preferred laserjet printers
2011-02-17 by Randy S.
Would like to get a feel for what printers
people are using for these PCB's?
Mostly interested in the ones you are printing
with at home .. so I can buy one ..
If I remember right I think I saw one with the
number 1018 or 1081 in it ??
Anyways.. whats everyone using ?
Randy - N2CUA
Re: [Homebrew_PCBs] preferred laserjet printers
2011-02-17 by Bob Butcher
I have a Brother HL1440 which does not work well. For some reason the toner does not want to transfer to the PCB, perhaps it takes more heat than I can generate. I also have an HP LaserJet 4 Plus that works better.
Bob
--- On Thu, 2/17/11, Randy S. <rj3819@...> wrote:
Subject: [Homebrew_PCBs] preferred laserjet printers
To: "Homebrew_PCB" <homebrew_pcbs@yahoogroups.com>
Date: Thursday, February 17, 2011, 10:51 AM
Randy - N2CUA
Thanks Bob ..
I was trying to research the HP toners for melting temp .. doesnt seem to be
readily published.
I did find this however..
""The HP 06A Black LaserJet Toner Cartridge is ideal for business or home  users
who need professional-quality laser output. It is designed  together to work
together with the HP LaserJet 5L and 6L series  Printers, and the HP LaserJet
3100 and 3150 All-in-Ones. The special  low-melt mechanism means lower
temperatures for less energy waste and  greater productivity. Average cartridge
yields 2500 standard pages.  Declared yield value in accordance with ISO/IEC
19752. ""
So a good question might be if the 5L and 6L printers are being used with
success ? If so .. perhaps printers with thes 06A cartridge might be a good
choice ?
Randy
Sent: Thu, February 17, 2011 1:11:31 PM
Subject: Re: [Homebrew_PCBs] preferred laserjet printers
Bob
Randy - N2CUA
2011-02-17 by Erik Knise
DJ Delorie used to post on here a lot.  His website is full of great info.
http://www.delorie.com/electronics/laminator/
Most "stock" laminators are not hot enough.  Some have been successful with
lots of passes while some have made custom controllers.  The issue a lot of
people have is that right when it's done heating most laminators turn off
the element until it gets to a threshold then it heats back up.  Instead of
using a slightly more complicated controller to get a nice steady
temperature.  It is possible to melt your laminator but a lot of people have
had good luck with the gbc personal series laminators.
On Thu, Feb 17, 2011 at 10:21 AM, Randy S. <rj3819@...> wrote:
> Thanks Bob ..
> be
> readily published.
>  users
> work
> LaserJet
> cartridge
> ISO/IEC
> 19752. ""
> choice ?
> Randy
Erik L. Knise
Pacific Shipping Company
Seattle, WA
2011-02-17 by Chris Kleeschulte
I use:
hp p1505n
it works well, it works under CUPS (linux and mac), it prints images that
preserve proportions...pdfs are exactly as they appear on the computer
screen. It prints my cheap magazine paper well (although I glue the paper to
standard copier paper) and the non-HP toner refills are about $22. $80 for
the HP ones. I find the fake ones from Amazon work equally well.
Chris
> > Thanks Bob ..
> > be
> > readily published.
> > users
> > work
> > LaserJet
> > cartridge
> > ISO/IEC
> > 19752. ""
> good
> > choice ?
> > Randy
> Erik L. Knise
> Seattle, WA
He had this info on the site .
Thought it might be interesting for others .
Assuming accruacy here and that things havent changed
since it was posted.
HP Toner 340 degrees F
Brother Toner 370 Degrees F
Sent: Thu, February 17, 2011 1:50:23 PM
> Thanks Bob ..
> be
> readily published.
> users
> work
> LaserJet
> cartridge
> ISO/IEC
> 19752. ""
> choice ?
> Randy
Erik L. Knise
Seattle, WA
2011-02-18 by DJ Delorie
Erik Knise <elknise@...> writes:
I'm still here, just haven't had much to say.  I got a new laser printer
(HP 3600n) that doesn't seem to stick as well as the 2550n at the same
temperature.  I'll probably have to re-test its toner - I got the toner
off eBay, might not be HP.  I was thinking about doing some tests with a
transparency - temperature, number of passes, see if I can find the
temperatures for plasticity and melting.  At least you can see through
transparencies :-)
Overall, I've been sticking with UV film instead.  More steps, but a LOT
more reliable.
Oh - I found out how to put 1/16" PCB through a 1/32" laminator
reliably.  Tape it to a sheet of paper.  Once the paper is pulled into
the laminator, the PCB is gently pulled in along with it.  I laminate my
UV films this way.
Also, I'm very happy with using 28 gauge brass wire in a 13.5 mil hole
for vias.  Brass is stiff enough to not bend, and friction holds it in
place while you solder.
Also, the temperature control hack for the laminator was WORTH IT!! :-)
