Best Way to Cut PCB
2010-05-07 by Frank P
Index last updated: 2026-03-30 17:29 UTC
2010-05-07 by studleylee
--- In Homebrew_PCBs@yahoogroups.com, "Frank P" <qz9090@...> wrote:
> There has been a lot of discussion centered on the laser toner transfer methods but how do you folks cut your copper clad sheets?
> Thanks.
2010-05-09 by Frank P
--- In Homebrew_PCBs@yahoogroups.com, "studleylee" <indigo_red@...> wrote:
> I use a harbor freight shear/bend/roll thing that I shimmed to have
> a steeper cutting angle.
> http://www.harborfreight.com/30-inch-shear-press-brake-and-slip-roll-5907.html
> if you wait for sales, I got mine for about $380
> smaller version:
> http://www.harborfreight.com/8-inch-bench-top-shear-brake-90757.html
> > Thanks.
2010-05-09 by sailingto
2010-05-09 by Simao Cardoso
>Besides i own 3 types of table saw's never cross my mind using them to
> Thanks for your input but you solutions seem a bit pricey. There must
> be another way.... ?
2010-05-09 by Harvey McRae
Sent: Sunday, May 09, 2010 12:45 PM
Subject: [Homebrew_PCBs] Re: Best Way to Cut PCB
Studleylee,
Thanks for your input but you solutions seem a bit pricey. There must be another way.... ?
> smaller version:
> > Thanks.
Sent: Sunday, May 09, 2010 2:10 PM
I use a HF paper cutter - this is the one I use:
http://www.harborfreight.com/12-inch-x-9-3-4-quarter-inch-paper-cutter-9805.html
I move the PCB out to mid ways and it cuts pretty good up to .062", but the .032" is better. I wish I had got this one - it's larger and - I think it would have cut the .062" with less pressure:
http://www.harborfreight.com/18-inch-x-15-inch-paper-cutter-90874.html
This cuts about as well as anything going - MUCH less hassle than saws and such like. The shear listed before would be my choice, BUT for nearly $400 vs $13...... Hard choice.... well, maybe not.
Ken H>
2010-05-10 by sailingto
2010-05-10 by Andrew
> Thanks.
2010-05-10 by Harvey McRae
Sent: Sunday, May 09, 2010 6:02 PM
Harvey, you are correct - the PCB section that is cut off does not do well at all, unless it's pretty large - couple of inches maybe?
Most all my boards are at least 1" to 3" in width, and that tends to cut off pretty good, but cutting a thin slice will just curl.
If I had to do 15 or 20 boards I think I might opt for a table saw myself - being sure to use a very fine tooth carbide blade.
In the PCB cutoff thread last week there was a really nice looking tiny table saw using diamond blade that looked like it'd do the trick.... If I needed 20 boards I think I'd seriously consider looking at a commercial offering.
Ken H>
2010-05-10 by idbruce
> Thanks.
2010-05-10 by rlspell2000
> Thanks.
2010-05-10 by Frank P
> Ken H>
--- In Homebrew_PCBs@yahoogroups.com, "Harvey McRae" <hlmcrae@...> wrote:
> I just required 20 (1 x 1.5 inch) PC Boards. I fully polished the larger piece....I have a regular size table saw, which I put the finest blade that I own in place. I set the 1 inch guide, took a piece of 1/8th masonite and cut through this to make a new base.... I now cut all my 1 inch strips.... Reset the guide for 1.5 inch and cut the strips into 1 1/2 pieces. The edges were a little rough but I just run them past my grinding wheel to take the corner off. I cut these with the copper clad side facing up.....I think my next attempt will be copper side down. In fact my last couple of cuts I made face down and they were not near as rough.
> Carefull on the fingers, I realize I am working very close to that saw blade.. Remember fingers cut even better than a PC Board.. They even leave more of a mess..
> I too am watching these answers, as I am open to suggestions for a better way than what I have..
> Cheers.
> Harvey L. McRae
> 838 McKenzie Rd.,
> Kelowna, B.C. V1X2B3
> Web: www.harriscreekcentral.webs.com
> From: Frank P
> Studleylee,
> > smaller version:
> > > Thanks.
> Ken H>
2010-05-10 by Stefan Trethan
On Mon, May 10, 2010 at 8:53 PM, Frank P <qz9090@...> wrote:
> I wonder if MicroMark sells small table saws?
2010-05-10 by Ian
> > Ken H>
2010-05-10 by Henry Liu
> Ken H>
Sent: Monday, May 10, 2010 11:50 AM
Harvey,
On one webpage, I saw a person cutting perf board with a dremel fitted with a cutting wheel and placed in a vise. The dremel was mounted horizontally so the blade was vertical.
This might be a feasible approach, but the cutting was done free hand. I think a jig formed like a tablesaw to support the PCB board would be a better solution.
