Via using J-B Weld - anyone tried this?
2010-06-05 by Chris
One of the things I don't like about making PCBs is soldering in a bunch of wires to connect top traces to bottom traces.  The more surface mount stuff I use, the more often I need to add special vias as I no longer have component legs to use for that purpose.
I have used J-B Weld on a number of "emergency fixes" over the years and have been impressed with its utility. I believe this is a metalized epoxy which I assume should be conductive.  I just mixed up a smal batch and will have to wait till late tonight or tomorrow to check it when it finally cures.
If this does conduct, then I was thinking I could apply this way....
1) Etch board
2) Tin board
3) apply clear contact paper to both faces of PCB
4) Drill all via holes
5) Use a spatula to smear the epoxy into all of the holes
6) After curing, remove contact paper
I suspect I might have small bumps of epoxy which if are a problem, a light sanding would knock them down.  If the sanding is required I could put the board back in the liquid tin again.
I probably won't be able to do a full test for a couple of weeks but thought I would announce it to see if anyone else has tried this.
Chris
Re: [Homebrew_PCBs] Via using J-B Weld - anyone tried this?
2010-06-05 by AGSCalabrese
> 1) Etch board
> 2) Tin board
> Chris
Intergoogle says that JB Weld is not conductive.
You may find this interesting....
http://www.circuitmart.com/mart/49690.shtml
Gus
Re: Via using J-B Weld - anyone tried this?
2010-06-06 by Frank P
JB Weld is not conductive...
http://www.jbweld.net/faq.php
Frank P.
> > 1) Etch board
> > 2) Tin board
> > Chris
> Gus
2010-06-09 by Chris
Confirmed - JB Weld is not conductive.
Chris
> Frank P.
> > > 1) Etch board
> > > 2) Tin board
> > > Chris
> > Gus
Re: [Homebrew_PCBs] Re: Via using J-B Weld - anyone tried this?
2010-06-09 by Donald H Locker
Anyone want to try this silver-filled conductive epoxy from Master Bond and report back?
<http://www.masterbond.com/tds/ep21tdcs.html>
Donald.
> Chris
> > Frank P.
> > > > 1) Etch board
> > > > 2) Tin board
> > > > Chris
[snip]
