Best Printer for photo process ?
2011-12-28 by marc
HI
i made lot of search on the forum
and not find clear answer about the best printer
for make photo process Transparency ?
lot of talk but for toner transfer not photo
my laser printer on mg chemical film was not dark egnof
i see some epson laser jet whit black-max ink  and rip software
but i never see any post here about it ?
sine i do this for semi professional i have bit of budget
but look for cheaper that buy mega-uk photoploter
Best regard
Marc Lalonde
Re: [Homebrew_PCBs] Best Printer for photo process ?
2011-12-28 by Leon Heller
On 28/12/2011 14:13, marc wrote:
> HI
I get excellent results with an HP 5940 and Mega Electronics Premium
JetStar film. It's a cheap printer.
Leon
Leon Heller
G1HSM
RE: [Homebrew_PCBs] Best Printer for photo process ?
2011-12-28 by Boman33
Hi Marc,
I started testing different printers, inks, settings and media but ran out
of time before finalizing the data.   3 printers * 5 media * varying ink
settings = lots of data.  Unfortunately work is interfering with my hobbies.
I did create a carefully designed test chart that allowed me to properly
measure the spectral density and resolution of the different combinations.
See:
http://www.vinland.com/USAF-1951.html
Happy hunting and please let us know what you come up with.
It would be interesting if people could mail me a sample of their best
combination artwork printed using my test chart so I could measure it and
include it in the final data and we would get a side by sided comparison  of
different systems.
Bertho
From: marc   Sent: Wednesday, December 28, 2011 09:14
HI
Best regard
Marc Lalonde
2011-12-28 by MIKE DURKIN
Has any one in the states tried this stuff?
 http://export.rsdelivers.com/product/rs/erprp200/aerosol-photoresist-solution-200ml/1989651.aspx
It's positive spray resist .... probably really expensive based on volume..
Mike KC7NOA
Date: Wed, 28 Dec 2011 20:50:03 +0000
Subject: Re: [Homebrew_PCBs] Best Printer for photo process ?
> HI
Leon
Leon Heller
G1HSM
2011-12-28 by Roland Harriston
Marc:
One trick that I have found useful is to make two copies of your work on
laser transparency material.
Then place one copy over the other and make sure that they line up
perfectly, then tape them
together on one or two edges.
You now have a transparency that is twice as dense (black areas are
twice as black)
as you would have using only one transparency.
Remember.....the two transparencies must line up perfectly to each other.
HTH
Roland F. Harriston, P.D.
marc wrote:
> HI
> Best regard
> Marc Lalonde
2011-12-29 by michael tenore
Hi All!
I once had access to Xerox 4125 laser printer that could lay down very dense traces for toner transfer when the print density was turned up..
You may well try to find a used one on eBay or Craigs list...
Regards
Mike
Sent: Wednesday, December 28, 2011 8:50 PM
> HI
Leon
Leon Heller
G1HSM
Re: Best Printer for photo process ?
2011-12-29 by Robert
I thought I saw a recommendation for the Ricoh 7000 somewhere...
it's around $900 (new)
a less expensive and not as fine dpi but Kyocera 1320 looks pretty good, around $400 (new)
I haven't tried either of these but looking at the specs I would guess they would do exeptionally well, especially the Ricoh.
neither has a built in copier though.
Robby
--- In Homebrew_PCBs@yahoogroups.com, michael tenore <wb2lcw@...> wrote:
> Hi All!
> Regards
> Mike
>  From: Leon Heller <leon355@...>
> Â
> > HI
> Leon
> Leon Heller
> G1HSM
2011-12-30 by marc
Hi Bertho and all
for now my Dell 3010cn have good resolution on mg chemical paper
but on bright lamp dark area look Gray but uniform
i will try a epson NX400 soon (just need tu buy back ink cartrige)
i have order some microfiche diazo duplicator film
hope to be able to use laser transparency as master for the diazo
and use diazo for my pcb exposure like in bigger shop
but my final target was find printer that able to print quality
transparency that was good and reliable for 6 mil trace/space
Best regard
Marc Lalonde
--- In Homebrew_PCBs@yahoogroups.com, "Boman33" <boman33@...> wrote:
> Hi Marc,
> See:
> different systems.
> Bertho
> HI
> Best regard
> Marc Lalonde
2011-12-30 by marc
HI Robby
that look really nice
think that sublimation printer may have good result
even if i have some budget for have just selling all my lpkf equipment
not sure that i will buy printer for be fist one to test it ;-)
Best regard
Marc Lalonde
Alphatronique inc.
> Robby
> --- In Homebrew_PCBs@yahoogroups.com, michael tenore <wb2lcw@> wrote:
> > Hi All!
> > Regards
> > Mike
> >  From: Leon Heller <leon355@>
> > Â
> > > HI
> > Leon
> > Leon Heller
> > G1HSM
RE: [Homebrew_PCBs] Re: Best Printer for photo process ?
