10 mil scissor cut copper clad ?
2010-08-16 by alan00463
Just saw this "scissor cut" double copper clad board http://www.goldmine-elec-products.com/prodinfo.asp?number=G17455 which you can supposedly cut with scissors. Has anyone used it? Is the copper on this board the same thickness as the copper on 32-mil board? Would this stuff be good for low-current prototyping?
2010-08-16 by Paul Mateer
I've used similar. Works well On Mon, Aug 16, 2010 at 8:59 AM, alan00463 <alan00463@...> wrote: > > > Just saw this "scissor cut" double copper clad board > http://www.goldmine-elec-products.com/prodinfo.asp?number=G17455 > which you can supposedly cut with scissors. > > Has anyone used it? > > Is the copper on this board the same thickness as the copper on 32-mil > board? > > Would this stuff be good for low-current prototyping? > > > -- Paul Mateer, AA9GG Elan Engineering Corp. www.elanengr.com NAQCC 3123, SKCC 4628, FPQRP 2003 [Non-text portions of this message have been removed]
2010-08-16 by Donald H Locker
Any idea what the copper thickness is? Thank you, Donald. -- "Plain Text" email -- it's an accessibility issue () no proprietary attachments; no html mail /\ ascii ribbon campaign - <www.asciiribbon.org> ----- Original Message -----
> From: "Paul Mateer" <paul.aa9gg@...> > To: "Homebrew PCBs" <Homebrew_PCBs@yahoogroups.com> > Sent: Monday, August 16, 2010 10:23:08 AM > Subject: Re: [Homebrew_PCBs] 10 mil scissor cut copper clad ? > > I've used similar. Works well > > On Mon, Aug 16, 2010 at 8:59 AM, alan00463 <alan00463@...> > wrote: > > > > > > > Just saw this "scissor cut" double copper clad board > > http://www.goldmine-elec-products.com/prodinfo.asp?number=G17455 > > which you can supposedly cut with scissors. > > > > Has anyone used it? > > > > Is the copper on this board the same thickness as the copper on > 32-mil > > board? > > > > Would this stuff be good for low-current prototyping? > > > > > > > > > > -- > Paul Mateer, AA9GG > Elan Engineering Corp. > www.elanengr.com > NAQCC 3123, SKCC 4628, FPQRP 2003 > > > [Non-text portions of this message have been removed] > > > > ------------------------------------ > > Be sure to visit the group home and check for new Links, Files, and > Photos: > http://groups.yahoo.com/group/Homebrew_PCBsYahoo! Groups Links > > >
2010-08-16 by roycepipkins
I have a bunch of thin single sided stuff. I love it. Its so thin that you can see through it after its been etched. This makes it possible to precisely align the two sides of a two sided circuit AFTER its been etched. It also means that if you want to use solder paste with SMD components on both sides of the board, its not a big deal, you can solder the sides separately before re-combining them. Just remember to drill any vias and thru-holes with the sides aligned before you start to solder. You can also get this type of board the the Ebay store: PCB Depot. ( http://stores.ebay.com/pcbdepot ) Regards, Royce --- In Homebrew_PCBs@yahoogroups.com, "alan00463" <alan00463@...> wrote:
> > Just saw this "scissor cut" double copper clad board > http://www.goldmine-elec-products.com/prodinfo.asp?number=G17455 > which you can supposedly cut with scissors. > > Has anyone used it? > > Is the copper on this board the same thickness as the copper on 32-mil board? > > Would this stuff be good for low-current prototyping? >
