Homebrew_PCBs
Index last updated: 2026-03-31 01:30 UTC
Homemade Inkjet head?!?
2010-05-27 by Slavko Kocjancic
Hello...
I'm start journey to make inkjet head for printing pcb's. As far I know
all direct print inkjet have problem's with ink and head itself is
problematic. So I was just trying to make one pixel piezo head capable
to jet etch resist for making traces and after that to print real solder
resist mask.
As far I know the head itself is made from 3 components. The chamber
with variable volume, the input port capilar and the nozle.
I was try to make capilar just with zigzag milling the pcb just 0.1mm
deep and after that gluing transparent foil ontop. The capilar is 15cm
long and seems that is ok. The chamber is made inside same piece just
the depth is set to 0.5mm and is covered with piezo buzzer glued on top.
For the nozzle I just try if I can do that small hole and I can. The
hole of 0.08mm can be done without some special tool.
See photos.
Slavko.
Re: Homemade Inkjet head?!?
2010-05-27 by alienrelics
Interesting!
I imagine using this with an XY table could make up for the lack of resolution. With a conventional inkjet printer, since the location of the head and nozzles are fixed, resolution must make up for lack of placement control of the head.
Drop size might be an issue. However, I imagine you could shoot just about anything out of your single jet.
Is there a UV cure conductive ink, perhaps?
You may require a constant ink feed. I have some pages to flesh out:
<http://www.polyphoto.com/tutorials/bulkinksystem/HydraulicConstantPressureExample02Web.jpg>
<http://www.polyphoto.com/tutorials/bulkinksystem/ExtensiveThoughtsOnCIS.html>
Steve Greenfield
--- In Homebrew_PCBs@yahoogroups.com, Slavko Kocjancic <eslavko@...> wrote:
> Hello...
> resist mask.
> See photos.
> Slavko.
Re: [Homebrew_PCBs] Re: Homemade Inkjet head?!?
alienrelics pravi:
> Interesting!
> Steve Greenfield
I will try that with my CNC. The resolution is just right for that. But
the speed can be to low. But if head pass the test with CNC then I can
make another fast XY machine.
About drop size I have no clue what I can expect. I can make nozzle very
thin but I think for the solder resist I need the biger nozle as I need
thick layer. And If think work I can build another 7 nozles and have 8
nozles as in old dot matrix day's.
Stil need a lot of experiment here. I just think how to observe drop or
to capture it? Is it drop? Is it stream? Maybe some strobo light
sinchronised with firing pulses?
My interest right now is to make printer able to print stop mask layer
on pcb (green stuf). After that I go finer. And if works then this can
be just great for flip "n" print idea...
Slavko.
now I gona to check that links....
Re: [Homebrew_PCBs] Homemade Inkjet head?!?
2010-05-27 by Simao Cardoso
> know all direct print inkjet have problem's with ink and head itself
> is problematic. So I was just trying to make one pixel piezo head
> capable to jet etch resist for making traces and after that to print
> real solder resist mask.
There is something like that available
http://www.microfab.com/equipment/devices.html
I have seen your name in CNC related threads, so if is in your interest,
I remember one long thread of CNC related ideas from one guy which
wanted to use an injector from a modern car diesel engine to build a CNC
solder paste application machine. Interesting at first but stopped at
the idea. I disassembled several diesel machines and repaired them,
mostly big engines, is really fun for me, but all with classical
injection system, newer car engines have constant pressure diesel pump
and an electronically controlled injector with built-in valve. It may
work as the devices above, never play with one but they should have the
pressure valve and the very thin exit hole, so they need to be hacked.
But you may consider an old HP head. Is simpler to build, and you can
find cheap CISS systems on eBay for relevant ones. If you search for
direct inkjet compositions they are mostly if not all for thermal heads.
It can evaporate the solvent making higher solids on surface less on the
inkjet, reducing viscosity and surface tension problems. Time ago when i
was searching for this i found one company which had a custom built
epoxy printer and the photo showed an HP45 head in there. Didn't wrote
down the url and can't find it anymore. And the
guy-who-uses-this-group-to-make-money is selling this heads, you may
find an old HP printer and extract some fun from it.
Simao
2010-05-28 by Slavko Kocjancic
Simao Cardoso pravi:
> Hi,
Seems good point. But its probably too expensive as price is not listed.
