Homebrew_PCBs
Archive for Homebrew_PCBs.
pump for spray etching
2003-09-30 by Adam Seychell
Anyone here every built a spray etcher ?
I'm looking at building a spray etcher on the cheap, but I cannot
find a suitable pump. Pressure requirements are fairly high for
sprays nozzles to work effectively. The pump must be capable of
at least 10 meter head (1 bar), but all low cost fountain pumps
are rated no more than 4 meters head. Getting hold of a pump is
the killer. Example, the Iwaki MD-70RZ has 16 meter head but
sells for AU$500. The etchant I'm using won't effect stainless steel.
Re: [Homebrew_PCBs] pump for spray etching
2003-09-30 by Stefan Trethan
why not build the rotrary spray etcher?
it sed only a plastic pipe, with holes for spraying on the upper part.
high speed driven by a motor on top of the tank.
we discussed this here a time ago...
st
On Tue, 30 Sep 2003 15:00:39 +1000, Adam Seychell
> I'm looking at building a spray etcher on the cheap, but I cannot find a
> suitable pump. Pressure requirements are fairly high for sprays nozzles
> to work effectively. The pump must be capable of at least 10 meter head
> (1 bar), but all low cost fountain pumps are rated no more than 4 meters
> head. Getting hold of a pump is the killer. Example, the Iwaki MD-70RZ
> has 16 meter head but sells for AU$500. The etchant I'm using won't
> Be sure to visit the group home and check for new Bookmarks and files:
> Homebrew_PCBs-unsubscribe@yahoogroups.com
2003-09-30 by Markus Zingg
I agree with Stefan that building a rotary kind of spray etcher is
most likely a lot easier. I do have one that I boght a while ago. I
first was happy, but over time it turned out that it does not create
reliable reproduceable results. That's however not due to it's
principle of operation but more because of some bad ideas on behalf of
the manufacturer.
I created a little homepage for you showing pictures of the
(depreciated) etcher I have and most importantly a little video of the
MUCH better Bungard spray etchers which should give you some good
ideas on how to build your own.
www.myhome.ch/mzingg/pcbstuff
Markus
May i add that if you don't get enough pressure for spraying
due to centrifugal force it may be a good idea to add a small
"pump" to it.
(my suggestion is a fan wheel from a small dc (computer) fan on the bottom
of the pipe).
i did some experimenting with a pipe and a power drill and you really need
a lot
of rpm to get something spraying. maybe a turbo wheel makes it easier.
i think the result may not be uniform, if rotated with constant angular
velocity
the middle of the board is sprayed more intense...
maybe two sprayer tubes or so..
i think for fe3cl etching it is a good idea..
but i did not further think about it when i found a cheap source for h2o2,
for me
etching in a tray and chemical regeneration of hcl /cucl is much more
convenient.
what do you want to spray?
stefan
the video is cool! must be old?
he takes the board out with bare hands... nice yellow hands if he makes
this often ;-)...
but it sows some nice features, the lid dripping back in the jar is a good
idea.
the "power chord lock" is nice too (i wouldn't implement...).
> the manufacturer.
> Markus
Thanks for the pointers to the rotary pipe etching machine.
I would agree this machine looks mechanically simpler and
cheaper than a oscillating spray nozzle type etched. I did
have a suspicion that this may not give a totally uniform
etch. From what the experts say about spray etching (or any
cleaning) is the impact velocity of the liquid is what does
the real work. Currently I have a bubble etched and it does
not produce reliable etching. Despite many different
arrangements of the air sparger I have tested, I found only
a limited etch uniformity can be achieved. The second
problem is etch undercut of the tin plating resist. The
boards I'm making use the pattern plating process, where tin
metal is plated on the tracks to act as a etch resist in a
ammonical type etching solution. The tin overhangs the track
a small amount and then breaks off creating slivers of tin
and potential short circuits. I scrub the boards with a
stiff nylon brush to remove the tin slivers.
Going by what a couple of professionals have said and also
from someone who built their own hobby spray etching
machine, is that spray etching is the only way to get
uniform etching and minimize etch undercut.
I had some thought on the spray etcher design. I was going
use some 20 mm PVC pipe and 4 pipe elbows to make up a
rectangle frame which fits internal to the tank. A flexible
rubber hose connects the pump outlet to the PVC pipe at some
point where etchant is pumped in. Four spray nozzles are
also fitted to the rectangular pipe frame such that they
spray inwards to the center of the tank. The PCB will then
hang vertically in the center of the tank and the PVC
rectangular frame will sit horizontally and oscillate up and
down spanning the PCB height. The mechanism to drive the
oscillating rectangular frame will consist of eight pulleys,
one at each inside corner of the tank. A cord will run
passed the pulleys so when they rotate there are vertical
cords moving at all four corners at the tank walls. The
rectangular frame is attached to the vertical cords so it
moves up and down as the pulleys rotate.
A DC motor mounted outside on the tank lid will drive the
inside pulleys via a belt. Two small holes in the lid will
be needed to pass a drive belt.
These nozzles are about AU$10 each
http://www.bete.com/metric/products/pages/spn.htm
I haven't yet found a solution for the pump.
Adam
> the manufacturer.
> Markus
2003-10-01 by Markus Zingg
Hi Adam
>the real work.
Acording to Bungard the etching process of THEIR machines is total
uniform - as oposed to the (el cheapo) machine I unfortunately first
bought. I must admitt though that I don't have first hand experience
with their machines. As soon as time permits - that's currently a bit
a problem :) - I will take a closer look at this. I may end up buying
one of those Bungard machines but we will see.
I totaly agree on this one. IMHO serious (fine artwork) kind of PCB's
can't be etched with those. I had one myself but it's sitting on the
shelf now.
>The second
I agree here too, but I think that the rotary principle is suffiently
good to do this. Again, I can't proofe this at the very moment.
This sounds like a good concept (and thanks for the pointer to the
nozzles). Please keep us up to date on your progress. Etching is
really the only step left here that does not work too well at the
moment. (I'm actualy currently "hand etching" by moving the PCB within
the Fe3Cl bath by hand up and down for 20 minutes and that's really
tedious. The "advantage" of this method is that I can control where
and how fast it etches within some reasonable degree with different
kind of moving the board but again - it's a pain...)
Yes, I figure this is getting difficult. Have you ever considered
building the pump also? I was thinking about having a PVC tube formed
as a circle and then some kind of rotor equiped with little wheles at
the ends to minimize friction that squeezes the tube thereby moving
the liquid inside the tube. I remember that there are pumps that
operate this way used by RC plane modelists. I have no clue though if
it's feasable to build one of those that is delivering the pressure
needed.
Markus
>Adam
>> the manufacturer.
>> Markus
RE: [Homebrew_PCBs] pump for spray etching
2003-10-01 by Marty Grove
Chemcut is once again making their tabletop, conveyorized etching /
developing system. It has oscillating spray, a rinse station after the
process chamber, and several other features.
I've got some data on these machines, and if anyone wants this information
I'll be happy to email it. Please contact me directly (don't want to
clutter up the discussion list) by email at martygrove@... and give
me an email address to send it to.
Take care!
Marty
2003-10-01 by Stefan Trethan
@markus:
i think your pump principle is like those medical "silicon hose rotrary
pumps".
they are used for pumping blood and other liquids.
the advantage is the silicone hose can be replaced easily, making
sterilization
unneccesary, the expensive pump motor, casing etc. is reused...
i have no idea where a rc plane builder may need such a pump (i'm kind of
involved
in that now...). maybe for tank refueling on glow engine planes (i only use
electric power).
but i think this is not a pump for spray etching, it it a slow pump.
what pump i suggest:
it is not too hard to build a centrifugal pump.
you can look for small aquarium pumps too.
if you get a EHEIM pump (look at pc watercooling supplys)
you may isolate the permanent magnet with thick laquer and that's it.
it uses ceramic shaft, all other things are plastic i think (only the
permanent magnet rotor not).
these are very good pumps and i think they would be well suited.
(the winding is totally encased in plastic)
(i cool my pc with it, so i know it... you can't hear these pumps from 1
meter away...)
another option is to build the pump immersed in the etchant.
the shaft goues up to the top and there is a motor mounted.
use a plastic shaft or a (expensive) metal which is not etched.
would be very easy to build from a small centrifugal pump where you simply
take the motor out.
do not try to use any commercial pump which uses some kind of sealing like
a stuffing box.
the etchant will get through and corrode the motor.
the centrifugal pump is not very critical design, only needs a balanced
rotor.
(easiest is taking one from another pump).
piston pumps are difficult to keep sealed, with metal in the etchant.
st
Re: pump for spray etching
2003-10-01 by Dave Mucha
The term is Peristaltic.
"produced by the successive contraction of the muscular fibers of
their walls, forcing their contents onwards; as, peristaltic
movement. "
This style pump offers dosing or low volume delivery of the fulids in
question. Commercial dishwashers use these for soap.
Not really high pressures, but higher than some other styles.
Aquarium pumps can only deliver a very low pressure, nothing near
what is needed to use a spray nozzle like the link listed, not even
close. They are designed to move liguids in a tank, not create
pressures in a pipe. However, some other spray nozzel would be
possible, more of a flooding, dripping than a pressure washing.
IF, chemical action was increased by new etchant and not by pressure,
then a fish pump might work.
Small chemical pumps are hard to come by, but you might try one of
the professional spray systems for a parts replacement. Maybe you
can get them to send a data sheet so you can figure out what the pump
is like ?
Dave
--- In Homebrew_PCBs@yahoogroups.com, Stefan Trethan
<stefan_trethan@g...> wrote:
> @markus:
rotrary
> pumps".
