PCB cutter
PCB cutter
2010-06-16 by Adam Seychell
Cutting PCB material both easily and accurately has been a challenge for
me. I have made a PCB cutter using a angle grinder with diamond disc.
After several attempts at trying to cut straight with a angle grinders I
came up with a saw bench arrangment. I made a video to see what people
think.
http://www.youtube.com/watch?v=GPzAMOYYyKM
This cutter is probably a bit complex just to cut PCB material, but it
was the cheapest and simplest way I could think of.
Re: [Homebrew_PCBs] PCB cutter
2010-06-16 by Simao Cardoso
The simplicity and efficiency of the guiding and alignment method is
impressively ingenious. Nice thing to share! And all the other good
words applied to every your sharings.
Don't hurt yourself. My fingers hurt just from seen your video (i have
cut myself in power tools before).
My own opinion, is that if spending more money than in a carbide scriber
or steel scissor to cut pcb's is better to spent it on a cnc router.
Your way all board is nicely cut, in a cnc a vacuum table is necessary,
or one as to leave 4 or 2 uncut connections. Since no handle needed
during the process, an cnc router is at least safer.
Simao
Re: PCB cutter
2010-06-16 by sailingto
That sure works good - Amazing what you can do with the 4" grinder - I think I've seen those for $20.....
Congrats on a job well done.
Ken H>
> think.
2010-06-16 by Bob Macklin
I cut 1/32 boards on a normal paper cutter. I have not tried 1/16 boards.
Bob Macklin
K5MYJ
Seattle, Wa.
"Real Radios Glow In The Dark"
Sent: Wednesday, June 16, 2010 10:09 AM
Subject: Re: [Homebrew_PCBs] PCB cutter
> Simao
> Photos:
Those diamond tile cutting blades are relatively smooth compared to a
toothed blade so if your finger happens to brush passed, you'll just
loose a layer of skin. One possibility I didn't think about is a finger
jammed where the blade travels down through the table top opening !
I agree. Sheet metal guillotines are expensive. They also stress the
PCB, and leave rough edge. I wanted something cheap, that cuts fairly
accurate but also very quick and no fuss like a guillotine. I'd think a
CNC machine would be too time consuming to use for doing just a few cuts.
Adam
I misread the description at first, i didn't realize the so inexpensive
materials you used to do this. If there was a competition for who make
the best cut for less money you definitely won.
> One possibility I didn't think about is a finger jammed where the
Your machine will be safer with a clamp for the pcb. Just something non
flexible above the draw slide with rubber facing the pcb. As long as the
draw slide, hold with a hinge (?) or so at the jig end so it can open to
place the pcb. To cut you would just hold tight both parts with one
hand, outside the table and move it forward. For a simpler alignment
just make the a larger base on the slide, 1 or 2 mm apart from the disk,
so you can align it just from placing the pcb.
> I'd think a CNC machine would be too time consuming to use for doing
> just a few cuts.
True. Your last shown board, beside you never show the other side, is
definitely a plated thought hole board, rare on homebrews. Although the
impressive work on design, imaging and etch, the thermal vias have some
hand drill misalignment. The cnc is your last step to absolute
perfection!
Simao
Re: PCB cutter
2010-06-17 by sailingto
I use a smaller size paper cutter, it works good on .032" and less.  For .062" and .050" it does "ok", but really need to slide PCB out about middle ways so the board doesn't "twist" on cutting.
Harbor Freight has two sizes, I have the small one, and am looking at getting the large one.
Ken H>
> Bob Macklin
> K5MYJ
> Seattle, Wa.
Re: [Homebrew_PCBs] Re: PCB cutter
2010-06-17 by Adam Seychell
I've wondered about these paper cutters. Is it possible to apply enough
force to cut 1.6mm (0.062") material in the middle of the blade ? My
guess is this would put too much strain the paper cutter, but never
tried it myself. How close can you cut to traces without risk damaging
them ?
Re: PCB cutter
2010-06-17 by Chris
I have tried 1/16 thick PCB material on a paper cutter (a good one) and would not recommend it.  It will cut it but the amount of force required is high and the board tends to move during the cut making it difficult to cut straight.  I have not had any PCB stock that is less than 1/16" but suspect it would work good for thin stock.
Chris
> them ?
Re: PCB cutter
2010-06-17 by Andrew
Adam, very nicely done. Your slider and alignment jig are especially well done.
> think.