(If price is not listed on web then near all the time that is done to
not scare people)
Even 100Eur is high price for me.
Yes I'm on cnczone.com too. :D A lot of hobbyes but near nill money
makers.
I think in that way to. (presure maintained with pump and electronic
valve to open it) But as I know the injector has more exit holes not
only one.
There is the problem as I want to use real solder mask. and this stuf is
thick like honey. the epson head can't blow that stuf out of the nozzle.
If that's true then I realy like to find that link.
> Simao
Slavko.
2010-05-28 by javaguy11111
I have had thoughts of doing something similar in the past.
You might want to take a look at this site.
http://www.slac.stanford.edu/exp/mps/FCS/FCS_drop.htm
I think it is about the simplest design I have seen for a
droplet ejector that might be feasible for a serious hobbyist
to build.
> Hello...
> resist mask.
> See photos.
> Slavko.
2010-05-28 by Mark Lerman
Wow - Nice link. It seems like that would do it! Now if you used a
copper solution to put down traces instead of resist, you would
really have something! Now that I'm about done with DLP, I could
easily get interested in this project! All of the systems we are
using in this group waste a lot of copper, and an additive system
rather than a subtractive (etching or cnc routing) would be great. I
know that a lot of work is being done on this, but the ability to
drop a singe dot where you want it would let us do a lot of experimental work.
Mark
>to build.
> > Hello...
> > resist mask.
> > See photos.
> > Slavko.
>> to build.
Seems very nice but how piezo is attached is very unclear.
> >> to build.
> >> --- In Homebrew_PCBs@yahoogroups.com, Slavko Kocjancic <eslavko@> wrote:
From the site
"A piezoelectric element adhesively attached to the reservoir tube "
javaguy11111 pravi:
>>>> to build.
> >From the site
I can read :D
But from picture/text I can't know how is realy done. Does piezo have
hole? Is that glas tube splited at pieco? Just not clear enought to be
sure how to deal with it.
> javaguy11111 pravi:
> >>>> to build.
> > >From the site
> I can read :D
It looks like the piezo has a hole. I am assuming that the attachment is using epoxy.
Doing a search on "ejector design Steven Zoltan" gives several hits on additional designs. A bit more research would need to be done to understand how the impulse from the piezo element gets transferred to the glass and then to the fluid. Some time modeling with an FEA program would help in understanding the exact mechanics of process and optimize the design.
javaguy11111 pravi:
>> javaguy11111 pravi:
>>>>>> to build.
>>> >From the site
>> I can read :D
I'm already found that. Part's of some eboks and patents.
The piezo has hole and squeze the glas pipe. Nothing else! Just squezing
glas pipete.
But of coures we can't find piezo with just right hole.... All that is
custom made and $$$ of course...
Slavko.
2010-05-30 by Simao Cardoso
> listed.
The point was to show a concept.
> only one.
Was kind of dumb from me referring a diesel injector, gasoline ones are
way simpler. There is who said the fuel injector works but worth what
worth
http://fabathome.org/wiki/index.php/Tools:_Fuel_Injector
Other thing you may consider are those printing markers used in
production of cables, tubes , metallic rods (and almost everything else)
used for side marking of lengths, dates, part number, etc. Some are
inkjet type, they have larger and fewer dots, could be capable of more
viscous liquids.
> is thick like honey.
Proper inks are difficult to source. But pump+tubes+single-dot-head is
too complex.
Simão
2010-05-31 by alienrelics
--- In Homebrew_PCBs@yahoogroups.com, Simao Cardoso <simaocardoso@...> wrote:
> viscous liquids.
At least some of them just use HP45 cartridge/head combos.
I have my doubts as to using solder mask as-is in an inkjet cartridge of any kind.
Steve Greenfield
2010-05-31 by Simao Cardoso
> of any kind.
And i don't argue with that. Inkjet soldermask technology seem more
related to fluid uv ink. I think even those require pumps, filters ,
heaters and agitators. The only thing i ever found acceptably simple was
http://www.freepatentsonline.com/7429102.html
Something similar to common epoxy with a solvent. Viscosity under 5cp.
In a common type of printer. Still no easy knowledge or anything i would
try. Or at least i don't find myself smart enough for it. Maybe one day
will be a easy source for an usable ink. That or my twenty-something
youth believe in change.
Simão
