charles.r.patton@...>
To:
Homebrew_PCBs@yahoogroups.com
Sent: Fri, February 18, 2011 9:03:39 PM
Subject: Re: [Homebrew_PCBs] FreePCB question
FreePCB has not implemented the print function. You need to generate
the CAM files (Gerbers) and view them with a free viewer such as
GC-Prevue from Graphicode. There are others, but GC-Prevue is the one I
use. It is quite capable of printing any layer or layers normal or
reversed, at scale or filling the page. . The other technique I use
is to fill the screen with the board being designed, do a "Screen Print"
to the clipboard, then paste into my free graphic viewer of choice,
Irfanview. Go to "edit" and invert the colors so that the background
goes to white -- saves on toner or ink as the case may be. This method
is nice when I start troubleshooting the board as it's in color and I
can easily trace a signal as I see the front and back simultaneously
without confusion. Either of these methods takes less than a minute.
Charles R. Patton
On 2/18/2011 5:23 PM, Randy S. wrote:
> I cant seem to be able to print ..
> The option is grayed out ..
> Do I have to finalize something?
> Or export or create something?
