Homebrew_PCBs
Blue Laser Drum Plotter
2011-06-12 by Volkan
Hi All,
Recently, I worked on a homemade drum plotter to expose negative acting film. I added some photos under Photo Albums > Drum_Plotter_V_Sahin and there is also a video on youtube
(http://www.youtube.com/user/vulcanmicronics).
Later, I will add more videos.
Short performance summary of the plotter
Resolution 832x2032 dpi
Optimum exposure time on RLN-4 Film=9.5 microseconds with 405nm 150mW laser.
Optimum drum speed:~615 rpm
Volkan
Re: Blue Laser Drum Plotter
2011-06-13 by psykhon@yahoo.com
Great job! looks amazing!
How do you focuse the laser?
--- In Homebrew_PCBs@yahoogroups.com, "Volkan" <v_sahin@...> wrote:
> Hi All,
> Thanks,
> Volkan
2011-06-14 by stan_katz
Marvelous!
I've been looking for a way to get consistently high quality negatives for fine pitch (surface mount) photoresist hobby work. I use Riston. To get the desired quality, I actually make litho negatives ( I don't mind darkroom work) from inkjet positives to increase density and resolution. This works after a fashion, but I have always wanted to go directly to film negative.
My local print shop has gone away. Anyhow, paying $10.00 - $15.00 to a printshop to imageset one design to film on a diy budget got ridiculous.
Therefore, I looked into purchasing a used print shop imagesetter from Ebay to do what you have accomplished. These beasts weigh a ton, take up too much room, and use proprietary chemistry and film rolls. They are smelly brutes that would pollute one's home. Anyway they are becoming obsolete. Supplies, if still available, are sold in industrial quantities, for a fortune.
Small quantities of letter size litho and RLN4 using standard A&B chemistry are still available from Ultrafine (Stateside). Your plotter's modest appetite for inexpensive films, and it's manageable size make it a winner! If you don't have plans to sell a construction manual, or manufacture the plotter for resale, I do hope you will post the construction details when you have a chance.
BTW Can it be built without access to a machine shop?
> Hi All,
> Thanks,
> Volkan
2011-06-14 by designer_craig
Stan,
Volkan also built a direct UV laser writing system that immages the pattern directly on the Riston coated PCB. It raster scans the laser over the board using a hacked printer mechanical. Even tested it on some boards I coated with AQ3000 pos photo resist for him. The resolution was just amazing. It takes about 20 to 30 minutes per side to expose an average board so the drum plotter is a better solution if you need to make more that one or two of the same board.
Both of these projects are on my list of things to build once I get my CNC mill finished up.
Craig
--- In Homebrew_PCBs@yahoogroups.com, "stan_katz" <stan_katz@...> wrote:
> Marvelous!
> --- In Homebrew_PCBs@yahoogroups.com, "Volkan" <v_sahin@> wrote:
> > Hi All,
> > Thanks,
> > Volkan
Re: [Homebrew_PCBs] Re: Blue Laser Drum Plotter
2011-06-14 by Volkan Sahin
Hi Stan,
It is not easy to sell it as a kit because of the drum. The critical item is photocopier drum. I don't know whether it is possible to find cheap well balanced cylinder like that or not.
I just built it for my needs with the available materials that I've. If you plan to do it yourself it requires some custom mechanical parts.
I still didn't finalize user interface and I decided to replace dc-motor with brushless one, so it'll take sometime to document it.
Volkan
--- On Mon, 6/13/11, stan_katz <stan_katz@...> wrote:
Subject: [Homebrew_PCBs] Re: Blue Laser Drum Plotter
Date: Monday, June 13, 2011, 8:51 PM
Marvelous!
> Hi All,
> Thanks,
> Volkan
Hi Volkan,
I can see I'm out of my league. You, and Craig are designer/machinists. Many years ago I worked as an engineer for a military contractor that gave evening in-plant courses on every technical subject imaginable. One "semester", I signed up for Kalman Filtering for guidance control. I was intrigued with another course which conflicted with the filtering course. It was Machine Shop I! If I had taken Machine Shop I, followed the next semesters with Machine Shop II and III perhaps I could have joined your exclusive club. This is not the only group I'm a member of where I have wound up kicking myself for that decision made so long ago!
Sigh!
Stan
--- In Homebrew_PCBs@yahoogroups.com, Volkan Sahin <v_sahin@...> wrote:
> Hi Stan,
> Â I just built it for my needs with the available materials that I've. If you plan to do it yourself it requires some custom mechanical parts.
> I still didn't finalize user interface and I decided to replace dc-motor with brushless one, so it'll take sometime to document it.Â
> Volkan
> From: stan_katz <stan_katz@...>
> Â
> Marvelous!
> > Hi All,
> > Thanks,
> > Volkan
2011-06-15 by designer_craig
Stan,
A lot of this is trial and error learning, I am not a machinist just a retired digital logic design engineer. Did take a couple of simple machining classes at college back in the early 70's but mostly its learn by doing or should I say learn by screwing up the first parts. I do have to give the net credit for allowing one to find the answer to almost any problem you can think of and to Youtube videos, they are great teachers. Never new what thread rolling was all about till I saw a youtube video and had the AH! moment. But there is never enough time to do all the learning you would like.
Craig
> Hi Volkan,
> Sigh!
> Stan
> --- In Homebrew_PCBs@yahoogroups.com, Volkan Sahin <v_sahin@> wrote:
> > Hi Stan,
> > Volkan
> > --- On Mon, 6/13/11, stan_katz <stan_katz@> wrote:
> > From: stan_katz <stan_katz@>
> > Â
> > Marvelous!
> > > Hi All,
> > > Thanks,
> > > Volkan
