Saving Press N Peel Blue Transfer Film
2011-06-09 by schenckcharles
Hi
For the last few years I have been using Press N Peel with a Dell
1700 laser printer in my home workshop.  Results have been excellent, with little wastage of PCB material or etchant.  However, most PCB
artwork is amaller than a standard page and there are always scraps
of the toner transfer material left over.
I solved this problem by printing the artwork on a piece of plain paper,
then rubber cementing a piece of the Press N Peel, which is slightly
larger than the artwork, dull side up.  Excess rubber cement is rubbed
away from the edges.  Then the whole gizmo is sent through the printer
again.  Rubber cement is removed from the shiny side of the Press N Peel
Blue before ironing it onto the copper board.
Just be sure that there is no traces of rubber cement on the sheet which
could contaminate rullers inside the laser printer.
Hope this works for all of you penny pinchers out there!
Cheers
Chris
Re: [Homebrew_PCBs] Saving Press N Peel Blue Transfer Film
2011-06-09 by David Griffith
On Thu, 9 Jun 2011, schenckcharles wrote:
> Hi
> For the last few years I have been using Press N Peel with a Dell 1700
> little wastage of PCB material or etchant.  However, most PCB artwork is
> amaller than a standard page and there are always scraps of the toner
I thought everyone did something like that.  It's in the Pulsar paper
documentation.
David Griffith
dgriffi@...
A: Because it fouls the order in which people normally read text.
Q: Why is top-posting such a bad thing?
A: Top-posting.
Q: What is the most annoying thing in e-mail?
2011-06-09 by Kim Vellore
Chris,
  I have been doing the same too except I use a tape and stick only
the feed end ~2mm inside of the blue transfer film with the other
three ends free, it has been working well for me so far. Sometimes
when the paper is large I add a little tape to the other three ends
too
Kim
On 6/9/11, schenckcharles <schenckcharles@...> wrote:
> Hi
> Cheers
> Chris
