copper good, wash with alcohol. Toner transfer at 360úF with a laminator using Pulsar toner transfer paper, then etch in HCl and H2O2. I used the green film last board and it seems a bit better, but not sure about large areas yet.
> > Just checking to see if anyone else has this problem, or maybe found a solution...... or maybe it's just me?
> > Thanks for any guidance and suggestions.
> > Ken H>
> > [Non-text portions of this message have been removed]
