how homemade tinning?
2010-05-21 by Giuseppe
Index last updated: 2026-03-31 01:30 UTC
2010-05-22 by James
>I use a product called Tinnit that comes as two powders you mix with water and heat. I've been eying a bottle of liquid tinning solution that doesn't require mixing which I think I'll try once I use this stuff up.
> As the subject....how to plate the etched pcb? liquid alloy?
2010-05-22 by Harvey & Betty McRae
Sent: Friday, May 21, 2010 6:59 PM
Subject: [Homebrew_PCBs] Re: how homemade tinning?
No virus found in this incoming message.
Checked by AVG - www.avg.com
Version: 9.0.819 / Virus Database: 271.1.1/2887 - Release Date: 05/20/10 23:26:00
2010-05-22 by Kerry Wentworth
> Well, I'm new enough to this etching process, that I wish to ask a question.. First, I'll say I am very happy to see a nicely etched board, having good solid copper carriers.. So now what is the purpose of tinning.? Can someone give me a quick answer. Thanks.--
> Harvey L. McRae,
> 838 McKenzie Rd.,
> Kelowna, BC. V1X2B3,
> www.webs.com/harriscreekcentral
2010-05-22 by Eddie Stassen
>I came across this method of electro tin plating recently:
2010-05-22 by Stefan Trethan
> Prevents oxidation of the copper, and flows solder well.
> Kerry
2010-05-22 by Leon Heller
2010-05-22 by Dave
>What you really need is an electroless Tin plating solution. You
2010-05-22 by kabowers@NorthState.net
>--- In Homebrew_PCBs@yahoogroups.com, "Giuseppe" <peppe685@...> wrote:One thing to watch out for with electroess plating is to keep everything
>can do a search on "electroless tin" and you should get some hits,
>both of commercially available plating solutions, and instructions
>on how you can make your own. One of the better discussions is
>here (Note the post by Ted Mooney):
><http://www.finishing.com/0200-0399/260.shtml>
>Back when I was young and immortal [1], I used one of the Cyanide
>based Tin plating solutions, and it worked quite well. However,
>now that I'm older and more mortal, I refuse to use Cyanide in a
>home lab.
>[2] Hey, I said "immortal", not "immoral"! :*)
>Dave
2010-05-22 by Harvey L. McRae
Sent: Friday, May 21, 2010 9:47 PM
Subject: Re: [Homebrew_PCBs] Re: how homemade tinning?
Kerry
> Harvey L. McRae,
> 838 McKenzie Rd.,
Kerry Wentworth
The Skunk Works
85 N Main St
Boscawen, NH 03303
603 753-8933
Version: 9.0.819 / Virus Database: 271.1.1/2888 - Release Date: 05/21/10 11:26:00
2010-05-23 by rlspell2000
--- In Homebrew_PCBs@yahoogroups.com, Stefan Trethan <stefan_trethan@...> wrote:
> If that is your only goal you could also paint it with a solution of
> rosin flux and alcohol.
> I bought a large spray can of that stuff and it will do many boards,
> but you can also brush paint or dip.
> The flux dries to a clear hard coating.
> ST
> On Sat, May 22, 2010 at 6:47 AM, Kerry Wentworth
> > Kerry
2010-05-23 by Stefan Trethan
On Sun, May 23, 2010 at 4:12 PM, rlspell2000 <rls@...> wrote:
> I use the rosin flux pen. Seems to work pretty good. After a year or so the board will turn a bit brown, but no corrosion, and you can still easily solder on it if you need to.
> Where do you get your can of alcohol thinned rosin? Do you have a link?
2010-05-23 by Frank P
> http://translate.google.com/translate?client=tmpg&hl=en&u=http://www.py2bbs.qsl.br/banho_estanho.php&langpair=pt|en
> <http://translate.google.com/translate?client=tmpg&hl=en&u=http://www.py2bbs.qsl.br/banho_estanho.php&langpair=pt%7Cen>
> (The site is in Portuguese, but Google does a fair job with the
> translation). Has anyone tried this?
2010-05-23 by Eddie Stassen
>For this method, since its electroplating, its done prior to etching. I
> Eddie,
> I'm new to etching too, so I am going to ask a naive question.
> The link you provided looks like the tin plating takes place PRIOR to
> etching.
>The chemical (electroless) methods are used after etching. This is the
> I thought the tin plating took place AFTER etching.
>I normally use flux and tinning with a hot soldering iron. Its ok for
> I believe Steven's solution of using rosin flux and alcohol is meant
> to be used after the etching process(I think).
> I'm a little confused with the timing. When is tinning meant to take
> place?
> Thanks.
2010-05-24 by KeepIt SimpleStupid
Date: Sunday, May 23, 2010, 4:57 PM
Eddie,
The link you provided looks like the tin plating takes place PRIOR to etching.
I believe Steven's solution of using rosin flux and alcohol is meant to be used after the etching process(I think).
I'm a little confused with the timing. When is tinning meant to take place?
Thanks.
