Homebrew_PCBs
[Homebrew_PCBs] Silver Ink
2012-01-18 by Mark Lerman
Anyone interested in sharing the $35 USD cost of accessing the
article Andrew found regarding silver acetate ink?
Mark
Re: [Homebrew_PCBs] Silver Ink
2012-01-18 by Benjamin Blumer
Ick. It'd be a crying shame to spend that much money. Unfortunately, I'm
traveling and only have my iPad with me and the school's VPN can't be set
up on iOS devices. Many university library computers don't require a
login. Any one of those ought get you access.
Sent from my iPad
Mark
RE: [Homebrew_PCBs] Silver Ink
2012-01-18 by MIKE DURKIN
There must be a reprint out there somewhere ...
Date: Wed, 18 Jan 2012 09:53:07 -0500
Subject: [Homebrew_PCBs] Silver Ink
Mark
2012-01-18 by David Mitchell
Look under the "supporting documentation" page:
http://pubs.acs.org/doi/suppl/10.1021/ja209267c
there is a PDF with the experimental methods described.
http://pubs.acs.org/doi/suppl/10.1021/ja209267c/suppl_file/ja209267c_si_001.pdf
good luck!
regards
David
> From: mlerman@...
> Mark
Re: Silver Ink
2012-01-18 by studleylee
Very Nice!!!! Thanks David et al for the sources!!! I think these traces could be further electro-plated if needed.
-Lee Studley
> good luck!
> regards
> David
> > From: mlerman@...
> > Mark
2012-01-18 by Andrew Hakman
Do you have the link to the article / what journal it's in? I can probably
get it for you, but I thought for sure someone else would have access first.
Andrew Hakman
> Mark
Re: [Homebrew_PCBs] Re: Silver Ink
The silver acetate seems to go for about $2 USD per gram from
"legitimate" sources, less from ebay. They mix 1 g with 2.5ml of
ammonium hydroxide plus .2ml formic acid. Assuming you can get 2 ml
of ink from the mixture and that the cost of the ammonium hydroxide
and formic acid are negligible (???), the cost would be about $1
USD/ml. Since you are only drawing traces, it shouldn't be too
expensive, especially if you can reuse any ink wasted in head
cleaning. Anyone interested in a group buy of the chemicals?
Mark
>-Lee Studley
> > good luck!
> > regards
> > David
> > > From: mlerman@...
> > > Mark
> and Photos:
By the way, I did actually access the article, but it really does not
provide any useful additional information beyond the info in the
supporting data PDF. (some graphs and such).
-David
> Andrew Hakman
>> Mark
2012-01-19 by Donald H Locker
The supporting pdf (with the experimental method) was well written and complete. There is sufficient info there to allow replication of the ink and possibly enough to make an ink compatible with an ink jet printhead.
Donald.
*Plain Text* email -- it's an accessibility issue
() no proprietary attachments; no html mail
/\ ascii ribbon campaign - <www.asciiribbon.org>
> From: "David Mitchell" <gossiphog@...>
> Sent: Wednesday, January 18, 2012 5:03:29 PM
> Subject: Re: [Homebrew_PCBs] Silver Ink
> -David
> > probably
> > access first.
> > Andrew Hakman
> >> Mark
> > Photos:
> Photos:
Re: Silver Ink
2012-01-19 by Dave
Is that lab grade or technical grade? There's a HUGE price
difference between the 99% purity stuff, and the 99.9% purity
stuff. :-)
For that matter, has anyone researched how to produce Silver
Acetate themselves? It's probably a lot more complex than
simply dropping some Silver coins into a bottle of vinegar.
Ok, having looked it up on wikipedia, it looks like there's a
three step process (Silver + Nitric Acid->Silver Nitrate +
Sodium Carbonate -> Silver Carbonate + Acetic Acid ->
Silver Acetate.). That's not too complex. I think the real
problem with the cost is that the price of Silver is rather
incredible at the moment.
> They mix 1 g with 2.5ml of ammonium hydroxide plus .2ml formic
> acid. Assuming you can get 2 ml of ink from the mixture and that
> the cost of the ammonium hydroxide and formic acid are negligible
> (???), the cost would be about $1 USD/ml.
Ammonium Hydroxide is simply ammonia in water.
Formic Acid isn't too hard to synthesize (via a couple of routes),
so it should be reasonably cheap. Don't get it on you. It's
the active ingredient in bee and ant stings.
I doubt that the cleaned ink from the head could be reused. But,
a little care in batching up the plots could minimize waste.
> Mark
Dave <- Not a chemist, but I occasionally bathe in H2O!
2012-01-19 by John Anhalt
Silver is currently $29 per ounce on the spot market, but you can't buy it for that. $2.00 per gram for silver acetate sounds like bargain.
John
Sent: Thursday, January 19, 2012 11:08 AM
Subject: [Homebrew_PCBs] Re: Silver Ink
stuff. :-)
> Mark
RE: [Homebrew_PCBs] Re: Silver Ink
2012-01-19 by Boman33
There is also the option to use some old silverware? It is 92.5% silver.
It is just an extra step to purify it.
Bertho
From: Anhalt Sent: Thursday, January 19, 2012 11:54
John
2012-01-20 by Donald H Locker
99% "without further purification" if you read <http://pubs.acs.org/doi/suppl/10.1021/ja209267c/suppl_file/ja209267c_si_001.pdf>
Donald.
> From: "Dave" <wa4qal@...>
> Sent: Thursday, January 19, 2012 11:08:37 AM
> stuff. :-)
> > Mark
2012-01-20 by Mark Lerman
It would waste a lot less ink if you printed with a plotter rather
than an inkjet. That way you could easily make several passes and 2
sided boards. Does anyone have a plotter recommendation that is
available, inexpensive, and has appropriate software available? I
think I'm going to give this a try.
Mark
