makeing party hat traces
2003-09-09 by Dave Mucha
Hi all,
I have been looking at some board from some other stuff, laser jets
I've pulled apart and alarm panels and stuff, and I have seen more
than a few sections near terminal connections that look like
triangles in a row, and a mirror image so the very tips of the
triangles seem to touch.
any idea why ?
and is one does them (for the reason in the response) is there a real
need for them ?
Dave
Re: makeing party hat traces
2003-09-09 by crankorgan
Dave,
     When a building is struck by lightning, long runs of wires in
the building like Alarms and Computer networks, receive an induced
high voltage. Some circuits use a spark gap.  The gap can be a simple
gap to ground or a solid state device. The old devices looked like
tubes. My guess is the are spark gaps....then again they could be
test points.
                                                  John
--- In Homebrew_PCBs@yahoogroups.com, "Dave Mucha" <dave_mucha@y...>
wrote:
> Hi all,
> any idea why ?
real
> need for them ?
> Dave
2003-09-10 by Dave Mucha
--- In Homebrew_PCBs@yahoogroups.com, "crankorgan" <john@k...> wrote:
> Dave,
simple
> test points.
>                                                   John
I'd go for the spark gaps.  there are pleanty of individual posts
lableled TP3 and such.
but it seems a strike would wipe out the whole board, even with some
drain.
Dave
2003-09-10 by Steve
some
> drain.
It isn't to save the board, it is to reduce the chance for fire. And
lightning may hit many miles away, you could be looking at the sun
outside and bam! Your fax machine bites the dust from a lightning hit
far away. Those points mean the majority of the energy dumps there
rather than in the components.
The physics of an arc are such that once it forms, relatively little
voltage is dropped across the arc. Relatively little may still mean a
hundred volts.
Just like fuses in an amplifier are not there to save the amp, they
are there to prevent the amp from catching fire. I'm not talking
about the speaker fuses.
Steve Greenfield
Re: [Homebrew_PCBs] Re: makeing party hat traces
2003-09-11 by Ron Amundson
We used them as spark gaps during CE surge testing. The problem is that once they fire, you may get carbon tracks, but they are cheaper than gas tubes. One key thing is to not use solder mask over them, as when it vaporizes carbon tracks are assured.
We also used them as cut to select options when using one pcb assembly for multiple products.Its a lot easier to cut through a party hat with a xacto knife, than any other trace.
Ron
  Sent: Tuesday, September 09, 2003 8:58 PM
  Subject: [Homebrew_PCBs] Re: makeing party hat traces
  > Dave,
  simple
  > test points.
  >                                                   John
  drain.
  Dave
        Yahoo! Groups Sponsor
              ADVERTISEMENT
  Be sure to visit the group home and check for new Bookmarks and files:
  http://groups.yahoo.com/group/Homebrew_PCBs
  Homebrew_PCBs-unsubscribe@yahoogroups.com
