Homebrew_PCBs
Archive for Homebrew_PCBs.
FR-4 Copper Clad and Etchant mix
2011-02-22 by Randy S.
FR-4 doesnt have to be green colored? Correct ?
Other question .. for making etchant ..
I saw 2 parts peroxide to one part muriatic acid ( 34% hydrochloric acid )
and I saw 3 to mix as well ..
Is it crucial ? I mean I guess the only thing that it would change is the
etching
times .. and the fumes LOL .. ??
Randy
Re: [Homebrew_PCBs] FR-4 Copper Clad and Etchant mix
2011-02-22 by Adam Shea
FR-4 isn't green, it's kinda beige. On commercial boards it's the
solder mask that's green (or red, or blue, or black, or white).
--Adam Shea.
> etching
> Randy
2011-02-22 by Tom Biery
    I don't know if that formula is correct I am curious if it is?  What are the
benifits of using that vs ammonium persulfate, that is what I am using in this
youtube video... http://www.youtube.com/watch?v=trnvlrVq6P0%c2%a0and it works fine.
Please let me know.
Tom
To: Homebrew_PCB <homebrew_pcbs@yahoogroups.com>
Sent: Mon, February 21, 2011 8:29:51 PM
Subject: [Homebrew_PCBs] FR-4 Copper Clad and Etchant mix
etching
Randy
2011-02-22 by Harvey White
I've used black, good for displays, blocks light.
>etching
I've used 4 parts peroxide to 1 part acid. Don't think it's
absolutely critical.
Harvey
>Randy
ooooh ok .. thank you..
Sent: Mon, February 21, 2011 8:31:40 PM
Subject: Re: [Homebrew_PCBs] FR-4 Copper Clad and Etchant mix
--Adam Shea.
> etching
> Randy
Is it any safer in the sense of fumes, etc .. hazmat ?
Sent: Mon, February 21, 2011 8:40:42 PM
youtube video... http://www.youtube.com/watch?v=trnvlrVq6P0 and it works fine.
Please let me know.
Tom
etching
Randy
oh .. can I mix and store this ? or is it a mix , use and discard ?
and are there disposal issues ?
etching
Randy
I mix the acid into the peroxide? Not the other way around?
and do I have to mix slowly? is there heat generation or splattering?
from the mixing process ?
Sent: Mon, February 21, 2011 8:43:46 PM
>etching
Harvey
>Randy
Mix and store. After about 30 days, the peroxide goes and it will not
etch. Bubble air through it and that will regenerate it. Eventually,
I think you will need to add HCL to it. Etchant lasts a long while.
Turns green to CUCL etchant...
Look into the archives and there's links to a lot of good
documentation.
Harvey
>From: Randy S. <rj3819@...>
>etching
>Randy
ALWAYS add acid to water. Heat will be generated, but splattering
will be minimized that way. Mix slowly. Check general chemistry lab
rules.
Harvey
>From: Harvey White <madyn@...>
>>etching
>Harvey
>>Randy
ok thanks .. NEVER took chemistry .. lol
I will look in the archives ..
Thanks for the great info ..
I guess I should mix small amounts unless I plan on using
it up in 30 days .. is it photo sensitive?
Sent: Mon, February 21, 2011 9:28:42 PM
rules.
Harvey
>>etching
>Harvey
>>Randy
Not photo sensitive. Since it's an acid, it will eat holes in your
shirt. I use it outside, having heated it a bit and bubbled air
through it. When brand new, it etches boards in about 5 or 6 minutes
at the most. After a long while, it stretches to 20 minutes.
If you're in the US, then the acid is about 8 dollars a gallon, and
the H2O2 (peroxide) is about 1.50 to 2.00 a quart. You want the 3%
stuff sold in the drugstores. It is also known as 30 vol, a measure
of the amount of oxygen it will produce.
You start off with one etchant, you end up with another. Some will
immediately add about 4-6 oz of copper to convert to the CuCl etchant.
I let the boards do it.
Bottom line: it's cheap. I use a cereal container (plastic),
relatively acid proof, and do 4 by 6 inch boards (actual size before
trimming about 5 by 7 inches). I can do two of them at once or more
than two depending on what the board size is.
Air bubbling moves the etchant around, and gives the etchant the air
it needs. I use about 5 quarts at a time, due to the board and tank
size.
Harvey
>rules.
>Harvey
>>>etching
>>Harvey
>>>Randy
ok thanks .. I was thinking about mixing in a antifreeze jug .. and putting in 3
- 32oz H2O2 and then add 32 OZ of acid ..
outdoors, slowly, with respirator and nitrile gloves and glasses..
I have an old aquarium pump and aerator somewhere ..
Sent: Mon, February 21, 2011 9:48:15 PM
size.
Harvey
>rules.
>Harvey
>>>etching
>>Harvey
>>>Randy
How do I dispose of exhausted etchant ?
size.
Harvey
>rules.
>Harvey
>>>etching
>>Harvey
>>>Randy
