Direct Laser Printing: How do you get the toner to stick better?
2011-06-06 by Rob Frohne
Hi All,
We are using a modified E260, but are having difficulty getting the
toner to consistently stick to the board, especially on larger boards
with large ground planes.  We have found some improvement by adding
another larger piece of board in electrical contact with the one to
print, but results are still inconsistent.  Do you have any hints for me
and my students?
Rob
Rob Frohne, Ph.D., P.E.
E.F. Cross School of Engineering
Walla Walla University
100 SW 4th Street
College Place, WA 99324
(509) 527-2075			 http://people.wallawalla.edu/~rob.frohne
Re: [Homebrew_PCBs] Direct Laser Printing: How do you get the toner to stick better?
2011-06-06 by Jim
Rob,
I also use a E260 to directly print to the PCB.
I solder a small wire to the blank PCB and connect it to ground. I use a
card stock carrier. As the PCB gets bigger (more square inches), I
sometimes connect the PCB to an adjustable 0 to 500 volt power supply
through a 3 to 5 meg resistor. I found the best voltage to be about +350
volts.
Cleaning the PCB with acetone is a must.
Search the archives for the words "acetone fix toner" for my method of
"fixing" the toner to the PCB without ANY heat.
Jim KI6MZ
On 6/6/2011 11:40 AM, Rob Frohne wrote:
> Hi All,
> and my students?
> Thanks,
> Rob
2011-06-07 by Rob Frohne
Hi Jim,
Thanks for the tips.  Your wire idea sounds good.
We have excellent results fixing the toner by running it through the
re-flow oven.
Again, thanks!
Rob
On 06/06/2011 02:04 PM, Jim wrote:
> Rob,
> volts.
> Jim KI6MZ
> > Hi All,
> > and my students?
> > Thanks,
> > Rob
100 SW 4th Street