But, of course, there must be a more efficient way.... ?
> Cheers.
> Harvey L. McRae
> 838 McKenzie Rd.,
> From: Frank P
> Studleylee,
> > smaller version:
> > > Thanks.
Sent: Monday, May 10, 2010 6:29 AM
Okay this is my first post. After trying several different methods with undesirable results, I finally tried something I read about on someone elses post elsewhere. For those of you who have a table saw, try using a metal cutting abrasive blade. After cutting pcb, use fine file to remove excess debris. This method worked well for me with satisfactory results. However I am thinking of creating a miniature table saw that uses a dremel rotary tool with a 545 Diamond Cutting Wheel. I believe this would be the perfect solution, but I have not tried it yet.
> Thanks.
2010-05-11 by James
>I use a few different methods. When I have time, I go to my friend's machine shop and use the sheetmetal shear, obviously this isn't an option for everybody. I've also used a utility knife with a straightedge to score the board about halfway through then snap it off and sand the edge smooth. When I'm making a small cut, I clamp the PCB between two scraps of wood in a vise and use a hacksaw guided by the wood to make a straight cut. This also requires a bit of sanding to true up the edge.
> Thanks.
2010-05-11 by grantfair2001
> Thanks.
2010-05-11 by Andrew
--- In Homebrew_PCBs@yahoogroups.com, "Ian" <ian@...> wrote:
> Unfortunately, I don't have one at the present to test with but I would think that a band saw would yield better (cleaner) results and would be much safer than a table saw. Home Depot sells a small 9" model for $119 that would be perfect for this task.
> http://www.homedepot.com/h_d1/N-5yc1vZ1xg3/R-100082549/h_d2/ProductDisplay?langId=-1&storeId=10051&catalogId=10053
> Ian
> > > Ken H>
2010-05-11 by bebx2000
>Try a 4" diamond saw ...
> Thanks.
2010-05-11 by James
>Can you get carbide tipped blades for it? FR4 PCB is murder on saw blades, you need something really hard or it will dull very quickly.
> Ian
2010-05-11 by Harvey McRae
Sent: Monday, May 10, 2010 9:14 PM
> Thanks.
http://tech.groups.yahoo.com/group/Homebrew_PCBs/message/25400
Baxter
2010-05-11 by Frank P
> Ian
> > > Ken H>
> Before you build your mini table saw, cut a few pieces by hand with the dremel.. I find that unless I'm running the Dremel tool at near top speed, it lacks on the power supply.. I don't think you would have enough power to do much cutting.
> Also doesn't Dremel have a little table saw attachment.? I think they do.
> Cheers.
> Harvey L. McRae
> 838 McKenzie Rd.,
> Phone - 250-765-1000
> Harvey's Cell - 250-808-4466
> From: idbruce
> > Thanks.
> Thanks.
Sent: Tuesday, May 11, 2010 2:35 PM
Harvey,
Thanks for your input.
Some of the more elaborate solutions (table saw, band saw, etc.) seem like a bit "over-kill" for me, if I am only making a PCB once in awhile.
I believe Ian suggested using a 545 Diamond Cutting bit with a Dremel tool.
If I needed a large quantity, I would agree with you, i.e. outsource it. Of course, that leads to another question, who do you order them from? ...but, I think that is another thread of discussion.
> Cheers.
> Harvey L. McRae
> 838 McKenzie Rd.,
> From: idbruce
> > Thanks.
2010-05-12 by Eddie Stassen
> So I decided to do some more research on the Internet on this subject
> and look what I found!!
> http://www.youtube.com/watch?v=61Q_6-cRua4
> <http://www.youtube.com/watch?v=61Q_6-cRua4>
> Cheap and easy....but I wonder if it would work on copper clad...?
> > Thanks.
2010-05-12 by Piers Goodhew
On 12/05/2010, at 6:02 PM, Eddie Stassen wrote:
> The subject of cutting pcb's seems to pop up frequently and probably
> should be addresses in a FAQ somewhere. I am always somewhat astounded
> by the number of expensive/complex solutions offered for such a
2010-05-12 by Andrew Villeneuve
On Wed, May 12, 2010 at 8:20 AM, Piers Goodhew <piers@...> wrote:
> Wandering a little off-topic, but I'll keep it brief.
> One of the interesting things about this group, in my short time in it, is
> the almost complete lack of consensus - from CAD software to etchant, to
> TT/pos/neg/dry/wet, right down to the type of glue to use in a tank, they
> all get about 7 well-argued opinions pretty much covering the full spectrum.
> The lack of an FAQ or wiki or something and the relatively narrow range of
> topics used to puzzle me, but it's becoming clearer now.