> sterilization
kind of
> involved
only use
> electric power).
it.
from 1
> meter away...)
simply
> take the motor out.
sealing like
> a stuffing box.
balanced
> rotor.
etchant.
> st
Re: [Homebrew_PCBs] Re: pump for spray etching
right that therm is for what i thought of...
the aquarium pump are really not too strong...
i didn't think about that. maximum pumping height only 3 meters..
(means 0,3 bar, and maybe only a drop a minute volume at this height ;-))
still i think a centrifugal pump is what to go for.
(maybe making more nozzles for more volume but less pressure).
take a plastic pump apart (some cheap underwater garden pump or so).
they have a plastic pumping wheel (and case) - get the cheapest to be sure
it is plastic.
exchange the shaft with a non-etched material and make it longer.
then use the motor from the original pump to drive the (new) shaft which
stands out
the top / top of the side of the tank.
these pumps can easily supply the volume, and at this volume also enough
pressure for a good jet...
st
On Wed, 01 Oct 2003 13:15:01 -0000, Dave Mucha <dave_mucha@...>
> "produced by the successive contraction of the muscular fibers of their
> walls, forcing their contents onwards; as, peristaltic movement. "
> Aquarium pumps can only deliver a very low pressure, nothing near what is
> needed to use a spray nozzle like the link listed, not even close. They
> are designed to move liguids in a tank, not create pressures in a pipe.
> However, some other spray nozzel would be possible, more of a flooding,
> Small chemical pumps are hard to come by, but you might try one of the
> professional spray systems for a parts replacement. Maybe you can get
> them to send a data sheet so you can figure out what the pump is like ?
> Dave
>> @markus:
> rotrary
>> pumps".
>> sterilization
> kind of
>> involved
> only use
>> electric power).
> it.
> the
> from 1
>> meter away...)
> simply
>> take the motor out.
> sealing like
>> a stuffing box.
> balanced
>> rotor.
> etchant.
>> st
>pumps".
>sterilization
>involved
>electric power).
Yep, tank refueling is what they are used for.
Would that not change if a motor is used? The tube could have a
dameter of say 1/2" and this would transport quite a bit of etchant in
a short tim - no? I can imagine that such a pump could do but then I
don't have experience with pumps. It just apealed me because they seem
to be easy to build and - based on their principle of operation they
of course also would resist the etchant.
Markus
but you need to fully compress the hose.
otherwise the liquid flows back in the gap left open.
would be hard with thick hose to fully compress (and have it expand
afterwards).
or do you think of a pump that uses one way walves and does not fully
compress the hose?
(bellow or membrane type)
i just had another idea.
if dry compressed air is availabe it would be easy to make a venturio pipe
pump.
(the principle of bottom-tank color spraying or water vacuum pump)
is simple, no moving parts, very high pressure, but you need to release the
air blown in again...
(without propelling fumes out).
stefan
>> pumps".
>> sterilization
>> of involved
>> use electric power).
> Markus
2003-10-01 by Russell Shaw
> movement. "
They're also used in inkjet printers for head priming/cleaning.
in
> Markus
A larger tube could be used, and that would offer more volume. means
a bigger motor, that may not be a problem.
I didn't like compressed air as that creates a potential disaster.
one possibility is to fill a pressure tank, pressureize it and spray
one batch. re-fil and spray again. would require a couple gallons
to get a few minutes of spray. But the hazzard potential increases
drastically.
Dave
2003-10-01 by Steve
Using larger diameter silicone tubing means it isn't hard to fully
collapse the tube for a peristaltic pump. And you always use 3 ball
bearing rollers, can't just rub. A geared surplus DC motor or a
stepping motor should work for this.
To maintain pressure you could have a small reservoir tank. Sealed,
with air inside. If you pump until it is half full, you've got 1
atmosphere of pressure. You could even rig up a few photosensors to
control the speed of the motor to regulate pressure.
I was thinking of a pump idea for something else that may work here:
Two one way valves (those little rubber ones you can get from a pet
store for aquariums) rigged to a cavity. One wall of the cavity is a
rubber membrane with a small woofer sealed to it. Not -quite- airtight
so barometric changes don't bottom out the woofer. Experiment with a
signal generator and find the best pumping frequency when it is
pumping fluid.
No idea how scalable that is or if it would provide sufficient
flow/pressure. Maybe the outlet oneway valve could be exposed and it
would spray out of that with sufficient flow (I'm talking about the
ones that look like a flattened baby bottle nipple).
Since the woofer has a back, too, potentially you could make a
doublesided pump. Otherwise all that energy just goes into making your
workshop noisy. Then you could seal the woofer in completely as
barometric changes would make no difference, and rely on slow
diffusion through the cone to keep pressure equalized across the woofer.
There, I just gave away a good idea I probably should have kept to
myself and developed, and offered for sale. :'/
Steve Greenfield
What you describe there is a simple membrane pump.
thousands sold each year (a lot of them for air pumping).
i tried it with a speaker @50hz, speaker diameter about 12cm.
the membrane hat to be sealed (used silicone).
with air id did make some suction (wanted it for vacuum-bag lamination).
but not very much, very low efficiency. (@50hz)
(membrane pp amplitude was 5mm - then it smoked, stopped to move and i
discarded it ;-))
i don't think this makes a good fluid pump, the liquid would drastically
reduce the
maximum operating frequency/ resonance point, and the coil in standard
woofers is for moving air
not 2 bar water or so....
the membrane pump is well known, well used, but i can't remember having one
seen for liquid.
i'm still not sure if a perestaltic pump would be easy to make big, i have
no hose
which can be compressed to zero gap and fills itself afterwards (only by
gravity).
and also i think the stress put on any hose to compress it so much at the
edges
is not good over time.
another possibility might be a bellow pump, same prinziple loke a piston
pump
only the varying volume is accomplished by a rubber/plastic body which is
compressed.
(in principle steves membrane pump is same but with a much larger
amplitude, much lower frequency.)
st
> rubber membrane with a small woofer sealed to it. Not -quite-airtightso
> pumping fluid.
> Steve Greenfield
Regenerate Natrium Persulfate
2003-10-01 by Radek Zitek
I have tried to use the natrium persulfate (Na2S2O8) for etching and
remember reading somewhere that it can be regenerated. Any pointers
where I could find more...
Thanks, Radek
2003-10-01 by Zoran A. Scepanovic
Hello Stefan,
01. October 2003, 15:56:05, you wrote:
ST> but you need to fully compress the hose.
ST> otherwise the liquid flows back in the gap left open.
ST> would be hard with thick hose to fully compress (and have it expand
ST> afterwards).
ST> or do you think of a pump that uses one way walves and does not fully
ST> compress the hose?
ST> (bellow or membrane type)
ST> i just had another idea.
ST> if dry compressed air is availabe it would be easy to make a venturio pipe
ST> pump.
ST> (the principle of bottom-tank color spraying or water vacuum pump)
ST> is simple, no moving parts, very high pressure, but you need to release the
ST> air blown in again...
ST> (without propelling fumes out).
ST> stefan
And I replied:
For more details on operation principle, max flowrates, max pressures on
peristaltic pumps (the ones that are using rollers combined with silicone
or other tubing) visit thye following site: www.masterflex.com
My small business is the maintenance and repair of various medical
equipment and I can assure you that no liquid is flowingback!
Best Regards,
Zoran
mailto:zasto@...
[Homebrew_PCBs] Solder paste refolw - why to preheat
Hi
I finally could convince myself to buy a steinel heat gun (the good one
with lcd and feedback controller markus suggested). It is a good unit and i
searched the web for some information on reflow soldering (repair with heat
gun etc.).
So i found the following, if you are interested in reflow, either hand
applied or oven, read this:
http://www.howardelectronics.com/desoldering_update.html
it says why the preheat is needed (vaporize the solvent in soldering paste
BEFORE solder melts
or you end up with small "explosions" and drops over the board).
it also shows a chart for reflow temperature over time (helpful for making
a oven).
the total soldering time is about 6 minutes.. i did assume a much shorter
time (if you take the 3 seconds stated in the most datasheets).
Maybe this is because the part is only over the critical temperature for a
very short time, not the whole
6 minutes, maybe there are other reasons. anyways i find it very long.
stefan
Hmmm, seems like the page is down or such? I can't access it from
here. Could someone confirm that the page is working?
Markus
On Wed, 1 Oct 2003 21:38:32 +0200, Zoran A. Scepanovic <zasto@...>
wrote:
> Hello Stefan,
i see.. there are units which can handle the flowrates. (but look at the
price..)
anyways.. you can't do this with some old garden hose.
these are special tubings which are constructed for compressing them tight.
maybe only buying the tube is within homebrew price range... not sure..
making a motor with rollers should be possible....
thanks for the link...
stefan
no but i can confirm it was already partially defect when i had a look.
no access to tubing, but could see pumps...
have a good night...
>> on
>> silicone
> Markus
Re: [Homebrew_PCBs] Regenerate Natrium Persulfate
2003-10-02 by Adam Seychell
Na2S2O8 (and other persulfate salts) are produced by
electrolysis of almost saturated Na2SO4 + sulfuric acid at low
temperatures (~0°C) and very high anode current densities. The
Na2S2O8 produced at the anode is less soluble than Na2SO4 and
thus collected as a precipitate.
I doubt it would be worth your while regenerating spent
persulfate etchant on a small scale. There are other
regeneratable etching chemistries to play with.
> Thanks, Radek
2003-10-02 by Steve
> discarded it ;-))
Phew, I don't feel so bad then.
I wouldn't expect a diaphram style pump to be very good at pulling a
vacuum.
Steve
What is the price of the Bungard etching machine ?
> shelf now.
Yep. :)
If you end up buying the machine please keep the group informed
on how well it works. I would be very interested to know.
