>- Jim Tonne W4ENE
>----- Original Message -----
>From: "Harvey White" <madyn@...>
>To: <Homebrew_PCBs@yahoogroups.com>
>Sent: Monday, May 31, 2010 2:53 PM
>Subject: Re: [Homebrew_PCBs] Etching container
>> On Mon, 31 May 2010 10:50:57 -0700, you wrote:
>>>Hi, I have yet to find a suitable container for the
>>>etchant (I use the
>>>muriatic acid thing).
>> I also use muriatic acid and H2O2.
>> I use a sealable food container, suitably sized for the
>> board.
>> Works well for me.
>> I would take the small container and put it in another
>> larger, sealed
>> container to prevent spills.
>> Harvey
>>>It is true I can use any sort of plastic container: I even
>>>have one of
>>>those kits, with acquarium pump and bubbler and heater,
>>>but the main
>>>problem is that it is basically impossible to store
>>>safely, as it cannot
>>>be properly sealed. Pouring back to another, safer
>>>container can be
>>>still be problematic because of spills and such, and then
>>>I always have
>>>to wash everything, that takes time to do properly. Also,
>>>as I never do
>>>boards bigger than the standard 10x16 cm, I feel like a
>>>smaller
>>>container with "not so much" etchant would be so much
>>>better for my needs.
>>>Any advice?
>>>I have reached a point in my PCB making that I can do very
>>>fine boards,
>>>no problem, but I waste a lot of time in taking care of
>>>details, and I
>>>want to make the whole thing more streamlined.
>>>bye
>>>as
>>>Be sure to visit the group home and check for new Links,
>>>Files, and Photos:
>>>http://groups.yahoo.com/group/Homebrew_PCBsYahoo! Groups
>>>Links
>> Files, and Photos:
>> Links
