Homebrew_PCBs
Printing on a solder mask
2010-05-10 by micro_minded
Has anybody tried printing a solder mask onto their boards?
I currently used pcb-fab-in-a-box with the GBC laminator and I can get 6mil traces and perfect boards every single time.
I have been looking for a supplier in canada for dry film solder resist and found nobody, only this company in germany:
http://www.octamex.de/shop/?page=shop/flypage&product_id=31&category_id=5848924494118370762daa6f026e22f7&
and this guy using it:
http://www.gerold-online.de/cms/en/uc-projects/soldermask.html
My question is could you print on a flatbed modified printer 4 or 5 layers of color to build up an effective solder mask?
Thanks!
Re: [Homebrew_PCBs] Printing on a solder mask
2010-05-10 by Andrew Villeneuve
Solder resist masks are made of polyurethane - I would suspect that you
might be able to achieve something cosmetically comparable by layering
pigment-based inks, but I don't think it would function to resist solder
very well at all.
I looked at the fab-in-a-box solution you're referring to, and it seems to
produce excellent results, but I recall it being extravagantly expensive -
hundreds of dollars per board, which is well out of my range.
-Andrew Villeneuve
> Thanks!
Re: Printing on a solder mask
2010-05-10 by sailingto
Andrew, the "Fab-in-a-box" solution does give good results, and if yo purchase it from them, it is EXPENSIVE!!! BUT there are MUCH less expensive ways of going that route. The laminator can be ordered direct from MyBinding for $25 shipped, (used to be the same low/high setting heat laminator, but that version is sold out, so for $25 they only have a high heat version - all that's needed.
The toner transfer paper can be ordered from DigiKey for about $17 shipped, and that is enough paper to make hundreds of boards by reusing the same paper several times - that is my approach. There are other papers that work almost as well that are free - as in magazine paper, OR the well know HP Presentation paper - just a tad harder to get off before etching.
Good luck and have fun.
Ken H>
Re: [Homebrew_PCBs] Re: Printing on a solder mask
There are definitely cheaper alternatives to the printing and etching parts
of the product, but the solder resist masking seems to be thing that the
fab-in-a-box system has working really well, and I haven't seen any cheap
alternatives to that yet.
-Andrew
> all that's needed.
> Ken H>
I did not realize Pulsar had any solder resist masking options. I have tried the green foil, but that's for sealing the toner, not to function as a solder resist - OR that is my understanding anyway. I've tried the green foil, and didn't work all that good for me. It's not really needed anyway as a good hot toner transfer seals the toner as well as needed for good etching.
If you are referring to a different product, please provide a link - I'd like to look at it. A solder resist mask would be neat - look good anyway. I use oversized pads and traces with a tad of extra spacing so am able to get by without solder resist mask pretty good.
Ken H.
--- In Homebrew_PCBs@yahoogroups.com, Andrew Villeneuve <andrewmv@...> wrote:
> -Andrew
> > all that's needed.
> > Ken H>
Ken,
You're right, I was actually thinking about this product in my last post:
http://www.lpkfusa.com/boardfinish/promask.htm
The price point is targeting "small shop" more than "homebrew", but if the
marketing is to be believed, it produces fab-plant quality results. They've
posted a video of the kit in action.
http://www.youtube.com/watch?v=hL1IuoUtVbw
Getting set up with this thing runs you US$650 for the materials to run 20
boards, and you'll need to have a UV developer table to use it, since it
uses photo masking for the resist mask.
You might be able to get by with skipping their starter set and just buying
the consumables for $200 (look at their store on the website), but it's
still pretty steep if, like me, you just thought solder mask "would be
neat".
-Andrew
> etching.
> Ken H.
> --- In Homebrew_PCBs@yahoogroups.com <Homebrew_PCBs%40yahoogroups.com>,
> parts
> > -Andrew
> expensive
> MyBinding
> but
> > > all that's needed.
> shipped,
> work
> HP
> > > Ken H>
lpkfusa.com has some awesome products thats for sure, for a slightly cheaper alternative I have found www.thinktink.com They have soldermask ($300 for 40ft) as well as a through hole compound for $70 and you just need a simple copper electroplating setup (http://www.thinktink.com/stack/volumes/volvi/condink.htm)
Pulsonix fab-in-a-box even ordered from them is pretty reasonably priced. $80 for the laminator and $80 for the starter kit that has two 10-packs of paper, green and white toner foil, single and double sided A4 size pieces of FR4. $160 was a no brainer as I ordered one board from a fab house and the damn thing didn't work and bam $75 out the window. At least now I can test it many times before I send it away. I have been using it every few days for 6 months and am still on the first pack of paper!
If you want the cheapest way do what other suggest and ebay the laminator and just get a package of the paper for $18 off digi-key.com I don't even bother with the green or white foils (not solder mask they melt under any heat) But you can get 6mil traces with 8mil isolation time and time again no worries.