> nozzles).
I actually put the wrong link to the nozzle. It should be
http://www.bete.com/metric/products/pages/nf.htm
At the moment I'm looking at getting a total of 6 x NF10 with 65
degree fan angle and in 303 stainless steel. Just confirmed the
price at AUD$10.45
Because its an alkaline etchant I'm allowed to use stainless
steel. Let me know if you want to know more details on the
etching chemistry. It is electrically regeneratable.
See http://www.elo-chem.com or google search "elo-chem"
> moment.
Yep, I know what you mean. Once you get everything else working
great, the quality of the etching step suddenly becomes an issue.
> as a circle and then some kind of rotor equiped.....
I know the pump your talking about. I read all the other replies
too. It appearing that the only pump to use is the magnetic drive
centrifugal pump. The one I have in mind is the MD-70RZ(T), see;
http://www.iwakiwalchem.com/iwaki/literature/Specsheets/MD5570100.pdf
My uncle is a sales rep for Iwaki pumps, so if he will discount I
will seriously think about taking the plunge.
According to the graph it should pump 20 L/minute at 1.5 bar.
Using this information the nozzle type can be calulated.
The challenge now is to design the spray nozzle configuration so
it etches uniformly. I've been told there is no simple solution
for working out all the variables. There are things such as the
number of nozzles, nozzle to nozzle spacing, distance from the
panel, amount of overlap of the spray pattern, the fan angle, the
jet incident angle to the panel, the linear sweeping speed of the
jets, ect. Its one of those things that you just have to play
with until you get it right. I might have to buy some cheap
phenolic copper clad to experiment with.
Adam
2003-10-02 by Markus Zingg
Hi Adam
The MK2 costs EUR 249
the Turbo EZ is EUR 437 and
the Turbo DZ is EUR 550
I haven't made up my mind yet wether I'm going to buy one of those or
not. I'm currently held busy elsewhere and will get back to this topic
and a decision as soon as time permits. I mean building one myself is
also going to cost money so the result of a homebuilt one either would
have to be better or then I must be sure that time and money will
result in a lower price (which based on the exeperience with building
the through plating machine I somehow doubht).
>> shelf now.
>Yep. :)
Will do so.
>> nozzles).
>price at AUD$10.45
>> moment.
>Adam
The biggest chalange with home built machines that you design yourself
is (IMHO) that you always must take the risk of buying parts to just
try if it works out well and there is some (not so low) percentage of
stuff that you buy where you end up with the conclusion that it does
not work well hence the money for it is most often lost. It's quite a
lot easier to build something after plans or such based on other
peoples experience than develop all by yourself although the latter is
undoubtly much more fun.
With regard to the rotary spray etcher I really somehow doubht if it's
worth the effort to design one bymyself because the prices - although
not really cheap - are still in a range where building one myself
could turn out to be a bad deal. This was very different with the
through plating machine where nothing in a compareable pricerange (and
quality of course) was available. This statement is however not really
related to your plans of building the kind of machine you are thinking
of cause I do agree that this machine will be much closer to what they
use in professional board shops.
Markus
Re: [Homebrew_PCBs] Re: membrane pumps
2003-10-02 by Stefan Trethan
>> discarded it ;-))
> vacuum.
> Steve
they are used for desoldering vacuum pumps (the pistol type with a tip with
a hole).
(for desoldering about 5cm diameter and 50hz frequency (maybe 100), no idea
which amplitude)
also for smd vacuum holding i have seen a membrane pump.
it is not a bad concept - cheap, no parts to be sealed..
but i think it may be because of the weight, thus the resonant frequency,
why i have never seen one for liquid. let me know if anyone has.
the speaker pump i built would have been enough for smd holding. membrane
pumps are cheap to get for aquarium air agitation.
but if you ever need a good cheap vacuum/compressed air pump get a used
fridge compressor.
run it some time to remove most oil and for pressure air build a dry filter
(paper towels or cloth)
to filter oil mist.
if you want to use the vacuum side you need to add a valve, from powering
the pump until vacuum is
formed it takes some time (not so with pressure, this is almost instant).
this can be a very nice vacuum generator for the desoldering iron (if you
add a valve to the handle).
(it is no high vacuum generator for evaporating a electron microscope! no
idea how many mmHg
but i testet it with water and 3 meters were no problem (the room was only
3 meter...))
stefan
2003-10-02 by Jan Kok
I wonder if a paint sprayer would work? Problems to solve:
- The paint sprayer plumbing and nozzle would have to withstand the
etchant.
- Air compressors generally produce some oil mist. That would have to
be filtered out to avoid contaminating the etchant. A section of pipe
in the air line filled with cotton ought to work.
I have seen a couple shops in universities that etch boards using
several gentle streams of etchant flowing onto the PCB. The streams are
shifted left and right, while the board is raised and lowered. Do these
not work well with fine geometry artwork?
Cheers,
- Jan
2003-10-03 by Adam Seychell
From the prices you listed, it seems the MK2 etching system
costs about the same as the MD-70RZ pump I'm looking at buying
for the spray etcher. To decide if it is worthwhile building a
spray etcher using this pump then it will have to be perform a
lot better than the MK2 machine.
I understand your arguments on home built machines. From my
experience I believe in general its not worth your time and money
building something yourself if it is already commercially
available and all you are interested in at the end of the day is
something to do the job. As you mentioned there are other risks
with home build equipment, like the finances of reiterating
designs before having something finally workable. There is a
learning curve which may or many not be enjoyable for you. It
sounds like you have also had some disappointing results with
some past projects. I can tell you I've had my fair share of
disaster projects. I'm almost too embarrassed to mention them
all, and would hate to think the amount of money I've wasted over
the past three years. I cannot tell you whether you should buy
the rotary spray etcher since I'm unfamiliar with its concept. If
you were to make one then I would recommend using the spray
nozzle/pump approach because it is a more proven method of
etching PCBs. I am still pondering over the design so it can be
constructed with minimal effort, which is the aim. My reasons for
build my own spray etcher are;
* I have enough evidence to show a well setup spray etcher gives
the best quality etching.
* Commercial spray etchers (not the rotating tube type) are many
times more expensive than the cost of parts to build my own.
* Based on the things I've learnt from building other chemical
processing equipment, this does not look like an extremely
complicated project.
* I enjoy tinkering in the workshop and creating things.
* I am not time constrained.
When I have something working I will publish the construction
details on my web address for anyone else who is interested. I
get the feeling there aren't too many fanatics like you and me
out there who will actually be silly enough to attempt home
brewed through hole plated PCBs :)
Adam
those or
this topic
myself is
either would
building
yourself
to just
percentage of
it does
quite a
latter is
if it's
although
pricerange (and
not really
thinking
what they
> Markus
and files:
2003-10-03 by Markus Zingg
Hi Adam
That's exactly the point, and the dilemma is that without trying the
MK2 (or which ever of these) it's impossible to tell.
Yes, I completely agree here. However, as you also tell later on spray
etchers, as you intend to build one, are only available at hilarious
high prices so building one of those on your own DOES make sense IMHO.
The learning and building is undoublty much fun. It's just that if you
have a limitted budget it may means that the "project" get's much
delayed because you may have to wait another two months to convince
your wife that those $300 now have to be spent :))
> It
>some past projects.
No, the through hole plating machine is far away from being
disapointing. It's actually a great project and even though I had to
pay more for it than someone just building it after my design it's
worth every penny I spent for it.
I never start a project before I'm sure that I can complete it. It's
just that sometimes you end up buying 70% of the material needed twice
- and that can get costly :)
Well, for a real homebrewer things are usually not that bad cause
those "wrong" materials turn out to be the right ones in a (sometimes
years) later project.
As mentioned before, I do have such an etcher already from "Radix" but
this one was not constructed with enough care and therefore the
results are sometimes brilliant, sometimes however disaterous and
there is no recognizeable pattern why. In other words, even if I
exactly measure the times, asure the same setup - well even the same
PCB is in there the results differ a lot. The machine is nice for not
so fine artwork but that's not what I use most often. However, the
principle seems to be ok.
>If
Ack, I completely agree that if the effort to build one is made it's
better to aproach a better concept than those that are comercially
available at this price level.
That would be great cause I'm sure I could save alot of money :) What
I would achive thought is to have an etcher that run's based on Fe3Cl
- hence the nozzels may would have to be made of plastics or such. I
have still multiple pounds of Fe3Cl on stock here which I happened to
buy in a not so bright moment - so using it up is of some importance
to me :)
Could you elaborate a bit why you are using the etchant (I did not
catched which one) you are using and where the specific advantages
are?
> I
>Adam
That's in fact true. Since I have my page about the through hole
palting machine online ~3 people asked detailed questions but I did
not got the impression that any of them really started to build one.
There is one exception though. A friend of mine will build one
although he already have a comercial one (he's not too happy with it).
However he currently must finish his military training thus he's out
of the loop for some months to come.
It's somehow hard to understand cause in the longer run it's even a
lot cheaper than having PCB's made externally - hmm, did I mentioned
on this list already that I meanwhile managed to also create
multilayer PCB's? I mention it in this context cause a 4x4" four layer
PCB costs me ~$13 a double sided one of the same size ~$8 quite hard
to beat IMHO. Especially if you consider that you don't have to wait
for them to be made etc. (creating this 4-layer PCB lasted 5 hours
only!) I'm even more surprized that engineering firms etc. which
obviousely do have a need for many prototypes don't use this option.
But well, it really seems that it takes a fanatic one to do this :))
Markus
>those or
>this topic
>myself is
>either would
>building
>yourself
>to just
>percentage of
>it does
>quite a
>latter is
>if it's
>although
>pricerange (and
>not really
>thinking
>what they
> > Markus
>and files:
Plated through holes and multilayer boards?
