Using a pantograph for making pcb's
2011-09-08 by javaguy11111
I was wondering if anyone has tried using a pantograph for making a pcb. A larger scale image could be printed out on paper and traced using the pantograph to make a smaller size on the pcb. A fine tip magic marker could be used as a resist or maybe just printing directly using conductive ink.
It is sort of a low tech way to do it, but it would provide another option.
Re: Using a pantograph for making pcb's
2011-09-08 by Bob Butcher
That is an interesting thought. I happen to have an old Hermes engraving pantograph with a diamond tip. I could print the PCB out 2:1 and trace the spaces between lines to scratch the copper through to the substrate, which would isolate all the copper that I want to keep. As an alternative I could spray paint the copper and scratch off the paint where I want to remove the copper, followed by etching the copper in the scratches. I have used this technique before, but used an exacto knife or carbide scribe to hand scratch the paint off instead of a pantograph. I will have to try it and see what happens. It should work for fairly small boards in any case.
Bob
Re: [Homebrew_PCBs] Re: Using a pantograph for making pcb's
2011-09-08 by Paul Mateer
Interesting concept.....
> Bob
Paul Mateer, AA9GG
Elan Engineering Corp.
www.elanengr.com
NAQCC 3123, SKCC 4628, FPQRP 2003
2011-09-08 by David Griffith
I don't think I would have the patience to make PCBs that way.
David Griffith
dgriffi@...
A: Because it fouls the order in which people normally read text.
Q: Why is top-posting such a bad thing?
A: Top-posting.
Q: What is the most annoying thing in e-mail?
Re: [Homebrew_PCBs] Using a pantograph for making pcb's
2011-09-08 by Riley
that'd certainly make it easier to do fine detail for those preposterously tiny smd pads...
templates could routed in wood/plastic/cardboard with cnc equipment that doesn't have such fine detail, like a carveright, cricut, makerbot
Riley
2011-09-08 by Piers Goodhew
I think it would be significantly easier than making one by hand,
significantly harder than making one via some fully automated process
PG
> tiny smd pads...
> Riley
2011-09-08 by Tim Gibbs
Hi I have a small engraving pantograph for marking signs.
Copied a trace from paper, It turned out fairly rough and is Ok for a small
board without IC.
This is an exercise of great care, one slip and bingo! Start a gain.
Regards
Tim