So back to the original topic of dry film solder mask. I have heard of liquid solder mask, where can you get it? I don't mind having to do a UV mask as I already have the equipment and Its the same setup for the dry type I imagine.
2010-05-11 by James
> Ken,
> neat".
> -Andrew
Yeesh! At that price you'd be better off just having boards made! I strive to make my homebrew PCBs as good as possible, but if I want production quality, I'll send off for some professional boards. Homebrew is fantastic for prototypes though, on a couple of occasions I've not caught errors in my design or layout until I assembled on a board I made, it'd sure be a drag to order a batch of boards only to discover they don't work!
2010-05-11 by micro_minded
I just ran into this website (http://techref.massmind.org/techref/pcb/etch/directinkjetresist.htm) that references this group. Turned an Epson into a flatbed printer.
You can pick up an Epson R220 and the CISS ink cart on ebay for $40 each (http://cgi.ebay.com/Compatible-CISS-ink-Epson-R340-RX600-R300-R200-R220-/380120801532?cmd=ViewItem&pt=BI_Toner&hash=item5880f720fc#ht_4561wt_940)
I have a lot of posts to read through still but I'm guessing some members here use think inkjet method and other use the laser printer method. That website says people have had good luck printing on a solder mask and component layer as I want to do. Looks like the ink can handle the reflow oven temperatures and should provide enough of a mask to keep solder paste from flowing down the tracks no?
Anyways enough pondering for tonight, need to find some pics/posts and see what others have got to work.
2010-05-11 by Tolga Abaci
Actually, there is another method that I've been experimenting with. It's
based on toner transfer and a glass paint called Pebeo Vitrea 160.
You can see some of the results I've obtained here:
http://retromaster.wordpress.com/pcb-making/. Just go down to the soldermask
section for the details.
Also, be sure to check out the "Remaining Issues" section. The way it was
applied on the board there, the soldermask is not very strong, as it came
off in several places (it is still a lot better than a PCB without a
soldermask). This is how it ended-up:
http://retromaster.files.wordpress.com/2010/05/ufe-sdram-la.jpg
I've experimented with the two-step cure idea mentioned there, and that
seems to produce a much stronger soldermask that does not come off easily.
I'll soon update the PCB with results of the improved process.
2010-05-11 by sailingto
Tolga, I am VERY impressed with your PCB work. I've spent a good bit of time reading and looking at photos - those are some VERY good double sided boards. I like your method of making the vias - I have some tiny rivets I use the same way.
I sure wish I had found your website back when I first started fooling with PCB - Your idea on drilling first, then putting the transfer on to aid in lining up holes is something I will try. I don't have a CNC to drill with.
Thanks for the good ideas and webpage.
Ken H>
Ken, thanks, I am glad you like my work. It took me some time and quite a
bit of trial and error to get my PCB making to this stage. There's still
quite a bit of room for improvement though, especially with the soldermask
technique I am sure I can get better, more durable results. I should also
get a scanner to get better images of the PCBs.
For the vias, you may have noticed in the later photo (second link in my
e-mail) that I've actually soldered the vias (in contrary to the photos in
the original page). Without soldering, there are reliability issues,
especially after the board goes to the oven for soldermask curing (due to
thermal expansion perhaps?). After soldering, no problems at all, very
reliable. I'll update the page soon to reflect this.
I am drilling the board first, because I have a CNC. That way it makes
sense. How will you know where to drill the holes without a CNC? Or do you
plan to get one? Perhaps I am missing something.
-Tolga
> use the same way.
> Ken H>
2010-05-11 by Kerry Wentworth
I also use a CNC machine to drill holes. I have an old XY stage that
was given to me, and I built a Z stage that drives a Dremel. I'm using
Allegro chips, A3955 and A2919 and running the voltage at ~26V. I get
good torque and speed. I use the microstep feature to drop the current
when not moving, to 10-15%. Even with a light table, I was never able
to get the pattern to line up with the holes anywhere near as well as
you do. I wrote some software that allows me to jog to 3 corners of the
pattern and translate the hole coordinates to match, so now I transfer,
drill and etch. I'm getting much better results. My drills may not be
sharp enough, because if I etch then drill, the pad on the bottom tends
to lift. But they are tough. During debug, signals got mixed up, and
the XY stage took off while the drill was at the bottom, and it milled a
slot in the board rather than break. It was a .035 drill. ;)
I also like your via method. I tried it in a vise on a defective board,
and the first try was perfect! The 2nd and 3rd were less perfect, the
wire tend to push to one side of the board and all of the peening occurs
on one side only. It takes a bit of care to get both sides to peen over
adequately, but it can be done, and the results are worth it.