2003-10-03 by Jan Kok
Markus, and others who have done these things on a limited budget:
Would you please describe your process, or provide a pointer to some
such description on the web?
I have made a few small double sided boards using photosensitized
boards, but haven’t attempted PTH’s or multilayers.
I have heard of a product that might be of use in making multiplayer
boards: There are thin sheets of copper on some sort of insulating
backing material. The sheets are thin and flexible enough that they can
be run through a laser printer. (Small pieces can be cut out and taped
to a full-size sheet of paper before sending through the printer.) The
laser toner protects the copper, so the copper sheet can then be etched
immediately. I read about this product and how to use it in a hobbyist
electronics magazine around 1995. Some hobbyist supply company offered
to sell small quantities of the material. The cost for ten 8 ½ x 11
inch sheets was less than $100 – maybe much less, I don’t remember.
- Jan
Water soluable flux
I recently had a chance to use some solder (intended for electronic use)
containing water-soluable flux. That stuff is wonderful! It solders
just as well as rosin-core solder. What is so great is that the flux
can be removed very easily by just rubbing gently with a water-soaked
paper towel. The flux should be washed off ASAP (within about four
hours of soldering) to avoid tarnishing the copper traces and solder
joints.
There are also water-based "flux pens" that look like felt-tipped Magic
Marker ink pens, that can be used to apply flux to the PCB. This is
especially useful for soldering surface mount ICs.
Enjoy!
- Jan
Re: [Homebrew_PCBs] Plated through holes and multilayer boards?
Adam and I both have independantly developped a through hole plating
setup. I can't tell much about Adam's (I figure though he will give
you informations) but I do have a page set up that showes the station
I built on my own.
www.myhome.ch/mzingg/pcbstuff/tps
The pages are not absolutely up to date but should give lot's of
information. With my "apraoch" the key point to understand is that I
do not mix my chemicals "on my own" but use the same chemistry as it's
deliverd to board houses. I have mine from Bungard, but it seems like
they have it from "J-Kem International" (who ever this might be). I
don't care cause those huge firms usually don't deliver small enough
quantities as Bugnard does. Another way might be to contact a board
house and ask if they mey sell some of their chemistry. I figure they
may do once they understand that this is about hobbyists use etc.
The remaining part then is to create the tanks and the electronics
needed for agitation and mainly for the electrolytic process itself.
Once these "investments" are made, producing throughplates PCB's
becomes very cheap, painless and fast. All you need is copper clated
material and of course laminate. There is thin copper clated FR4
material available also at reasonable prices. I use 0.5mm for the
inner layer and 0.3mm for the outer layers in case of a four layer
board thereby getting four layer board of the same thinkness as those
made by boardhouses.
The process is not that different from creating double sided PCB's in
that you first laminate, expose and developp and etch the inner layer,
then glue the outer layers onto the two sides. Then you drill holes
(not before this) so as the drill goes through the copper of the inner
layers at those places where it should (the layout must be made so as
the pads don't have holes). If you then through plate this "stack" the
outer surfaces are conneted to the inner layers whre they should. From
this point on there is no difference in createing a double sided PCB,
that said you simply laminate the outer layers, expose and developp
and etch it.
A key point is aligning the layers. I do this with two special
diagonaly psoitioned holes of 3mm diameter that I drill through all
the layers as the first step. The films I use to expose also get those
holes. My english is unfortunately not good enough to describe how I
manage to create precisely positioned 3mm diameter holes into the
films but I "stamp"? them out using a little tool I built by myself.
To create this tool I used 3mm diameter silver steel and used a center
drill to drill a hole into one end. This results in a very sharp edge.
Anyways, once the holse are within the layers and the films, all can
be precisely alligned using 3mm sized pin's. Since I do not have a CNC
drill yet (well, I'm in the process of building one myself but since
I'm currently held busy with other stuff it's laying around for some
months now) I'm actualy laminating a layout to one of the outer layers
at an early stage using a film where the holes of the vias and pads
are not covered. This laminate get's then only exposed and developped
and then serves as a help in hand drilling the holes into the propper
places. Btw, this method of using pin's works so nicely that I also
use it for double sided PCB's to alling the film which before always
used to be a bit trickey.
An important thing is also the glueing. It's very important to make
sure that glue is everywhere and that there are no air inclusions
between the layers. I asure this by glueing both sides in one shot,
applying the glue to the INNER layer only and by only applying a
fairly thinn layer of glue (2 components glue that dryes in 5 minutes
from the hardware store is fine. I.e. 5 min epoxy or similar). The
reason why I apply the glue to the inner layer is that it's structured
by the artwork and by doing so it's obvious that those parts without
copper get enough glue so as there is no air at those spots later on.
After having applied the glue to the inner layer, I position the outer
layers again using the two 3mm pins and apply as much pressure as I
can. I created a little wooden construction for this purpose that
holds two vices positioned in such a way so as I can apply pressure to
an as big area of the PCB as possible. Of yourse, during this process
the PCB is covered by two wood pieces so as it does not get scratched
or bent by the vices and also to more evenly apply the pressure.
That's mostly it. It sounds a lot more complicated than it actually
is. In fact the key point is to have a through hole station. The very
same principle can be used to create 6 layers or more. The only
difference is that you have to glue twice. The holes are however
always only drilled after glueing the most outher layers.
If you also apply a solder stop mask to the outer layers (I do have
one that can be laminated, exposed an developped - again Bungard is
your friend) the look and feel of such a PCB is identical to one made
by a board house. Since I most often use this only for prototypes I
don't apply solder stop mask very often but it works quite well.
I figure you are in the same boat as most homebrewers here then.
I never heard of such a product, but IMHO $100 for this size is way
too much. For that price I would have my boards made by a board house.
As stated in my other post, I have a hard time to understand why
people seem to be so shy of using this aproach. Hey, it's nothing more
than 5 tanks with chemicals in them - really no rocket sience to just
use it this way.
Markus
2003-10-04 by Ron Amundson
Sent: Wednesday, October 01, 2003 4:54 PM
Subject: Re: [Homebrew_PCBs] pump for spray etching
Markus
It is down at the moment. They probably do sometime of system maintenance Friday evening. A friend of mine used to work for them. I asked about getting a free pump for pcb etching, and he said that the flow rate would be way too low so I never pursued it.
Ron
Re: Plated through holes and multilayer boards?
2003-10-04 by roel_cnc
Hi, Markus
I am also a homebrewer and like to handle the PTH thing also myself.
Got on this moment only two questions:
1: the cuvets (fluid units)where they made off and how they glued
together (type of gleu)
2: chemical 1# part, is it electroless chem. cu. because some systems
use a pasta
if it is possible the names of the chems.
i already use dry film - spray etch and cnc drilling and works for
several years now .
many greatfull thanks in adv.
Roel
--- In Homebrew_PCBs@yahoogroups.com, Markus Zingg <m.zingg@n...>
some
station
> I built on my own.
it's
like
they
those
in
layer,
inner
as
From
PCB,
> and etch it.
those
center
edge.
CNC
layers
developped
propper
minutes
structured
on.
outer
to
process
scratched
very
made
> >boards, but haven't attempted PTH's or multilayers.
multiplayer
they can
taped
printer.) The
etched
hobbyist
offered
11
> >inch sheets was less than $100 – maybe much less, I don't remember.
house.
more
just
> use it this way.
> Markus
Re: [Homebrew_PCBs] Re: Plated through holes and multilayer boards?
2003-10-04 by Markus Zingg
Hi Roel
>Hi, Markus
They are made from "hobby glas" and basically are made with a hot air
gun and a circular saw. I used 2mm sheets sized 1.2 x 0.5 meter. For
the five tanks - also calculating your first attempts to get the
weldering under control - I recommend you to buy ~8 sheets. There is
no glueing involved, but I weldered them using plastic stripes first
cutted of from the material. On the link I gave - under closeups - you
can see them fairly well on the "The machine put in parts" picture.
There you can also see the frame into which the tanks are simply
inserted There is some learning curve involved with building them, but
the third or fourth attempt is likely to work our right. I basically
first cutted out a stripe of the material that I bent (using the hot
air gun) to a U shape. Then on each side of the U I weldered another
stripe. The U shape aproach is having the advantage that you only have
to welder on two sides and the side parts also form a good stand for
them if you ever need to take them out of the machine or such.
>use a pasta
I honestly don't fully understand this question. Again, the chemicals
are from Bungard. It's the "entry chemicals set" for their "Compacta
30" throughplating machine (which is btw. in a completely different
league than my machine - IMHO ~8000$). This set is reasonably priced
and because the Compacta 30 operates with 15 and 30 litter tanks as
oposed to my machine (2 and 5 liters) the chemicals obviousely last
longer. Everythnig (chemical wise) is included in this set. I also
ordered replacement Anodes for this same "Compacta 30" model cause
they are well suited for my machine also. I can send you a pdf
describing the baths a bit more closely but there is of course no
chemical formula or such available. It tells you how to prepare the
baths but again, no deatils about the formula or such. These baths
reflect years of experience of those firms makeing them and such
detailed information is treaed as a trade secret.
>several years now .
Well, then a trhough plating machine obviousely forms a nice
enhancement of your equipement.
You are welcome.
Markus
2003-10-04 by Adam Seychell
> several years now .
How do you apply the dry film ?
I have been applying dry film with a wetted hand roller, see:
http://groups.yahoo.com/group/Homebrew_PCBs/message/2709
And I'm really interested how you managed to get a spray
etching machine for home use, and would also be curious in
the concept of its design. ? I am in the process of
designing my own.