> PG
2010-05-12 by jamesmichaelnewton
>I experienced the same thing when I started reading! I couldn't keep all the different ideas straight in my head so I started building a wiki to organize it all. It's not totally complete, but it is a good start and has most of the common ideas. Please feel free to use the little form at the bottom of each page to contribute your ideas, or register and then "make this page YOURS!" to become a page editor if you like.
> One of the interesting things about this group, in my short time in it, is the almost complete lack of consensus - from CAD software to etchant, to TT/pos/neg/dry/wet, right down to the type of glue to use in a tank, they all get about 7 well-argued opinions pretty much covering the full spectrum.
> The lack of an FAQ or wiki or something and the relatively narrow range of topics used to puzzle me, but it's becoming clearer now.
> PG
2010-05-12 by Frank P
> relatively simple problem. Unless you are running a production setup or
> have lots of money to throw at an expensive shear, there is no reason to
> run to power tools for the solution. Since the vast majority of pcb cuts
> are straight, the score and snap method a still in my mind the best
> method - cheap, safe, easy on the tools, lungs and ears and little
> wasted material. The cuts come out fairly clean and a few swipes across
> a sheet of 150 grit sandpaper is usually enough for a very smooth edge.
> You can see the process in the first part if this video:
> http://www.youtube.com/watch?v=oP1Uw-lI7BU. The tool is a carbide tipped
> laminate cutter you can probably pick up at any hardware store, although
> a glass cutter or even a sharp blade could possible also be used in a pinch.
> For the occasional board that requires cutouts a mini hacksaw and a file
> does the trick.
> Just my 2c
> Eddie
> > > Thanks.
2010-05-12 by James
>There's so many methods that work with no clear winner as to what is "best". The important part is that you get acceptable boards. I experimented over time until I managed to get good consistent results with the smallest effort and lowest cost and have continued to refine, but it's far from the only way to do it.
> I agree, and I like that about this group. There's plenty of advise, but
> nobody assumes you're doing it wrong if you're not using their method.
> -Andrew
2010-05-13 by Piers Goodhew
> --- In Homebrew_PCBs@yahoogroups.com <Homebrew_PCBs%40yahoogroups.com>,
> > PG
> http://techref.massmind.org/techref/pcbs.htm
2010-05-13 by John McCormick
--- On Thu, 5/13/10, Piers Goodhew <piers@...> wrote:
Subject: Re: The FAQ, and maybe why there isn't one. Was Re: [Homebrew_PCBs] Re: Best Way to Cut PCB
Date: Thursday, May 13, 2010, 3:34 AM
I did look at the massmind site earlier. It didn't seem to have a lot of
wiki things that I'm used to like auto links, tables of contents, nice clean
syntax to easily autoformat posts, but I guess I should look again.
The main reason I haven't volunteered for such a job is that I think you
need to be prepared to put in at least a year (half a year) actually doing
it, and I try not to make commitments I'm not certain i can keep.
But continuing to think aloud, we seem to have less than 10 general topics,
a page with a bit of a summary and then a URL that finds recent messages
might be a workable solution.
E.g. Really roughly:
*Cutting PCB*
Methods include Score & Snap, shears and band/rotary saws (using the more
fine/metal cutting blades). Small PCB's can be effectively cut using score
and snap, or tinsnips (if smaller than the blade length). Larger boards can
be cut with larger shears among others. [mention commonly tried things that
don't work well?]
Search for forum posts mentioning "cutting PCB":
http://tech.groups.yahoo.com/group/Homebrew_PCBs/msearch?query=pcb+cutting&submit=Search&charset=UTF-8
But it works fairly well now: a newbie turns up, asks the same question, 10
well thought out answers arrive, several of them completely novel.
PG
On Thu, May 13, 2010 at 2:44 AM, jamesmichaelnewton <
> > PG
Be sure to visit the group home and check for new Links, Files, and Photos:
http://groups.yahoo.com/group/Homebrew_PCBsYahoo! Groups Links
2010-05-13 by Eddie Stassen
>Agreed, you would either have to cut a 2x8 inch strip off first (which
> Eddie,
> Scoring sounds easy but if you're trying to cut a 2 by 3 inch piece
> from a 8 by 10, I would think the corners might create some difficulties.
> This guy uses a hack saw and gets decent results...
> http://www.youtube.com/watch?v=bHUNmgFct1o&feature=related
> <http://www.youtube.com/watch?v=bHUNmgFct1o&feature=related>
> reason to
> cuts
> <http://www.youtube.com/watch?v=oP1Uw-lI7BU.> The tool is a carbide
> tipped
> although
> a pinch.
> file
> > does the trick.
> > Just my 2c
> > Eddie
> <http://www.youtube.com/watch?v=61Q_6-cRua4>>
> > > > Thanks.
2010-05-13 by jamesmichaelnewton
>Seriously? It's more important to you that the site be pretty than that it have relevant content? wow... whatever...
