Spiral Challenge
Spiral Challenge
2011-08-02 by Eldon Brown
I took the Homebrew PCB Group Spiral Challenge, for my initial results see:
http://wa0uwh.blogspot.com/
or an on site search for; PCB
72 - Eldon - WA0UWH - CN88xc - http://WA0UWH.blogspot.com/
Re: [Homebrew_PCBs] Spiral Challenge
2011-08-04 by DJ Delorie
Did you try to fix the breaks and measure the resistance?  I think it
would be interesting to see if my calculations are accurate, and if so,
how the measured resistance compares to it relative to how much
bigger/smaller than "spec" the etched traces are.
2011-08-04 by Eldon Brown
OK, DJ
I did that, see the web page.
I will have more thoughts later, it is late.
Eldon Brown
Sweet!
Here's a tip: you know the track-to-track spacing is 20 mil (you did say
10/10 pattern, yes?).  Given that, you can calculate the actual DPI of
the photo (about 4300 dpi for the spot I was measuring).  Also measure a
track, and you can compute the actual track width (about 9.2 mil in some
spots, 7.1 in others).
But simply measuring pixels-of-copper vs pixels-of-space should
tell you how close to "perfect" you are.
Your ohms are a little high, some things that might cause that:
* pinholes cause "necks" in the copper which add resistance
* cleaning/scraping/sanding the copper might thin it somewhat
* thinner traces on average would increase it
If you just go by the ohms ratio, it says your average trace width is
18/23 * 10 = 7.8 mil, which sounds close enough.
Did you measure the high ohms between the two tracks?
Also, if you have a flatbed scanner, they're often useful for
high-accuracy PCB scans.
DJ,
I just realized via your last name and the Spiral Challenge URL, that you
are the owner/keeper of the Challenge. And, we may have chatted/email before
on other issues.
Thanks for the Challenge, and insight.
Yes, the resistance between traces is greater the several Meg ohms. I
updated the blog page a little.
I think with more attention to details, I could successfully produce a
flawless 10/10 Challenge board, using the Toner Transfer Method. Or maybe
even a higher resolution version with  smaller traces.
Perhaps a PCB Software Vendor, Transfer Paper Vendor, or an Industry Leader
would like to sponsor a Homebrew PCB Contest or a Formal Challenge.
It would be fun.
Thanks for your Homebrew PCB support and efforts.
Eldon Brown
On Thu, Aug 4, 2011 at 10:08 AM, DJ Delorie <dj@...> wrote:
> Sweet!
>  ,___
Eldon Brown <eldonb46@...> writes:
> DJ,
Yup!  Hence my interest in your results :-)
Whew :-)