Adam
dry film and laminator
2003-10-05 by roel_cnc
--- In Homebrew_PCBs@yahoogroups.com, Adam Seychell
<adam_seychell@y...> wrote:
for
> > several years now .
not with (boiling)water - it wolnd be a dry film anymore :)
I used in the past a aloy plate aprox. 30 mm thick and build a heater
from a washing machine:) in, and a thermo unit from an oven to
control temp.(+/-100 C.)
clean the board putt the film on and lay it on the heated element-
instant roll with a soft one over it pressing hard off cause.
i still use this for the soldermask dry film part
the resist (new way) i use this moment parts from an big copier
silicon roll with heater inside - works awesome.
remember there are 2 sorts off film the resist and soldermask ive got
from both 2 rolls 25 meters eatch as samples :)
> designing my own.
the spray etcher i build has on both sides a ring off pvc pipe (used
as air-pressure tube in factory's) with nozzles from a carwash unit.
just washing your car sometimes with the right wrench :) wil do.
same unit for development but cheaper pump
the pump is the most expensive part off all got some docs somewere
around - and dont forget a real pump use atleast 1 to 1,5hp motor
but i still love my bubble etcher the best there is fast and always
perfect for single runs
please excuse me english
greatings from holland
Roel
> Adam
Re: [Homebrew_PCBs] dry film and laminator
2003-10-05 by Adam Seychell
> for
>>>several years now .
Roel,
What type of etching solution do you use ? I assume
everything is plastic, including the nozzles. A 1,5hp pump
definitely is a good size. I was thinking of using more like
1/4 hp centrifuge pump. to give 1,5 bar at 20 liters/minute.
That should be enough for a single sided spray etch with
sweeping spray nozzles. Does the spray oscillate in any way
or is both the PCB and the spray stay still during the
entire etching time ?
I do not have any solder mask material yet. Does the
soldermask you own work by photo imaging ? If so then does
it also develop in 1% sodium carbonate ?
Re: dry film and laminator
the pcb oscillate about 10 cm
10 nozzles per side makes 20 off it
volume off etch is about 25 liters
i use the fe3 the brown fluid.
the soldermask works the same way - only after developing extra uv
cure and after that an oven cure for 60 min at 159 C if you can get
the same film (dynachem laminar DM)
gr. Roel
i got lot off documents about the chems for plating and
Re: [Homebrew_PCBs] Re: dry film and laminator
2003-10-06 by Adam Seychell
roel_cnc wrote:
>>What type of etching solution do you use ? I assume...
Does it oscillate side to side movement or is it spinning ?
Is your pump a centrifugal or a diaphragm type ?
Do you have a model number for the pump ?
I found a company, www.flojet.com (web site seems to be down at
the moment). They make a large range of relatively small electric
diaphragm pumps. These pumps are higher pressure and low volume
compared to centrifuge type. You probably know that spray nozzles
need good pressure to work effectively.
Did you consider using proper chemical etching nozzles ?
What is the spray pattern on the nozzles you are using ? Fan or
cone type ?
I have read that the spray pattern and the positioning of the
nozzles is critical for uniform etching. Did you experiment with
different nozzle configurations until you were happy with the
etching results ?
Thanks, it seems I should try and get hold of some of this
soldermask. I wonder if its more expensive than photoresist.
Here is the datasheet for the laminar DM;
http://www.interflux.pl/wwwpages/products/shipley/laminar-dm.pdf
I guess its not possible for soldermask to be stripped off the
board after it is fully cured. Methylene chloride paint stripper
should work, but that will kill the epoxy laminate material too.
2003-10-07 by roel_cnc
> cone type ?
> etching results ?
uv
get
---> why should you remove.!
some links
www.hendor.com for pumps i use m62 6000 liters p/h
thats why i use 25 liters of etch and dont forget the anti foam
additif or it will rise up to the sealing. :)
www.bete.com for the nozzles i use similar to the nfs12 Fan 120°
4L p/m 20x that makes a total of 4800 L p/h
heater is a 1 kw flat wire teflon coated no url aviable yet
gr. Roel
chemicals
>>> I can send you a pdf describing the baths a bit more closely <<<<
Yes please send me that pfd file.
P.s. i already started building the units
> Markus
Re: [Homebrew_PCBs] Re: Plated through holes and rinsing ?
2003-10-08 by Adam Seychell
> they are well suited for my machine also. I can....
From what I imagine, you have all the tanks close to each
other and you dip the boards in the appropriate order in
each bath. Obviously you must rinse between baths so that
the subsequent baths do not become cross contaminated at any
appreciable rate. I'm wondering how you do the rinsing. Do
you have the tanks near a water tap, and simply lift the
board from the process tank, wait 20 seconds to finish
dripping, move to the running water tap, rinse, wait another
20 seconds to drip, then proceed to the next process tank?
I am thinking of building my own processing tanks, but
wondering if its worth including the rinse tanks after each
stage. Like you I have managed to weld 3 mm PVC plastic
sheet (the gray stuff) and I bought a secondhand hot air
welder for this job. I also built a plastic sheet bender
using a hot element wire running a line in the middle of the
piece of particle board. I found it impossible to get
straight and neat right angle bends using only a hot air
gun. The best way to construct a series of small narrow
tanks is to divide a big tank into small ones by welding
dividers inside. In this way 10 or 15 separate baths could
easily be built with the least amount of welding and materials.
A two stage counterflow rinse stage would consist of two
tanks next to each other, the first tank (the tank you first
dip) has about 1" higher liquid level than the second tank.
The wall between the two tanks has a open hole so the first
tank pours into the second tank when its liquid level goes
above this hole. The second tank has an effluent hole about
1" below this level. If you are a bit interested in
counterflow rinsing then check out;
http://www.justoffbase-tools.co.uk/tools.asp?parent=1I2433P1056M0
Theoretically a 20cm x 20cm PCB will need 100 mL of fresh
water added each rinse cycle to keep the concentration of
the second rinse tank 1/1000 of the process tank in a two
stage counterflow rinse system.
If 3 stage counterflow rinse is used the concentration of
the final tank is reduced to 0.005% or 50 ppm. Ok its clear
2 stage rinsing is more than enough for the job.
In your setup, is it possible to empty individual baths ? I
was thinking of welding small block of plastic to the tank
bottom and then tap a 3/4" BSP thread into this block for
screwing in a drum tap. Something like shown
My aim is to have then entire PCB processing equipment in
the one area so I can make a board without having to run
around over the place. By including rinse tanks I think it
will make the job easier to control. Would you agree ?
Correction, the link to counterflow rinsing is
http://www.blackstone-ney.com/04.TP_better_rinsing.php
and I also got the liquid levels mixed up, The second tank
has a higher level than the first tank.
roel_cnc wrote:
> some links
According to the BETE data sheet the NFS12 is the smallest in the
series.
http://www.bete.com/metric/products/pages/nfs.htm
The performance graph of the M62 tells me that if you use 20x
NFS12 then the you are operating almost at maximum pump pressure.
i.e you are heavily restricting the flow.
At 1.2 bar the NFS12 puts out 0.306 liters/min, times by 20 gives
total flow of 6.1 L/min or 370 L/hour. You are only getting a
small fraction of the energy from this pump.
2003-10-08 by Steve
I figured that's what you meant. Use the used, slightly dirty water to
prerinse, then into clean fresh water.
Steve
2003-10-08 by Markus Zingg
Hi Adam
[snip]
>each bath.
Yes, however the tanks are SEPERATED from each other by a ~1" sized
gap. That's needed cause the temperature of the baths must be
controlled individually. That's important here and I mention it to
give another indication why creating a tank and puting in walls is a
bad idea here.
Ok, here we go:
bath #1 is a Cleaner Conditioner that must be run at 65-70 degrees
celsius (149 - 158 farenheit) the PCB must reside in this bath for 7
minutes. Thereafter there is a 1 minutes static rinse followed by 1
minute spray rinse .
bath #2 is a "Predip" - no heating requiered roomtemperature is ok.
The PCB must be in this bath for 1 minute. There is NO rinse made
after this bath cause the water would contaminate the following bath.
bath #3 is the "Palladium" bath also called "Activator". That's said
it's the bath which makes the holes conductive. Duration is 7 minutes,
temperature is also room temperature. There is a 1 minute static rinse
followed by 1 minute spray rinse after this and before the next bath.
bath #4 is the so called "Intensifier". The purpose is to make
palladium that happens to reside on the copper go away and to
intensify it in the holes. Duration is 4 minutes. The bath temperature
must be 45 degrees celsius ( 113 fahrenheit) There is also a 1 minute
static rinse followed by 1 minute spray rinse.
bath #5 is then finally the coper plating bath. This is ok at room
temperature. Duration is 24 minutes followed by a final 1 minute
static and 1 minute spray rinse.
I rinse the pcb's simply in a water tank, then go to the wall water
outlet? (don't know the propper english term) and rinse it there for
another minute. I use a kitchen timer watch to controll the durations
and take very much care to stay within these times and temperatures. I
never had a problem yet by doing so.
>gun.
I did not used any aditional tools. If the gun is having a small pipe
header it's sufficient to simply move it up and down along the line
you want to bend it up until it stats to bend. Then take a 90 degree
angel that lies on a table or such and bend the plastic to 90 degrees
holding it down to the table and into the angle. Was really easy with
the "hobbyglass" I was using. I created a little piece of wood with
the size of the final width of the tanks (i.e. two of them. one for
the 5cm tanks and another one for the 10cm tank) that I used to keep
the distance of them equal. The remainig part is practizing :) I had
to create ~4 aditional tanks that were not ok.
No, that's a problem with heating and keeping temperatures apart. I
also can tell you that it's going to be very difficult to have those
tanks dens cause you will have big trouble reaching them as narrow as
they are.