Kerry
For the vias, I'd suggest to make the via hole a really tight fit. Then, it
becomes more difficult to put the wire in the hole, but the wire does not
slide all the way to one side, and the results become consistent.
I've experienced the pads lifting issue myself and it's usually because the
drill is not sharp enough, like you said. I've thought about the 3-corner
registration method you've mentioned, but I was not sure I could get it to
work accurately enough. But now suddenly it seems like a good idea... :)
Probably much better than fiddling with printout scale factors to get a good
match. I might try it next time.
On Tue, May 11, 2010 at 4:46 PM, Kerry Wentworth <
> Kerry
> > http://retromaster.wordpress.com/pcb-making/.<http://retromaster.wordpress.com/pcb-making/>Just go down to the soldermask
> easily.
Well, not sure if drilling first will work or not, my idea was to print drill pattern on thin paper so holes 'n vias could be seen from back side, put TT paper on one side of PCB, run thru laminator once to stick paper in place. That would cause the drill pattern of all holes to be visible, then drill thru this thin paper.
With all the holes drilled, I was hoping lining up both sides of TT paper to the existing drilled holes would improve hole registration. Currently my double sided boards have most of the traces on one side, with only a few on the other side. This keeps the holes to a minimum.
As I write this, I'm not sure it will work - maybe I'll get to try later this week.
Ken H>
I think it could work, but it might be difficult to prevent the drill bit
from slipping.
> you
> this week.
> Ken H>
2010-05-11 by Harvey McRae
I have made a little tin template for my little PCB's I bend the one edge and one end to act as a guide, place the pcb into the corner .... go to my little dremel drill stand, and within a minute or two (I'd say a minute) I have all 20 + holes drilled. My tin template was the top of the vegetable can that we had for lunch.. Remember my board is only 1x 1.5 inches.. I drilled ten night before last, with all the change of pieces in less than 15 minutes.
Harvey L. McRae
838 McKenzie Rd.,
Kelowna, B.C. V1X2B3
Web: www.harriscreekcentral.webs.com
Sent: Tuesday, May 11, 2010 9:26 AM
Subject: [Homebrew_PCBs] Re: Printing on a solder mask
Ken H>
2010-05-12 by Donald H Locker
Hi, Ken.
Good idea. How about going one step further - print an annulus centered on each hole, do a TT to the board, remove the paper and drill through the centers of the annuli? No need for thin paper, and you can use acetone to strip the hole pattern before transferring the traces to the board.
Just a guided-randomness thought.
Donald.
> do you
> later this week.
> Ken H>
2010-05-12 by sailingto
> Good idea. How about going one step further - print an annulus >centered on each hole, do a TT to the board, remove the paper and >drill through the centers of the annuli?
This is getting off topic of solder mask:
After posting and thinking on it some I had come up with the same idea - do a light TT then drill thru that, clean board good, then a standard TT with traces for etching.
I'm not as sure now - the TT paper I use is totally opaque preventing the holes from showing thru to line up with. I think my past method of drilling just a couple of guide holes is plenty. One change for double sided boards I wish to try is place top paper on board, make one pass thru laminator to stick paper to copper. Then drill a couple of guide holes, put bottom paper to board using the guide holes, then pass thru laminator for solid TT. After etching, then drill holes.
I've got a board to make this week - we'll see how it goes.
Ken H>
2010-05-12 by micro_minded
Amazing work you have done, got me lookin for some of this glass paint. Turns out I can get any color they make in a 45ml jar for $5 at a local framing and art supply store.
Now I gotta get an aquarium pump and make a cheap airbrush and run some tests.
For anyone else interested here are some good pics: (not mine)
http://dc220.4shared.com/img/287468073/eb7cf589/8d595cd12f0cfff9846a1a2b710af6.jpg?rnd=0.039624984953933406&sizeM=3
http://dc220.4shared.com/img/287468074/7518602a/6f30e7c2e89f6575f3b97102893a7d.jpg?rnd=0.5840545487154954&sizeM=3
http://dc220.4shared.com/img/287468070/7275a433/27e0b0340c384e8520cb5238854dc9.jpg?rnd=0.3785841829252953&sizeM=3
If I can get results like that I will be plenty happy. Makes me wonder though if this paint can be injected into an ink cartridge and be printable. I know nothing if modding inkjets or how think their inks are. Anybody comment?
2010-05-13 by Tolga Abaci
I am not sure if the paint would work in an inkjet head. It is water-based,
I guess that's good. On the other hand, it's quite thick. Maybe if it's
thinned enough and printed in several layers it would work. You need to have
a fairly thick layer of this paint to get it work well as a soldermask.
For me, this method was quite attractive for two reasons: First, the paint
is cheap and available everywhere. Second, I already got the toner transfer
process working well, and this is quite compatible with it, it was a mere
extension.