2011-12-30 by Boman33
Marc,
It sounds like we have been traveling down the same roads.  I also used to
use Diazo for the final artwork but like you, I am hoping for direct
printing of the artwork.
I normally send out the artwork and get commercial boards made but for test
fixtures, RF striplines and other testing, a quick in-house setup would be
desirable.
Bertho
From: marc   Sent: Thursday, December 29, 2011 21:43
Hi Bertho and all
Best regard
Marc Lalonde
_,___
2011-12-30 by Robert
LPKF is some good stuff I read about,
kinda pricey for me though, about as close to the machine/router as I want to spend (time and $) is a RepRap for plastic parts (I could make my own stand offs for mounting boards).
I figure the photo process has a chance for much finer detail (with the right set up) and there's no need to convert files for milling (drilling though I guess the LPKF would come in handy).
anything would be an improvement for for me considering my antiquated and tedious mostly manual hand tracing/scribing etch pen and carbon paper technique.
one thing about it though, when you put that much work into a board it really becomes a thing of pride. several boards like that I made from the August 1980 Radio-Electronics 11 part/month construction article series "Build Your Own Robot For Under $400" or Unicorn-1 Robot as it was titled within the article's text. the first few sections of the series are on scribd here:
http://www.scribd.com/doc/3231860/Unicorn1-Robot-Articles-in-Radio-Electronics-
another link with lots of photos here:
http://www.theoldrobots.com/Unicorn.html
the most challenging board I remember was a double sided DTMF decoder circuit with 8 trimmer pots for tuning the frequencies of the 16 tones. the circuit was then connected to a simple fm receiver for 16 different on-off controls, a pair could be combined to have forward/reverse switching for the 12v Dc motors. pretty basic and the FCC has changed the rules since the article was originally published regarding the fm frequency used (just change to a legal public use frequency), but the DTMF decoder is still one heck of a nice circuit because of the old analog trimmer pots! you can tune the MF custom for almost no chance of interference (at least from stray wandering DTMF tones, however unlikely). this board was finished and all the parts soldered (with sockets for all ICs, I still have to buy the chips, hopefully I can find) some 25 or more years ago:
http://casino13.deviantart.com/art/DTMF-decoder-pc-board-102262741
sorry about the poor focus (I really need a tripod), and the photo was taken after so many years so the board traces show a little tarnish (along with dust particles on the components), I really should desolder everything and clean the board with a scotch pad and maybe think about trying to make some kind of simple plating bath.
anyway I'm a little exited this evening because I just took delivery of a Motorola R1150E Code Synthesizer II in perfect minty condition!
and was able to download the manual, unit powered on and passed all tests as outlined in the book!
the 1150 can produce just about any tone or combination of tone, custom tones, etc., that can really help when tuning this old board (after 25 years! if I can find the chips, can't remember but I think they're just 555 timers, common, and 7400 logic series, not sure which exactly, misplaced the article but I'll find it at some point.)
I may be slow but I'm not a quitter...
Robby
--- In Homebrew_PCBs@yahoogroups.com, "marc" <mlalonde@...> wrote:
> HI Robby
> Best regard
> Marc Lalonde
> Alphatronique inc.
> > Robby
> > > Hi All!
> > > Regards
> > > Mike
> > > Â
> > > > HI
> > > Leon
> > > Leon Heller
> > > G1HSM
2011-12-30 by marc
Hi Robby
buy my lpkf in 2004 (milling,plating,multilayer press)
and yes it very expensive cost price of a nice car ;-)
i find quickly that for be reliable it need to stay 8 mil and more
even if lpkf rate it for 4 mil trace ,it doable but tool was out of price 25$ for bit that last 3 linear meter !!  ,if do 8mil tool was 7$
and do near 30 linear meter ,and not talk about copper dust
even if milling was reliable it take time and have vaccum cleaner
for dust removal running so big noise on shop for ~8 hour per board
and you not have solder mask  ,this become problem Whit QFN ,BGA
so i find that it was time to move to photo process
open possibility to etch solder-past stencil in house
and have Proto pcb whit mask so it may made whit past /reflow
for now seem that my limitation for photo was film printer
and find way to not etch my via ;-)
my target was reliable 6 mil trace/space whit under 2000$ invesment
you boar look nice for hand draft and 20 year old
Best regard
Marc Lalonde
Alphatronique inc.
> Robby
> --- In Homebrew_PCBs@yahoogroups.com, "marc" <mlalonde@> wrote:
> > HI Robby
> > Best regard
> > Marc Lalonde
> > Alphatronique inc.
> > > Robby
> > > --- In Homebrew_PCBs@...m, michael tenore <wb2lcw@> wrote:
> > > > Hi All!
