toner transfer limits
2012-03-12 by Bert Van Kets
Hi all,
After a hiatus of many years I'm getting back into electronics (robotics
in particular). I have made a couple of PCBs using the photo transfer
method.
I am now venturing into SMD components and want to use the toner
transfer method as I have discarded my UV lightbox.
So I'd like to know what methods you guys use to get very thin traces
reliably.
What are the limits of this method?
What are the things to look out for to get reliable thin traces?
Thanks.
Bert
Re: [Homebrew_PCBs] toner transfer limits
2012-03-13 by Harvey White
On Mon, 12 Mar 2012 09:48:12 +0100, you wrote:
>Hi all,
>method.
>reliably.
clean board, good paper, good laminator.
I find that 10 mil traces are reliable, but somewhat picky to get
right.  0.5 mm spacing on a VQFP-100 flatpack is about the limit for
me, and the board still needs a bit of hand rework at times.
clean the board well.  proper temperature and pressure in the
laminator.  For large (5x7) boards I run through 8 to 10 times with
the laminator I have.  You will need to experiment.  Green foil helps
a lot, but I have had instances where it simply does not adhere at
all, ever.  Then it may ruin the board.  Odd.  Best boards have green
foil done properly.  Photoresist is actually a better process when
done with a good negative.
You will need a laser printer with 1200 DPI, dense toner, and one that
the toner softens at the proper temperature (that of the laminator).
600 DPI does not work for fine traces.
Harvey
>Thanks.
>Bert
2012-03-13 by Bert Van Kets
Thanks for the info.
I'll start my tests with through hole and a regular iron.
Did anyone ever try to use a fuser unit from an old laser printer?
I have an old Laserjet II I can sacrifice for that. It should have the
perfect temperature to transfer the toner. If I could get the speed down
there should not be any need for multiple passes.
Bert
> >Hi all,
> >method.
> >reliably.
> Harvey
> >Thanks.
> >Bert
I have one that's sitting there asking to be a project.  It's on the
list, that's all I can say.
I have a thermocouple controller, and I'll be using the original
heating element, providing a constant speed drive to the gearing.
Further than that, no ideas yet, although I think I will be perhaps
using aluminum, or something that is an insulator and easy to replace.
Down the road a bit.
Harvey
>Bert
>> >Hi all,
>> >method.
>> >reliably.
>> Harvey
>> >Thanks.
>> >Bert
Re: toner transfer limits
2012-03-14 by tda7000
> Bert
I'm sure you could use a fuser but you would need to do some modifications
I was thinking about it but in the end I went with the laminator because everything was already in the one unit and to get it up to correct temperature I just needed to add 1 resistor to the control circuitry.
Mine does seem to need a few passes but that doesn't worry me a great deal, considering how easy it was to get up and running.
2012-03-14 by sheldon_mp_cooper
This tip only applies to small boards, but when I make things like SMD to DIP adapters, I make multiple copies on the 3"x4" boards I use for such things.  The duplicate array of the PC board's artwork is made easily using a graphics/paint/drawing program.  This is the same method used by IC manufacturers where multiple dies are made on the same wafer and then the bad ones discarded.
Re: [Homebrew_PCBs] Re: toner transfer limits
2012-03-15 by Eldon Brown
Here an example of panelizing using DipTrace - for one of my small Toner
Transfer projects.
http://wa0uwh.blogspot.com/2012/03/prop-tcvcxo-pcb.html
Eldon Brown
72 - Eldon - WA0UWH - CN88xc - http://WA0UWH.blogspot.com/
On Wed, Mar 14, 2012 at 08:13, sheldon_mp_cooper <bigbazinga@yahoo.com>wrote:
> bad ones discarded.
2012-03-23 by x100
Using 15 mill traces, I can get 100% (no breaks, no rework) results on the first try with magazine paper. The 8 mil traces were also completely intact, but I never tried a complete board with that size yet.  My only complaint is that I get paper fiber between some traces which must be manually removed with a needle.
I just tried HP presentation paper (from Staples).  I didn't etch yet, but the toner deposit looked much better.  The paper also lifted off by itself after about 2 minutes of soaking with not a single fiber bridge!