Right now, it looks like curing the paint in two steps is the key... The
first cure (low temp - 120C) gets the paint strong enough to resist solvent,
but not too resistant so that the solvent would remove only the toner-masked
areas. The second cure (high temp - 160C) really fixes the paint in place
and makes it solvent resistant.
> tests.
> comment?
2010-05-13 by micro_minded
Have you tried ramping up the temp to 220C to see if the paint can withstand reflow temperatures?
I have moved away from PTH design and onto SMT only and have had difficulty with paints, toners and reflowing. I use the pulsonix transfer setup and it works great but if you use toner as a soldermask or even as a component layer it melts/burns and can run into solder joints and ruin things. Hopefully this paint will stay in place and not liquefy.
I'm planning on going out to grab some in a few hours and do some testing this weekend with fully fabbed boards and liquid tin at the end.
Anyone know of a cheap way to make an airbrush? I don't have a compressor but I did find a $26 airbrush that might work:
http://www.kmstools.com/badger-model-250-airbrush-set-73
> extension.
2010-05-13 by R. Ian Lee
"Anyone know of a cheap way to make an airbrush?"
Try in the toy dept at Walmart or other craft store that has modelling
supplies. You can get a cheap airbrush that runs off canned air. Been many
years since I've bought one, but I'm thinking you can probably get the whole
setup for under $30.
2010-05-13 by Jack@coats.org
I've never tried ramping the temperature that high, since I always solder
manually. I remember seeing this paint burn (to a darkish brown color) too,
but I do not know how high the temperature was since I wasn't monitoring it.
Good luck...
> water-based,
> have
> paint
> transfer
> > extension.
> solvent,
> toner-masked
2011-08-08 by abuakif
I did try using toner transfer technique (laminator + magazine) but my drill stand is not really fixed. I am thinking on getting the Proxxon later. In Malaysia, all the tools are probably a lot more expensive than the one in the States (I used to live and studied in St Louis for almost 10 years back in 1995 - 2001).
Anyway, I just came back from a hardware store getting a airbrush compressor and just ordered Pebeo Vitrea 160 from Kuala Lumpur. Also, I just purchased an oven. These few days will be focused on getting the solder mask and silkscreen using the technique described by Retromaster.
> Harvey L. McRae
> 838 McKenzie Rd.,
> From: sailingto
> Ken H>
RE: [Homebrew_PCBs] Re: Printing on a solder mask
2011-08-08 by Boman33
An alternative to a regular or specialized drillpress is to buy a small air
grinder for 1/8" bits. It has very high RPM, about 50,000 and perfect for
the carbide drill bits. Attach it to a small linear precision slide, cheap
on eBay, and you have the basis for a very accurate and efficient system.
I built one about 20 years ago and I added an air operated cylinder to
drive it from a footswitch. I also set up a laser pointer to make it even
faster to drill. The grinder is only about $ 22 from Harbor Freight. See:
http://www.harborfreight.com/air-tools/grinders/1-8-eighth-inch-air-micro-di
e-grinder-47869.html
Bertho
From abuakif Sent: Monday, August 08, 2011 06:59
in 1995 - 2001).
2011-08-08 by Andrew Leech
I have tried pre-drilling boards in the past, but unless your drills are
exceptionally sharp (mine weren't, I was using HSS) you get a little bit
of burring around the edges of your holes. Any little disturbance here
is enough to stop the transfer sticking around the holes, so it meant a
lot of touch ups.
My preferred method of double sided registration is to print both sides
of the layout on the same bit of paper with a 2mm gap between then, then
simply fold the paper over the edge of the board. I had an extra border
printed around the board about 2 mm off the edge of the actual artwork,
and peeking under the edges of the paper after folding lets you sight up
the borders pretty easily to ensure they're lining up. It took a little
practice but I found it incredibly repeatable without any extra drilling
steps etc. Haven't done any for some time but for a period I was doing
on average 3-5 boards a week this way.
Andrew
> Retromaster.
> <mailto:Homebrew_PCBs%40yahoogroups.com>, "Harvey McRae" <hlmcrae@...>
> > Harvey L. McRae
> > 838 McKenzie Rd.,
> > From: sailingto
> Or do you
> later this week.
> > Ken H>
2011-08-10 by abuakif
Bertho,
I just purchased my rather expensive Airbrush gun along with non-oil based compressor. The thing got really hot and shutted down when I worked with Pebeo Vitrea paint. Now I start seeing the viability of your suggestion! Anyway, I had spent $200 for this cheap, unreliable compressor.
Tun Zainal
> Bertho
> in 1995 - 2001).
2011-08-10 by Boman33
Try to bring the compressor back since you just bought it. It ought to work
well.
Bertho
From: abuakif Sent: Wednesday, August 10, 2011 08:52
Bertho,
Tun Zainal
air
> Bertho
drill
back
> in 1995 - 2001).
compressor
purchased