> > > > Regards
> > > > Mike
> > > > Â
> > > > > HI
> > > > Leon
> > > > Leon Heller
> > > > G1HSM
2011-12-31 by clausundercover
Has anyone tried making negatives with medical imaging printers? Those that print out x-rays.
I was watching some kodak dryview on e-bay and they are around 250-750 and maybe there are others, and I think maybe these printers may compete with lkpf and pro products since they print on photo film.
Then if it works there is a question of films, chemicals, etc...
>[snip]
2011-12-31 by marc
HI
Medical film printer i see was limited to 325DPI
it use kind of thermal film so good process but lack of resolution ..
I just but a new xerox solid-ink "Wax"  printer
1-) True 2400DPI resolution
2-) ink was wax so it etch and for sure developer resist to
    i see on this forum many user use very thin pcb on that printer
    for direct pcb printing whit good result
    but my idea was use a exposed DIAZO film (microfiche)
    then develop it ,wax will serve as developer resist
so result will be 2400 DPI diazo film  just like real pcb shop ;-)
3-) this printer use full length printing head so dot registration
    was perfect ,it actually print image on rotating drum then
    transfer it to the paper ,this was made a quite low temperature
   (65DeG c) so this may not pose problem of film shrink
4-) it quite easy to transform it in all back printer by loading
    Black ink block on all 4 tray ,so by manipulate the postscrip image it possible to have 4 wax dot think by pixel ,so in theory 3  time more opaque dark
5-)if all above fail A4 size drum will make a perfect drum for
   a DIY protoplotter ,since it well balanced ,have servo motor for drive it and knot it precise position
will post result when i receive/test the printer
if some one was interested this was in deep explanation of how this printer work , that reading tell me that it may make real nice artwork printer for pcb ..
http://www.imaging.org/ist/resources/tutorials/solid_ink.cfm
Best regard
Marc Lalonde
Alphatronique inc.
> >[snip]
2012-01-01 by DJ Delorie
I've had excellent results with my Epson R280 (Claria black) and Jetstar
Premium film.  However, the printer quality is now high enough that the
software's efforts to deal with low quality paper is the limiting
factor, so I ended up writing my own software.
Here's a sample 5/5 board I did with inkjet:
http://www.delorie.com/pcb/inkjet/insanity_II.html
and some other photos:
http://www.delorie.com/pcb/inkjet/inkmask-via-f.html
http://www.delorie.com/electronics/sdram/sdram-toppcb.html  (6/6)
2012-01-01 by MIKE DURKIN
Software?
Share it?
I have a R300 ...
Date: Sun, 1 Jan 2012 12:53:49 -0500
2012-01-01 by Boman33
Happy New Year to All!
Very, very nice DJ!
Is the software available? Is it a Gerber driver or does it take  a TIFF
file?  Either one is OK.
Bertho
From: DJ Delorie   Sent: Sunday, January 01, 2012 12:54
2012-01-01 by bebx2000
You might try fuse-on-foil
http://www.ctgraphic.com/info/brochure/Foil%20Fuser%20Q&A.pdf
http://www.papilio.com/includes/pdf/other/MTF.pdf
I came across a forum link (long since lost) advocating the silver foil to  make black toner areas absolutely opaque on transparencies.I bought some and it works just like Pulsar Green Foil to seal toner on PCBs to eliminate etching pinhole problems.
Baxter
2012-01-02 by DJ Delorie
I've shared it before...
http://www.delorie.com/pcb/pbm2escp2.zip
Converts PBM files to raw ESCP2 files.  If you're a windows user, you'll
have to figure out how to dump that binary file to your printer without
windows "interpreting" it.
2012-01-02 by Boman33
Thanks!!
From:  DJ Delorie   Sent: Sunday, January 01, 2012 20:33
__
2012-01-02 by gulick_steve
Hi
Is their metallic films actually conductive? If so, it might provide a start for direct printing of circuitry on paper or film. If too thin on not conductive enough, maybe it could be used further electroplate copper on the transferred foil traces
Steve
> Baxter
2012-01-03 by bebx2000
Hi Steve,
I don't think it is conductive. The areas over the laser print actually fuse into the toner so it is some form of plastic that has an affinity for toner. After you run a piece of foil taped to your laser print through your laminator, the piece of foil will have clear areas where it stuck to the toner.
Baxter
--- In Homebrew_PCBs@yahoogroups.com, "gulick_steve" <sgulick@...> wrote:
> Hi
> Steve
Solid ink printer follow-up ...
2012-01-04 by marc
HI
just make my first test on the Xerox solid ink printer
(collor-cube 8570n)
that was shame , noting close to 2400dip claimed by xerox
this was same pcb image print wit dell laser printer (600DPI)
and whit the Xerox for comparaison (transparency over white sheet)..
http://www.alphatronique.com/XEROX.JPG
http://www.alphatronique.com/dell.JPG
only good thing is that black was really black
this was also image from Xerox print on paper of a QFN 0.5mm pitch
http://www.alphatronique.com/tqfp.JPG
some trace close up ...
http://www.alphatronique.com/trace.JPG
so i still need to find a better printer once again
Best regard
Marc Lalonde
Alphatronique inc.
