Re: [Homebrew_PCBs] Cutter selection and/or hack s
2011-11-18 by Piers Goodhew
Where do you get that from?
(btw I did get some fr4 from eBay, a seller in Qingdong, and it's perfectly fine. 5 10*15 (cm) sheets less than 10 bucks. Took a while to arrive as usual.)
PG
Sent from my phone, anything lewd or incomprehensible is probably autocorrect and not my fault.
----- Reply message -----
Subject: [Homebrew_PCBs] Cutter selection and/or hacks
Date: Fri, Nov 18, 2011 7:44 am
On 17/11/2011 15:43, DaveC wrote:
> This stuff is TOUGH! I scored with a utility knife, through the
> copper and well into the fiberglass. When I bent it over the edge of
> a table, it bowed a lot before finally breaking.
I use CEM-1 paper/fibre-glass laminate. It's *much* easier to cut and
drill than FR4.
Leon
Leon Heller
G1HSM
Re: [Homebrew_PCBs] Cutter selection and/or hacks
2011-11-18 by Leon Heller
> arrive as usual.)
Farnell stocks it. I usually get mine from Mega Electronics, as the
resist seems better.
Leon
Leon Heller
G1HSM