Intresting article Will look into this later (I'm a bit short of time
at the moment)
I wanted to do something with such a drum tap but haven't found them
here. Since with my station the tanks simply are standing within the
grid takeing them out even if they are full is no problem. Once they
are out they can easily be emptied into normal plastic tanks. In
general this is definately a very good idea cause some of the fluids
tend to "vaporize" away if the tanks are not closed - which is hard to
achive. So, if you can empty the tanks whenever the station is not
needed this is definately the best solution. Aditionally you will find
that the stations remains a lot cleaner over time this way.
Yes, I agree that having the rinse tanks close is a good idea. I don't
know though if you manage to have a good spray rinse situation without
too much hazzle though.
Markus
Hello Markus,
Markus Zingg wrote:
[delete]
> bad idea here.
That makes perfect sense. Only the baths at room temperature
can have rinse as part of the "main" tank. Otherwise the
rinse tanks will have to be separate. I have seen commercial
counterflow rinsing systems built with one larger tank
partitioned into equal sections, but I guess that would be
the obvious way to it.
> Ok, here we go:
Thanks for the detailed description of the process you
follow. You might remember I am using a different chemistry
up until the copper electroplating. I'm not really developed
enough to describe them in detail yet.
I fully understand the importance of making sure every step
is followed properly. Correct bath temperature, dwell times,
and rinsing are essential.
65 - 70°C is a high temperature, does "hobbyglass" material
become softer at that temperature ? You mentioned that
working with hobbyglass is easy using hot air tools, so I
assumed it to be similar to ridged PVC, which I found very
easy to work with compared to plastics like Plexiglas
(perspex), polypropylene, polyethylene, polycarbonate.
PVC begins to become soft after 52 to 56°C, and at 65° is
like a very stiff rubbery material and becomes softer as
temperature rises.
I also found that making wooden jigs helps the building
plastic tanks. From your photos, it looks like you have done
very well.
I can understand why 1 minute is needed for rinsing because
solution tends to stay on the surface and in holes. You can
see this when the PCB pulled from an acid solution, rinsed
and then allowed to dry. Small traces of acid stain the pink
copper, and it takes a lot more than a 10 seconds of rinsing
to remove enough acid for no staining to occur.
I always used lids on my tanks, dust and evaporation will
eventually take their toll. Have you thought of putting a
hinged lid with some plastic foam underneath to help seal
off the tanks ?
I'm surprised you cannot find drum taps. They are very cheap
and sold almost any hardware store here in Australia. The
cheap ones are about AU$1 wholesale.
I cannot see why spray rinsing would be that important for
our operations. Spray might achieve the same result faster,
or better for removing solids. I don't think is would be
essential for the palladium system (super activation) you
are using. Immersion in a rinse tank and gentle movement of
the panel for 1 minute should properly rinse. Its mainly
drilled holes that are more difficult to flush out.
Having recently shopped around for a pump for a spray
etching machine, its clear that spraying equipment is going
to cost you :) The Iwaki WD-70RZ I was initially looking at
can produce 1.5bar at 20L/min but costs AU$600 ($US380), the
Iwaki WD-30RZ 0.9bar at 9L/min, but I can get for AU$250
($US170). The lower practical limit for spray nozzles is
about 0.7 bar so hopefully I can get by with the cheaper pump.
Thanks again for your help, I'll keep you informed when
things develop.
Adam
2003-11-01 by roel_cnc
To Markus,
Why are the anodes bagged/enveloped with clothes!
i did try that welding part on some hobby glas and pvc sheets with no
luck at all- even after a week or 4 no real (strong)rigid weldings
are posible.
I created me a vacuum unit - that do the job perfect :))
gr. Roel
2003-11-01 by Adam Seychell
> To Markus,
> are posible.
> gr. Roel
Then you must not have been using either the correct type of
welding rod, hot air nozzle shape, hot air temperature,
welding technique or preparation of the joining surfaces.
It does take a fair bit of practice to get a basic weld,
(similar to the leaning curve of soldering in electronics)
but then it takes a lot more practice to make it 100%
strong, i.e. welds stronger than the base material.
Some good information on hot air plastic welding can be
found here;
http://www.tempatron.co.uk/pdf_files/Principles.pdf
2003-11-02 by Markus Zingg
>To Markus,
>are posible.
>gr. Roel
Hi Roel
Firest of, nice to see that someone tires to build a station!
I did not used PVC sheets. The hobby glass is made of Polystyrol which
is really easy to weld and bend with the hot air gun. I do agree
though that creating the tanks is from the point of view of the
mechanical aspects a more difficult part. I also "wasted" about 3
tanks until I had it going.
Another option might be to glue the tanks instead of welding. There is
a guy from gemany currently building the station and he decided to go
this route. He posted a picture of the tanks in a german web based
electronics forum and since the thread is a) in german and b) not
directly linkeable I put the picture of the forum up to my website so
as you can take a look.
See here:
www.myhome.ch/mzingg/pcbstuff/tps/dg_tanks.jpg
Aparently you solved the problem with the vacum unit you mention.
Interesting, do you have a picture of it?
Markus
2003-11-02 by roel_cnc
Hi Markus
the tanks are ready so no more welding or glue :))
But i will try again with the info pdf from >>Adam<< <(thanks)
the idea of vacuming i found on the net
www.xs4all.nl/~atmel/thermomoulage1.avi
www.xs4all.nl/~atmel/thermomoulage2.avi
practical the same as i have build
and about 5 min per tank to make
pics will come as soon i get hold on to a camera
Question why are the anodes on your pics covert with clothes!
next the heated tanks do they have air agitation otherwise it get a
more hot to the element as eslewere in the tank!
perhaps we should talk more ore less about the hazards and
power .psu. thats involved for the people who's gonna trie to build
>Hi Markus
Uh, yes, I forgot to answer this part. They are here to keep small
copper wires that will be created by the process away from the PCB
where they obviousely could create short cuts. For a homebrew station
- due to the smaller number of runs - maybe not that much of an issue,
but they were part of the anode package as I bought it.
Huh? what do you mean with this?
Markus
2003-11-02 by Adam Seychell
Markus Zingg wrote:
>>Hi Markus
What small copper wires are you talking about ? I thought
the anode and cathode (PCB) are well separated so there
cannot be any possibility of contact.
Anode bags are very often used in many types of plating
baths. I know that for bright acid copper sulfate plating
the bags are used to inhibit solution flow around the anode
surface and preserve the black (or dark brown) film that
normally forms. I am using Macuspec 9241 brightener from
Macdermid and the data sheet stresses that anode bags must
be used. Well, since it didn't give any reasons why anode
bags must be used I didn't believe it and so I didn't use
any. Hmmm, yep, I soon learned why the bags are important.
The black film on anodes that's formed during plating is
very fragile and may easily strip off with air bubble
agitation. In these conditions the film is continuously
forming and releasing into the solution. After plating just
one PCB I could see enough precipitate produced that the
bottom of the tank was covered with a dark powder. I
installed the proper anode bags and it solved the problem
totally. I later read in plating books that the anode film
in bright acid copper plating is important for correct
dissolution of the anode.
Interesting , originally when I was plating with no
additives (200g/L H2S04 , 75g/L CuS04.5H20), the anodes
would not form this dark brown film, and would be more
stable. But there were still some anode film and small
amount of copper powder would release into the bath.
I also found that plating with low acid high copper
(75g/L H2S04 , 200g/L CuS04.5H20) then anodes dissolve much
cleaner and remain pink, but of course this bath has
terrible plating uniformity and is why no one uses it to
plate PCBs.
The anode bags are normally polypropylene fabric, that looks
very much like white denim. You could probably use 2 or 3
layers of 100% polyester fabric. I would first put it in
some 200g/L sulfuric acid for a week so that any thing in it
that might react with the acid will do so before in goes
into your plating tank.
Hi Adam
Good question :) That's what someone told me they are used for. Well,
I used the station during some runs without those bags and could not
see a difference in the results. There are also no visible wires or
such, so maybe they surf another purpose - hell, most likely the one
you describe.
I also use brigthner and the anodes also became this dark "patina"
which I was told is good/important for the process. I do have the bags
mounted and since I have them I never felt motivated to try without.
Might be that I under estimate their effect. I must say though that I
don't use air agitation in my tanks.
Markus
> I thought
>plate PCBs.
>Be sure to visit the group home and check for new Bookmarks and files:
>To unsubscribe from this group, send an email to:
>Homebrew_PCBs-unsubscribe@yahoogroups.com
>Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/
2003-11-02 by mpdickens
Markus,
I am in the process of building a copper plating
station for thru-hole plating. What you are describing
is very similar to the descriptions that I have read
about while researching this topic. Is there a website
with pictures and/or describing what you have done?
I am very interested in how you physically set your
plating station as the chemistry you are employing.
Best regards
Marvin Dickens
--- Markus Zingg <m.zingg@...> wrote:
> Hi Adam
> are used for. Well,
> bags and could not
> visible wires or
> most likely the one
> you describe.
> dark "patina"
> I do have the bags
> to try without.
> say though that I
> Markus
Registered Linux User No. 80253
If you use linux, get counted at:
http://www.linuxcounter.org
Do you Yahoo!?
Exclusive Video Premiere - Britney Spears
http://launch.yahoo.com/promos/britneyspears/
2003-11-03 by Adam Seychell
Markus Zingg wrote:
> Hi Adam
> you describe.
The brightener data sheet describes the optimum color for
anodes and black to very dark brown. If red or pink then it
means something is out of balance. Oh, one more thing, this
dark film only forms on phosphorized copper anodes (copper
with 0.05% phosphorous). Without the phosphor there is no
film and the anodes dissolve in such a way they release
copper powder in the solution. I think its the additives
that are mostly responsible for making the copper anodes
dissolve this way. I know from early experiments copper
plating with a low acid high copper plating solution (75g/L
H2S04, 200g/L CuSO4.5H20) without additives and pure copper
anodes then the anodes dissolve reasonable cleanly.
