Re: [Homebrew_PCBs] Re: light ring conversion for miniature drill press
2010-05-25 by Harvey L. McRae
I use my Dremel tool all the time for drilling my boards. I use a #70 drill bill. I don't even use a carbide bit and I have had no problems. Cheers. Harvey L. McRae, 838 McKenzie Rd., Kelowna, BC. V1X2B3, www.webs.com/harriscreekcentral
Sent: Tuesday, May 25, 2010 1:02 PM
Subject: Re: [Homebrew_PCBs] Re: light ring conversion for miniature drill press
Is a dremel adequate for drilling pcbs using carbide drills? I know
it isn't good enough for pcb routing, but just for drilling?? If not,
what is a good, small, reasonably priced alternative?
Mark
At 05:59 PM 5/24/2010, you wrote:
>On Mon, 24 May 2010 22:40:31 +0200, you wrote:
> >I think even with a single sided board the light shining through the
> >center of the pad might be enought to locate it depending on PCB
> >material. Or one could turn it over, of course.
>In my experience, trying to locate holes and align them, no. You
>wouldn't b happy with the results. I'd say either drill from bottom,
>right side up, or drill from top, top side down.
>Problem with turning the board over is not the dust collection, it's
>the large (and bulky) drill mechanism. Clamps are not always needed,
>but might help. Hydraulics are not needed, but a spring and solenoid
>might help.
>It does sound like an interesting project.
>Harvey
> >ST
> >On Mon, May 24, 2010 at 10:37 PM, Mark Lerman <mlerman@...> wrote:
> >> I was thinking that the board would have to be upside down when you
> >> drilled it because the camera would have to see the top of the board,
> >> but you're right, there will be pads on the bottom of the board,
> >> too. Yes, camera on bottom is probably better, and certainly easier
> >> to implement. I've got a video otoscope that's made for close focus -
> >> have to give it a try.
> >> Mark
> >Be sure to visit the group home and check for new Links, Files, and Photos:
> >http://groups.yahoo.com/group/Homebrew_PCBsYahoo! Groups Links
No virus found in this incoming message.
Checked by AVG - www.avg.com
Version: 9.0.819 / Virus Database: 271.1.1/2895 - Release Date: 05/24/10 23:26:00
