Melting temperatures of toner
2010-11-03 by tda7000
Does anyone know the temperatures that different brands of toner melt at?
I managed to make transfer work with an iron, but the toner spread out a bit (doesn't help my iron doesn't have numbers printed on the dial)
Tried with a modified GBC laminator (approx 170 Degrees C) but couldn't get the toner to stick at all.
I am using a Lexmark T522 printer and I'm guessing I need a higher temperature on my laminator - but - what temperature?
Does anyone know?
Re: [Homebrew_PCBs] Melting temperatures of toner
2010-11-03 by Jean-Marc Spaggiari
Hi TDA,
I also have a Lexmark (E210), and a GBC laminator
(http://www.presentationsdirect.com/gbc-heatseal-9-creative-pouch-laminator.html)
and it's working very well.
I have posted some pictures of the results there:
http://forums.parallax.com/showthread.php?t=126368&page=2 (Seach for
jmspaggi).
Have you cleaned your board correctly? I'm using Vim (Cif) for that. I
clean it at least 3 times, then some acetone. Also, your board need to
be thick enought. I tryied with thin boards, and I had to add another
board below to be sure there is enought pressure on the laminator.
JM
2010/11/3 tda7000 <Tda7000@...>:
> Does anyone know?
2010-11-03 by freedom2000
I have a lexmark with original toner. It's merlting at 170 - 180°C
Other brands like "brothers" may melt at 210°C
JP
----- Mail Original -----
De: "tda7000" <Tda7000@...>
À: "Homebrew PCBs" <Homebrew_PCBs@yahoogroups.com>
Envoyé: Mercredi 3 Novembre 2010 12h38:03 GMT +01:00 Amsterdam / Berlin / Berne / Rome / Stockholm / Vienne
Objet: [Homebrew_PCBs] Melting temperatures of toner
Does anyone know?
2010-11-03 by DJ Delorie
When I did my laminator hack, I tested a couple of toners.  HP melts
around 170C (340F) and the high-temp Brother around 187C (370F).  I've
yet to take the time to truly characterize the HP toner though - toners
have two interesting temperatures, the one where they become plastic and
sticky (good) and the higher one where they actually turn liquid (bad).
  You want something between those :-)