A beginner might like to use that bath instead because no
brightener or phosophorized anodes are needed. Problem with
this bath is that plating uniformity is extremely sensitive
to your anode configuration. Also you can only plate to
about 100 um before copper "noodles" start forming.
2003-11-03 by Markus Zingg
>Markus,
>Best regards
>Marvin Dickens
Hi Marvin
Yes, I created a little site about the station. See here:
Markus
2003-11-03 by mpdickens
Hello Markus!
Your station is most excellent! Questions:
1.) What/who's chemistry are you using?
2.) How many volts/amps do you? Are you
using a formula to calculate
voltage/amperage verses board size?
3.) What is the composition of your anodes
and what is thier weight/size?
Before I saw what you had done, I had already begun
construction of a similar thru-hole plating system.
Like you, I came to the conclusion that what I needed
was a station that was built on time tested
technology. In other words, I wanted to build a
smaller version of
what large companies use to thru-hole plate (In fact,
all of the tools/fixtures/equipment I have made are
based on proven industry technology).
Currently, I have the tank, card holders and
circulation system completed. I still have
build/engineer the rectifier (power supply), purchase
anodes and descide on a chemistry. My plan is to
complete this station, work the kinks/problems out and
then build a tinning station.
Your station is of professional quality. Further,
I am impressed (Not that it really matters...).
FWIW, you may want to cross post/link your station
to:
http://groups.yahoo.com/group/Electroplating
Best regards
Marvin Dickens
> Hi Marvin
> here:
> Markus
Do you Yahoo!?
Hi Marvin
>Hello Markus!
I'm using mostly ready made chemistry from Bungard Electronics. This
is the same chemistry as it's also delivered to professional board
houses. In other words, if you can't get it say from Bungard it's
always a good idea to ask at a board house if they sell smaller
quantities to you.
Yes, 3 amp's per square decimeter which is rouoghly 3 amp's per 3.8
square inches. It's not that critical, so it's maybe save to say 3
amp's per 4 inches square.
The weight is not so important. The "fater" they are the longer they
last. The amount of surface is what counts but even there you can vary
a bit. Acording to my experinece I'd say that if you build the station
"reasonably" the most important thing is the chemistry used. I
strongly recommend you or anyone else interested to buy this from a
proven place (i.e. a board house or a special supplier of board
houses). The anodes must be made of copper with some small amount of
phosphor. I bougth my anodes also from Bungard along with the
chemistry. The chemistry came mostly ready madb but had to mix
together certain fluids or mix it with distilate water or sulfric acid
etc. etc. Along with the chemistry detailed instructions on how to mix
the baths were suplied.
>smaller version of
Again, I strongly recomend to consider Bungards chemistry. I have no
clue where you live, but if it's in europe chances are good that you
can order there. Adam Seychel - another member of this list - comes
from australia (well, at least that's what I think) so he may can
provide you with a good supplier there. There are also many US members
of this list so maybe someone can provide information on where to buy
such chemistry in the US.
Well, thanks for the flowers. It was quite a bit of work. I had the
luck of knowing someone who bought a little station and who told me
what to avoid and what to add, and - as mentioned - I spent quite a
while with thinking on how to build it so as it can easily be
operated, quickly cleaned and to operate it in a save and easy fasion.
>to:
Intresting link. I was not aware of this group.
Markus
Re: [Homebrew_PCBs] Re: copper plating
Marvin,
If you don't want to go through all the technical know-how
and details of chemistry of plating then I would recommend
you buy the plating solutions and necessary parts from
someone who specializes in this. Markus has shown the group
he has had good success with Bungards as a supplier. You can
probably save money buying everything individually, such as
anodes from an anode supplier, or sulfuric and copper
sulfate from a chemical supplier, brighteners from a plating
supplier. There should be electroplating suppliers in any
industrialized city that has electroplating shops. It took
me quite a few phone calls before I found what I needed. Its
surprising how helpful some salesmen can be to the poor
hobbyist trying to setup a plating apparatus. The chemicals
are non-toxic, although corrosive and can burn skin & eyes.
The problem may be buying small quantities. If the person at
the electroplating supplier is not too busy he/she should
happily sell you small quantity. I was lucky enough to get
free 250 ml bottle of Macdermid brightener for acid copper
sulfate plating, simply because it wasn't worth their effort
selling so small amount. That gave me enough brightener to
make 90 liters of plating solution. Don't bother trying to
buy supplies from PCB fabricators or plating shops. I went
to about 6 different places and not ONE of them was willing
to sell me anything.
Your anodes must be phosphorized copper or they won't form
the black protective film during dissolution. Anodes are
sold at electroplating suppliers as nuggets, bars, ect. I
bought 1 kg of nuggets because the bars were too big and
expensive. The nuggets sit in a sack made from outdoor
plastic shade cloth (polyethylene). A connection is made by
2mm^2 PVC coated solid wire to one of the nuggets, which
contacts the remaining nuggets. I drilled a hole in the
nugget to neatly fit the solid wire and used a nail punch to
crimp the outside of the nugget. Some PVC solvent cement
sealed the wire connection at the nugget. If you can get
small anode bars then they will be easier to use than nuggets.
My tank is 250 mm x 340 mm base and 320 mm high. Liquid
depth is 250 mm. Maxium PCB capcity is 300x200mm. Spacing
between the middle of the anode and PCB surface is about 90
mm. There are two anodes in total giving one on each side of
the PCB. The anodes sacks are about 60 mm diameter at the
widest part. Each anode weights about 500g. There is
polypropylene anode bags as recommended in the Macdermid
brightener datasheet. I bought one large anode bag form the
supplier and cut it to size, then sowed together with 100%
polyester thread. I usually plate between 2 and 3 A /dm^2,
but go down to 1.5A/dm^2 in cold temperatures (<15°C) in
order to maintain a bright plating finish. Solution
agitation by air bubbles using homemade air diffuser (two
lengths of PVC pipe 1 mm holes each spaced 25 mm) and a good
aquarium air pump. There are lead weights at the bottom
which stop the diffusor from floating. Tank holds 22 liters
of plating solution and constructed from gray 4.5mm ridged
PVC sheet. All plastic joints are hand welded.
Adam.
mpdickens wrote:
> Hello Markus!
> smaller version of
> to:
> Best regards
> Marvin Dickens
pvc hot air welding
2003-11-04 by roel_cnc
info to Adam and Markus :)
Buy me new wire and sheet pvc today.!
pitty is wire gose only per 2 kilo's
Its fantastic and strong (AWESOME)
Re: [Homebrew_PCBs] pvc hot air welding
2003-11-05 by Adam Seychell
This weekend I played around with my hot air welder again, trying
to get better practice. I bought three types or welding rod, and
small and large triangle type and a 3 mm round, each type comes
in 50 rods per pack. I found triangle is the best. For 4.5mm
sheet I use the larger triangle, for 3 mm sheet I use the small
triangle rods. Practice on lots of scrap pieces and then try and
break the weld when cooled. A *really* good weld will not break
at the weld, but rather the sheet its self will break. The trick
is to get the right temperature setting and nozzle distance from
the work piece. There is a fine line between burning the plastic
and not heating it enough to properly fuse. If the temperature is
too low then it takes too long to melt the plastic and so too
much heat transfers to the bulk of the material, which makes
everything deform and then you cannot push hard of the rod. If
the heat is too hot then it very easy to burns the plastic which
contaminates it with carbon and produces a weak weld.
Adam
roel_cnc wrote:
> Hi,
Re: pvc hot air welding
2003-11-05 by markuszingg
> Adam
Hi Adam
The trick that I use is the hot air welding gun itself. It's
temperature is automatically controlled and it is having a digital
display showing the temperature which also can be used to set the
temperature requested. It then takes the gun probably 10 seconds or
so to reach a new temeparature level and it then stays there. This
really helps a lot in getting consistent good results.
Markus
Re: [Homebrew_PCBs] Re: pvc hot air welding
2003-11-05 by Simon Whitehead
Markus,
Which hot air gun do you use?
Simon
>> Adam
> Hi Adam
> Markus
> Buy Ink Cartridges or Refill Kits for your HP, Epson, Canon or Lexmark
> Printer at MyInks.com. Free s/h on orders $50 or more to the US &
> Canada.
> http://www.c1tracking.com/l.asp?cid=5511
> http://us.click.yahoo.com/mOAaAA/3exGAA/qnsNAA/bGYolB/TM
Simon Whitehead
s.whitehead@...
>>Adam
> Hi Adam
> Markus
Do you have brand name / model number for the hot air welder
you are using ? I have a Leister Tirac S
http://www.leister.com/english/html/inhalt/6_1_3.html
It does not have digital temperature readout.
2003-11-05 by Markus Zingg
Seinel Modell HL2305 LCD
I really can highly recomend this one. It's not even that expensive.
http://www.steinel.de/englisch/index.html
there click on "Products for DIY ers" then on "Hot Air Guns" it's the
first one on the left.
Markus
>Markus,
>Simon
>>> Adam
>> Hi Adam
>> Markus
>> Canada.
>Simon Whitehead
>s.whitehead@...
A friend of mine has got one of those Steinel LCD guns, I
should of tried it before spending my money on that old and
used Leister hot air welder. The air pressure from a hot air
welder is a lot higher than a heat gun, so I'm not sure how
well it will work, but if you had successfully built your
tanks from it then I cannot see any major problem with using
a general purpose hot air gun. All the reducing nozzles for
hot air guns also have a side vent that can get annoying.
