basic basics of boards
2003-09-21 by Dave Mucha
Hi all,
I was wondering it there is an introduction to basics of schematics
and board design?
Things like what polarity is the square pad on an LED ?
Why 15 mil traces and not 12.5 mil ?
how to best isolate an AC rectifier/cap from the rest of the DC on
the board ?  things like that.
are there 'standard' drill sizes that are common for all board
houses ?
I have a friend who says all square pads on 2 pins are ground or
negative. Is that rule of thumb or general industry practice ?
and it seems a 90 degree corner on a 15 mil trace, when etched can be
undercut to less than 10 mil.
Instrumentation inputs may be put inside of a ground ring to as to
keep all stray baord voltages away.
Seems I went to the monkey-see monkey-do school of board design.
Dave
Re: [Homebrew_PCBs] basic basics of boards
2003-09-21 by Stefan Trethan
On Sun, 21 Sep 2003 14:24:05 -0000, Dave Mucha <dave_mucha@...>
wrote:
> Hi all,
> I was wondering it there is an introduction to basics of schematics and
> board design?
> how to best isolate an AC rectifier/cap from the rest of the DC on the
> are there 'standard' drill sizes that are common for all board houses ?
> Instrumentation inputs may be put inside of a ground ring to as to keep
> Dave
you can design all these things like you want them.
like it makes best sense for you.
track with is determined by current/voltage drop you can accept.
but in many cases the voltage loss due to resistance is so little that you
rather make it as small as your design process allows to be manufactuered
securely. (if you have lots of space make it wider).
further you for sure will not calculate the minimum with for each track,
you simply take "standard with"
0.3mm or so what you like and only the tracks which are higher current
(maybe supply etc.) you make thicker.
the sqare pad is pin 1 most cases. never thought about cathode/anode on
diodes. i leave it how the pcb software
makes it.
i don't understand what you mean with isolate the rectifier part...
standard drill sized i don't know because i drill myself.
but 0,6mm, 0,8mm, 0,9mm, 1mm, 1,2mm and maybe 0,4mm if you need i am sure
any boarhouse in europe offers.
0,85 and 0,95 too.
If you can choose than you select the drill for the wire thickness
(emphasis on tolerances!).
ground rings around opamp inputs work. but there is also "guard ring".
it puts the "ring" or coax shielding not at ground but on a voltage which
is the same like the one measured (but low impedance).
this way you get zero losses from bad insulation etc. because there is no
voltage differential thus no current flow.
some opamp have special guard output but you may often use the other input
if it is low impedance.
(remember in amplifier configuration the inputs are at nearly same voltage)
monkey-see, monkey-do is not the worst way.
but monkey always should know why he does things.
only doing things for no special reason only because somebody else did it
is not good.
it may be not adequate for the situation.
st
> Be sure to visit the group home and check for new Bookmarks and files:
> Homebrew_PCBs-unsubscribe@yahoogroups.com
2003-09-21 by Leon Heller
>From: "Dave Mucha" <dave_mucha@...>
>Reply-To: Homebrew_PCBs@yahoogroups.com
>Subject: [Homebrew_PCBs] basic basics of boards
>Date: Sun, 21 Sep 2003 14:24:05 -0000
>Hi all,
>and board design?
Square pads generally indicate pin 1 on a component. I don't think it is
used much these days, as it takes up too much area.
For my home made PCBs I go down to 10 mils occasionally.
>houses ?
0.8 mm is the most common drill size, used for ICs, Rs and Cs.
It's a good idea to mitre all corners. They etch better and work better at
high frequencies.
"Sitting by Nellie" is the UK equivalent.
Leon
Leon Heller, G1HSM Tel: +44 1424 423947
Email:leon_heller@...
My web page: http://www.geocities.com/leon_heller
It's fast, it's easy and it's free. Get MSN Messenger today!
http://www.msn.co.uk/messenger
Re: basic basics of boards
2003-09-22 by ghidera2000
--- In Homebrew_PCBs@yahoogroups.com, "Dave Mucha" <dave_mucha@y...>
wrote:
> Hi all,
schematics
> and board design?
Me Three :D
> houses ?
IFAIK no, just 1/32, 1/16. whatever is the smallest size your parts
will easily fit into. Probably 1/16th would be the best general
purpose - though them big diode leads generally won't fit. Need 3/32
I think.
Means pin 1 on chips and typically positive on things like caps etc.
Haven't seen anything stating that this is a law or anything.
be
So put a couple 45's in there instead. Check out a trace width
calculator like
http://www.geocities.com/CapeCanaveral/Lab/9643/TraceWidth.htm. You
might be suprised at how much current a tiny bit of copper can
carry. e.g. a 15 mil trace can carry 1 full amp and only raise five
degrees C.
The most common reason for larger traces is that they're less likely
to be botched during home etching.
The second most common is to keep noise down on power traces (ground
being more important - use bypass caps for Vcc and the traces can
stay thin).
Third is high frequency. Electrons under high frequency tend to
travel at the edges of a trace and shy away from the center. There's
a ratio of how far out from the edge the electons travel and the
frequency the circuit is at (saw it in passing but didn't pay
attention). You have to make these traces wide enough so that
the "used" portion of the trace is just as big as the DC only
equivilent current would require. Or something like that - like I
said, I didn't pay a lot of attention.
> Dave
Hey, who was your homeroom teacher? I might have had the same one!
2003-09-22 by Dave Mucha
--- In Homebrew_PCBs@yahoogroups.com, "ghidera2000"
<dave_mucha@y...>
> wrote:
> > Hi all,
> schematics
> > and board design?
> Me Three :D
OK, My friend has been around a long time and has pretty much done it
all.  Says the square pad on a 2 pin is ground.  That's where it all
started.
that go me thinking about when I was doing instrumentation schematics
(as opposed to pcb schematincs)  there is a complete written
stanadard that details everything.   It would make electronics a
little easier if were adopted some of those practices, or if they
existed.
> > houses ?
3/32
> I think.
YIKES !    I use a #78 for resistors (0.015")   0.9mm for thru chips
and 1/16 for screw terminals.   I just figured that there is
something more 'standard' than using one of each lot.
can
> be
> calculator like
> degrees C.
Thans for the link.   (btw, the period on the end makes it a pita to
use.)
Nellie Prymaite.
She taught us by sitting beside Nellie in the moring and in the
afternoons, she would have us do what she did.
It sound like we went to different high shcools together.
Dave
