WTB: PID temperature controller
2011-03-12 by David C. Partridge
2011-03-12 by Kerry Wentworth
> Does anyone have one or more of these they are happy to part with for very little. 240V supply required, SSR output preferred.--
> As postage may be an issue, I live in UK.
> Thanks
> Dave
2011-03-12 by Les
--- In Homebrew_PCBs@yahoogroups.com, "David C. Partridge" <david.partridge@...> wrote:
> Thanks
> Dave
> Kerry,--
> Unfortunately though they would seem ideal in most all respects, as far as I can tell from the manual they are about 6.25" deep, and I don't have much over 3" to play with behind the panel.
> If I've got that wrong, please let me know.
> Regards,
> David Partridge
2011-03-13 by jeremy hodder
2011-03-13 by Tony Smith
> Thanks, I Saw those, but was hoping I might score one cheaper - also...
> suspicious of the anonymous off-brand Chinese parts - maybe unjustifiably
2011-03-13 by David C. Partridge
> unjustifiably
> Hmmmm .. Prices including delivery to UK and likely customs charges (20%plus
> about $18), aren't as comfortably low as that.Ok, they're cheap to where I am (Australia). We don't pay VAT (10% GST
> David, You could try making one. The REPRAP group makes pid temperatureOk, I looked up the RepRap PID, and they use the 'usual chip' for the
> controls for the heated bed and extruder.
> Oh, and I should mention it doesn't have a SSD built-in, but it can drivean
> SSD.Sigh. That's SSR (Solid State Relay), not SSD (Solid State Drive).
> Oh, and I should mention it doesn't have a SSD built-in, but it canan
> drive
2011-03-13 by Charles Patton
> thermocouple, the AD595. Sparkfun - http://www.sparkfun.com/products/306 -
> have them for $18. The other 'usual chip' is the MAX6675, and it's $12.
> Ouch. You still need a display, controls, microcontroller, PID coding,
> power supply and a few other bits & pieces.
> I think I'll take my chances with the $25 eBay unit.
> My only problem with that unit is it doesn't (I think) send a signal
> when it
> reaches temperature, you could use that to start a timer. It has an alarm,
> but that's only for under/over-temperature. I figure I can do it by
> monitoring the heater, and when it switches off for the first time use
> that
> to start the timer.
> drive an
> SSD. It also has a relay that can handle 240v @ 3 amps.
> Tony
> And I guess only a very few can do profiles with dwell times (thinkre-flow
> oven soak time) or do that all do that?These ones don't, they just maintain a single pre-set temperature. No
> Tony,Yeah, I wasn't optimistic, I figured I might be pretty close to the target
> You wrote, "I figure I can do it by monitoring the heater, and when it
> switches off for the first time use that to start the timer."
> No, that won't work.
> Any decent PID controller properly set up will start to cycle as it
> approaches the setpoint temperature. That cycling point is controlled
2011-03-21 by Tony Smith
2011-03-23 by jmelson2
>Right, many of the units have an extra-cost option to do this. I got an Omega CN4800 for reflow control, but it has the ramp and soak feature, and I think lists for ~ $800. I got it on eBay for $60 or so.
> And I guess only a very few can do profiles with dwell times (think re-flow oven soak time) or do that all do that?