The side vent is probably there to prevent too much
restriction of air flow.
Adam
> Markus
>>Markus,
>>Simon
>>>>Adam
>>>Hi Adam
>>>Markus
>>>Canada.
>>Simon Whitehead
>>s.whitehead@...
On the web page of Steinel I posted you also can see the accessories
available. I use the "Reduction nozzle, 9 mm" to bend the material and
the "Welding nozzle" for the real welding operation. Works quite
nicely.
Markus
>Adam
>> Markus
>>>Markus,
>>>Simon
>>>>>Adam
>>>>Hi Adam
>>>>Markus
>>>>Canada.
>>>Simon Whitehead
>>>s.whitehead@...
I can see the 3 mm sheet being bent that way say upto 300 mm
in length. I made a plastic bender because I was planing on
doing larger tanks 450 mm length on 4.5mm thick PVC. You
seem to have done things quite nicely with what you've got.
What thickness material are you using ?
Did you have to reinforce all the welding zones with blocks
of wood before you started welding so that the "hobby glass"
sheets didn't bend under the heat ?
I found that I had to make special wooden frame inserted
into the tank so that during welding the pressure of the
welding rod didn't collapse the sheets.
From your past posts on the "hobby glass" I get the feeling
this is ridged clear pvc sheeting. Try burning some and see
how it compares to flame color/smoke smell to some real PVC.
PVC is very difficult to get burning by its self and
produces a harsh smelling smoke, (HCl fumes).
> nicely.
> Markus
>>Adam
>>>Markus
>>>>Markus,
>>>>Simon
>>>>>>Adam
>>>>>Hi Adam
>>>>>Markus
>>>>>Canada.
>>>>Simon Whitehead
>>>>s.whitehead@...
Hi Adam
2mm and 4mm.
They too bend under heat. What I did was first (using the 9mm reducion
nozzle) bend a long sheet (25x65cm) to a 'U' shape. I did this by
first bending one side, placing the sheet on a table into a 90degree
angle and let it cool out, then bend the second side. I thereafter
palced a thick wood block on the table as a base (in order to prevent
burning the table) and also created a little peace of wood that fit's
into the 'U' measuring ~4.5cm x 3cm using 5mm think wood. I then could
put the 'U' onto the side part (9x30cm) and place the wood into the
'U' to prevent it from loosing shape. I then used one hand to hold the
'U' down and also feed the plastic into the welder (of course this
time unsing the welding nozzle) and the other to hold the hot air gun.
It takes some practice but onece you figured it out it works not that
bad. You somehow miss a third hand :))
See above, you probably did the same thing then.
I'm currently not at home, so can't try this right away. I happen to
know how PVC smells when burning. Some 22 years ago I happend to learn
tool maker as my first profession where we were building molds to
fabricate plastic parts. I have a collection of the diverse plastic
base materials somewhere. Have to grab that out and compare the
flames/fumes of them with the glass I'm using.
Markus
RE: [Homebrew_PCBs] Re: pvc hot air welding
2003-11-05 by Marty Grove
I thought I'd toss this into the group: here is a link for a very
inexpensive plastic welder:
http://www.harborfreight.com/cpi/ctaf/Displayitem.taf?itemnumber=41592
It plugs into 110 volt a.c., and requires a compressed air source. I use
one of these, and plug it into an air compressor. It comes with (I'm
guessing) about 20 feet of air hose, an air regulator (to adjust the air
flow at the tip), and the electrical cord to plug into 110 volt. However,
there is no temperature thermostat on this welder, but I find that by
adjusting the distance I hold the welder to the work, I can sufficiently
regulate the temperature.
Marty
Sent: Wednesday, November 05, 2003 6:41 AM
Subject: Re: [Homebrew_PCBs] Re: pvc hot air welding
Hi Adam
2mm and 4mm.
Markus
ADVERTISEMENT
<http://rd.yahoo.com/M=267637.4116730.5333196.1261774/D=egroupweb/S=17050832
91:HM/A=1754452/R=0/SIG=11tn6fnpm/*http:/www.netflix.com/Default?mqso=601783
24&partid=4116730> click here
<http://us.adserver.yahoo.com/l?M=267637.4116730.5333196.1261774/D=egroupmai
l/S=:HM/A=1754452/rand=715585243>
Your use of Yahoo! Groups is subject to the Yahoo!
<http://docs.yahoo.com/info/terms/> Terms of Service.
2003-11-05 by Stefan Trethan
the side vent is really annoying..
i had many times nearly charring things with it.
BUT it is my fault:
From steinel supplies there is a heat shrink tubing nozzle.
this is the 9mm reduction with a small U shaped sheet metal deflector in
the front.
this deflector is obviously used to aid in shrinking the tube uniformly.
the deflector is just plugged on the roduction nozzle, you can easily pull
it off.
The result is then the nice 9mm nozzle without those silly vents.
I checked also if it is a problem to operate the gun without the vents:
the package for the shrinking nozzle (without vents) says "only for heat
guns with
electronic temperature control circuit". the vented nozzle is good for all
guns.
obviously the vents are only to keep cheap guns from overheating the
filament.
The vents are only a hazard and big waste of energy if you own a reasonable
heat gun.
On my nozzle the vents are only stamped out and bent inwards. but the
stainless material
is so strong i couldn't bend it back. if i find the time with a big vice, a
ronund iron piece and
a hammer i will maybe be able to close them.
So if you really have a heat gun with control circuit (check by restricting
the flow and monitoring
the current it draws for example) it is really a good idea to close the
holes/ get a nozzle without it.
I can also really recommend the steinel LCD, expensive but worth much
more...
st
On Wed, 05 Nov 2003 20:48:24 +1100, Adam Seychell
<adam_seychell@...> wrote:
> A friend of mine has got one of those Steinel LCD guns, I should of tried
> it before spending my money on that old and used Leister hot air welder.
> The air pressure from a hot air welder is a lot higher than a heat gun,
> so I'm not sure how well it will work, but if you had successfully built
> your tanks from it then I cannot see any major problem with using a
> general purpose hot air gun. All the reducing nozzles for hot air guns
> also have a side vent that can get annoying. The side vent is probably
> there to prevent too much restriction of air flow.
> Adam
Thanks for the descriptions. What are the internal
dimensions of the tanks. From your web pages I can see 4
smaller ones and one larger one for the copper
electroplating. From your pictures the tanks look like they
were made from 3 mm sheet. Did you consider putting an outer
lip on the tops of the tanks ?
I found that using lots of spring clamps are VERY helpful
when welding. I clamp a large piece of chipboard to the
bench so it hung out about 40 cm, I then could do all my
work on this board and easily clamp things from underneath
using sliding G clamps.
Markus Zingg wrote:
> Hi Adam
> 2mm and 4mm.
> Markus
2003-11-07 by Markus Zingg
Hi Adam
Sorry for the late reply - terribly busy times here.
They are made to contain 2 and 4.5 liters respectively with a certain
"security" zone so as I don't have to fill them completely up. The
dimensions are therefore 4x25x29 cm with side pannels sized 9x30. The
bigger tank is identical except that it's 9 cm wide. All these
measures are internal dimesions.
Uhmmm they are actually just 2mm :)
Yes, but it turned out that it's not necesairly needed. I WILL replace
the tanks though but mostly only because I want to try to build them
with a faster & easier method. I'm thinking of makeing the side
pannels from 4mm sheets and then mill a "U shaped track" into them
where I can sink the 'U' formed sheets into. This should make the
welder process easier and also make it more rigid. An outer lip seems
like a good idea.
I must say that I like the fact that the tanks are "clear". You can
see a lot better what's going on and of course if a tank should ever
start to leak this would be seen much faster.
My "next generation" tanks also will have a tube inside that allows to
pump the liquid out of the tanks into a dedicated bottle per bath.
Like this I can further minimize that something happens to the
chemicals, overall, keep them cleaner and also avoid that parts of the
liquids vaporize. Especially the cleaning bath (#1) and also the
activator bath (#4) show this tendency. Well, #1 is really almost
behaves like water. Luckyly this is also the cheapest bath.
I definately will try this milling thing as soon as my CNC drilling
machine gets ready. The material is all ready for long (you may can
imagine how hot I am to start puting it together) but as mentioned,
terribly busy times here. I'm working 18+ hours at 7 days for now 9
months or so.. Luckyly there is meanwhile a silver stripe on the
horizon.
Hmmm, I unfortunately don't understand english good enough to know
what you mean. If you could make a picuture of that process I'm sure
it would become much clearer.
Markus
>Markus Zingg wrote:
>> Hi Adam
>> 2mm and 4mm.
>> Markus
2003-11-12 by Adam Seychell
Markus Zingg wrote:
> Hi Adam
yea, same with me.
Thats simialr size to mine. For the narrow tanks I'm going
for 5.5 x 35 cm base and 30 cm high (internal sizes). Liquid
depth is 25 cm, volume 4.8L. This will process 20 x 30 cm
panels. The plating tank has a base size of 26 x 35 cm.
After much debating I've decided to go 3 mm PVC for the
small tanks and 4.5 mm PVC for the acid copper plating and
spray etching chamber.
I remember talking to you before about wanting to improve
your etching process. Well I've finnaly got all the parts
and meterials ready to build my spray etcher and will let
you know how it goes. The cost of it all wasn't bad as I
first thought. But since I'm working full time, its
difficult trying to finish such projects with limited time.
An outer lip seems
> like a good idea.
yes, you only put a extra bend at the top of the side
panels. That really strengthens it up for little extra effort.
yes ok. I'm still designing my own tank system. When I start
the construction I'll take pictures and make them available
on the web, just as you have.
Adam
