Controlled solder paste dispensing
2011-05-07 by Boman33
For regular SMT assembly I use commercial stencils to screen print the solder paste but I am having problems dispensing solder paste by hand in small amounts for rework or prototypes. I have seen somewhere that individual stencils are sold but that adds the requirement to accurately align the stencil which will be very difficult on a rework board. Using a syringe and placing a single long bead across all the IC pin pads work fine on wider pitch ICs but as the pitch is getting smaller I am having trouble getting the line thin enough. In other words, there is too much solder so when I reflow there are solder bridging. If I use a finer tip on the syringe I cannot squeeze it hard enough for the paste to come out. If I add some flux it gets thinner but too runny. I like the normal consistency since it helps to keep the ICs in place with its stickiness. My current smallest bead diameter is 0.5mm (20mils). I like to be able to get about half of that size. I am basically looking for a solder paste with less solder and more thick flux material so I can squeeze out a reasonably sized bead but after reflow there is less solder than a normal paste. Any suggestions on a paste like that? Any other suggestions on how to place a very small amount of solder on the IC pads? Thanks in advance for suggestions. Bertho [Non-text portions of this message have been removed]