> HI
> Best regard
> Marc Lalonde
> Alphatronique inc.
> > >[snip]
RE: [Homebrew_PCBs] Solid ink printer follow-up ...
2012-01-04 by MIKE DURKIN
What image was sent to the printer?
I need to make some QFN .5 TOO...
IM still going to try a R300, Maybe 4 passes and 4 bakes .... don't know.
Date: Wed, 4 Jan 2012 18:57:16 +0000
Subject: [Homebrew_PCBs] Solid ink printer follow-up ...
      HI
(collor-cube 8570n)
Best regard
Marc Lalonde
Alphatronique inc.
> HI
> Best regard
> Marc Lalonde
> Alphatronique inc.
> > >[snip]
Re: Solid ink printer follow-up ...
2012-01-04 by marc
HI
image was print direct from my Cad Software (P-CAD 2006)
trough the xerox postscript print driver
if print in PDF then print the pdf seem to have bit better
image but still not usable for any 0.5 pitch smt
on microscope look like printer use kind of dithering
that look good on color picture (photo print)
but for pcb my old Dell 3010CN laser was far better
i see futureshop have sale on epson nx625 for 50$
so this time it will less expensive test ;-)
Best regard
Marc Lalonde
> From: mlalonde@...
RE: [Homebrew_PCBs] Re: Solid ink printer follow-up ...
Wonder if dithering can be turned off in my R300 ....
Date: Wed, 4 Jan 2012 20:49:20 +0000
Subject: [Homebrew_PCBs] Re: Solid ink printer follow-up ...
      HI
Best regard
Marc Lalonde
> From: mlalonde@...
Re: [Homebrew_PCBs] Re: Solid ink printer follow-up ...
2012-01-05 by DJ Delorie
MIKE DURKIN <Patriot121@...> writes:
If the R300 is like my R280, the dithering is done by software on the
PC.  I use my own software which doesn't dither, and get "perfect" 2880
DPI prints (assuming the film can handle that much ink without
smearing).
2012-01-05 by MIKE DURKIN
The one you shared ... I hope so ...
Perhaps not a solid print ... bake then repeat to keep from smearing ...
Date: Thu, 5 Jan 2012 00:05:22 -0500
Subject: Re: [Homebrew_PCBs] Re: Solid ink printer follow-up ...
smearing).
2012-01-05 by alex4459jopiklal44
try with red ..
I had the same with a cannon. that claimed 2400 ..but they all have a smaller resolution in black when you read the specs. and they often have a lower resolution in the other direction.. that means, as I see it ,that it is the lowest resolution that count.. so I printet a B/W with my new cannon.. looked like yours.. but then with red it was better than my old HP 710. I can see it when it is etched.. the edges is much sharper. and red gives perfect stop from the UV.. yellow and blue did not stop as well.
alex
my printer is the cannon IP4850 and I print on transparancy and use precoated boards , expose with uv in 3 minutes .I can do 5 mil traces and clearance, at least over 5x2cm without any fault.
> (collor-cube 8570n)
When I got my latest films, I had to add a dithering option to reduce
ink away from the edges to keep it from smearing.  I'm not sure I could
reprint with any hope of alignment accuracy.
Perhaps you could do two films, the first with a clean dark edge and
less ink in the middles, the second with the edges moved back
(i.e. shrink everything) so it's less sensitive to misalignment.  You'd
of course put the shrunk one on top so the more accurate edge is closer
to the copper.
2012-01-06 by AlienRelics
It is about blocking UV, too. Black is fairly light resistant and so does not really need UV blockers, whereas the colors have more sensitivity to it.
Depending on the exact ink formulation, particular brands may put more UV inhibitors in different colors. In your Canon, apparently Magenta has more UV inhibitors.
I've read of others having even more luck with 6 color CcMmYK printers, using light colored green prints because it uses the photo inks to print it, and the photo inks have a lot of UV inhibitors due to their increased sensitivity to fading.
Steve Greenfield AE7HD
--- In Homebrew_PCBs@yahoogroups.com, "alex4459jopiklal44" <christiansen_alex@...> wrote:
> try with red ..
> alex
> > (collor-cube 8570n)
2012-01-07 by DJ Delorie
"AlienRelics" <alienrelics@...> writes:
> sensitivity to it.
I tested all six of my (Claria) inks.  Black and Yellow blocked UV just
fine, but yellow didn't dry fast enough (and was hard to see when you
try to line it up on the board).  The other four colors were completely
transparent to UV.  Black it is.
