--- In Homebrew_PCBs@yahoogroups.com, "alienrelics" <alienrelics@...> wrote:
> A suggestion about posting links.
> When posting links, put it on its own line, do not use punctuation, and always add the http:// at the beginning. And if the link is longer than a line (about 80 characters) or it has spaces in it, I suggest using <> around it or using a URL shortening service such as
> http://www.tinyurl.com
> http://www.zuken.com/cadstarexpress
> Steve Greenfield
> Your friendly neighborhood moderator
> --- In Homebrew_PCBs@yahoogroups.com, "howard.chester" <howard.chester@> wrote:
> > I've just D/Loaded the free (300pin, 50 device limit)Zuken CADSTAR V12.1
> > I will try it out over the weekend and post the results soon.
> > D/Load from www.zuken.com/cadstarexpress. (requires registration)
> > I also D/Loaded the extra libraries and manual (PDF).
> > Package contains a auto-place and auto-router, export in all the usual
> > formats (including a built in PDF converter)and a 3-D viewer
One again...sorry folks, first cup of coffie and one eye closed, thanks again Steve for pointing out the glaring typo...
