Micromark drill press
2010-06-15 by Steve
Micromark has their "jewelers-quality" drill presses on sale. This one
is the adjustable speed
<http://www.micromark.com/MICROLUX-BENCHTOP-VARIABLE-SPEED-MINI-HOBBY-DRILL-PRESS,8283.html>
and here is the standard
<http://www.micromark.com/MICROLUX-3-SPEED-MINI-DRILL-PRESS,7797.html>
model. Even at a substantially reduced sale price, they still seem
pricey to me.
Any thoughts as to how the Micromark products might compare to other
methods that have been discussed for drilling PCB's?
Steve
Re: [Homebrew_PCBs] Micromark drill press
2010-06-15 by Leon Heller
> pricey to me.
They aren't fast enough. You need at least 16,000 rpm for a PCB drill.
Leon
Leon Heller
G1HSM
Re: Micromark drill press
2010-06-15 by morarcalin
I use this one to drill boards (http://www.jameco.com/webapp/wcs/stores/servlet/Product_10001_10001_26702_-1)
super cheap but I can say it really works. Just oil the heck out of the sliders with some WD-40 and make sure everything is snug and tight :))
To make my life easier a bit I bought one of these foot switches from Harbor Freight
(http://www.harborfreight.com/momentary-power-foot-switch-96619.html).  It really helps to have the drill stopped when you "target" the hole - you get very nicely aligned stuff going on. I use the tonner method and etch away the drill hole too, helps to guide the drill bit where it should go.
I also use drill bits from Harbor (5$ or so for 20 ..) so with around 40-45$  I got a quite decent drill solution. It just happens that I have a Harbor Freight close by.
> pricey to me.
> Steve
2010-06-16 by sailingto
Both of those are NICE - I'd sure like to have one.  With 8K RPM they sure would work nice... I expect anyway.  I "make do" with a cheap drill press with 3100 rpm max and it does a good job of drilling with anything from .017", .021", .031" and larger carbide bits. I have drilled with my dremel tool that has high rpm and the holes "might" be a tad cleaner, but 3100 rpm works ok.
Maybe I could convince myself to spend a couple hundred bucks?????  Have to think about that.
Thanks for the link.
Ken H>
> pricey to me.
> Steve
2010-06-17 by Chris
I don't agree with the requirement of a 16,000 RPM spindle.  I am using a large woodworking drill press set at about 2000 RPM and have no problem at all drilling holes in circuit boards. It would be better to have the higher RPM, but there is no reason at all you cannot use a lower speed spindle.
Chris
> > pricey to me.
> Leon
> Leon Heller
> G1HSM
Re: [Homebrew_PCBs] Re: Micromark drill press
2010-06-17 by Slavko Kocjancic
Chris pravi:
> Chris
.. but you need to slow down feed.
2010-06-17 by Andrew
Be aware that WD-40 does not provide long-term lubrication. It is designed primarily to displace water (hence the WD part of the name) and to evaporate. If you are having to relube and relube and relube, try a light machine oil (sewing machine oil) or graphite.
> > pricey to me.
> > Steve
2010-07-15 by lists
In article <hvd8si+lgc8@...>,
If you can "beg, borrow or steal" some, a drop of slideway oil as used on
lathes and so on, would probably be better still.
Stuart Winsor