> Ya I agree no offense but that massmind website is terrible.
> There's a million poorly placed ads on it and is f-ugly...
> Google Sites has free wiki templates and hosting: http://sites.google.com/site/projectwikitemplate_en/The reason why that site has ads is that the ads pay for someone to maintain it. That's why it exists. There are very few saints in the engineering world. It makes just enough from those ads to pay my hosting bill and for the time I spend maintaining it.
> It would take 15 minutes to recreate all the info on massmind without the ads and have a true wiki style webpage faq.
> I would volunteer to just cut and paste info into a google webpage but I'm not an expert by any means.And yet you feel qualified to slam my efforts. Thanks.
> --- On Thu, 5/13/10, Piers Goodhew <piers@...> wrote:Nope, your right, it's a pile of shit. Just read above. But it's a pile of shit that works and has most of the /content/ and actual information that are important on it. To post something you would have to actually type or paste in your text, copy in the URL you wanted to reference (if there is one) and then depend on a human page editor (me) to link things and edit the page if it needed it. The horror!
> From: Piers Goodhew <piers@...>
> The main reason I haven't volunteered for such a job is that I think youYeah, I wonder why I bother.
2010-05-13 by Stefan Trethan
> --- In Homebrew_PCBs@yahoogroups.com, John McCormick <mcjonster@...> wrote:
> If you wanted to be a page editor, you would actually have to learn HTML. REAL HTML! That arcane "programming language" that people must go to school for years to understand. Instead of auto linking random words, you would actually have to type <a href="lcds.htm">lcd</a> so don't bother, start a wiki yourself instead.
> In fact, I doubt I will anymore.
> James.
2010-05-13 by mcjonster
--- In Homebrew_PCBs@yahoogroups.com, Stefan Trethan <stefan_trethan@...> wrote:
> I like simple HTML websites.
> I understand the concept of ads and accept them as a way to keep free
> information online.
> You have paid me personally a nice sum of that ad money in exchange
> for hosting some of my info about direct inkjet printing.
> That said, I still have to concur with the previous critics that your
> page has some very serious drawbacks. They are serious to the extent
> that I did not feel inclined to discover the other, no doubt very
> interesting, information located there.
> Some points I wish to list individually:
> * There doesn't appear to be any structure apart from a general
> sorting into topics, which are often not well named.
> * Topics make no attempt at all to be complete. Individual comments
> about one thing or the other seem to make up the content. Even if no
> detailed information is available at least there should be a list of
> all the common options. It is like someone wants to explain how to
> bake a cake, and all he talks about is how the icing is applied.
> * It is hard to see where the content ends and the ads and navigation
> elements start, because it is all one color and style.
> I am sorry, to me it is confusing and disorganized. My reaction to
> your site, in as few words as possible: "huh, what's that?".
> It's sad that you want to quit now, because this could have been a
> very good thing, but on the other hand I can't help but feel it was a
> bit of a wasted effort to start with if the majority of people can't
> get to grips with the website.
> Consider this, you have set this site up, you know every nook and
> cranny and it makes perfect sense to you. But we haven't. If you write
> a page for other people they should be able to use it.
> I hope you'll not dwell on the criticism too much, it's really not
> meant in bad spirit.
> I'd help with a FAQ or wiki, as long as I can get my head around it,
> hosting/moderation is stable and long-term, and an effort is made to
> somehow allow all the differing opinions about how to do things to
> co-exist.
> ST
> On Thu, May 13, 2010 at 5:37 PM, jamesmichaelnewton
> >> --- On Thu, 5/13/10, Piers Goodhew <piers@> wrote:
> >> From: Piers Goodhew <piers@>
> > James.
2010-05-13 by Derward Myrick
Sent: Wednesday, May 12, 2010 11:17 PM
*Cutting PCB*
don't work well?]
PG
> > PG
2010-05-13 by Jack@coats.org
><> ... JackWhatever you do, work at it with all your heart... Colossians 3:23
On Thu, May 13, 2010 at 7:49 PM, Jack@... <jack@...> wrote:
> A FAQ should, IMHO, have some semblance of order.
> Let me suggest...
> Intro: A quick overview of what/why/where/who/when we like/use homebrewed PCBs.
> Also, where to find the email discussion group (how to subscribe
> and un-subscribe) and its archives.
> Techniques:
> Design/layout:
> DIY by hand
> software
> 'copy and paste' (using or modifying others designs)
> Mechanical:
> additive vs subtractive techniques
> additive like via reprap, or laying down conductive
> material on an insulating substrate
> subtractive etching
> other or combined methods?
> Boards/materials used
> material, its properties, including chemical and temprature
> range/sensativity.
> rigid
> flexible
> fiberglass
> phenolic (sp)
> others
> single sided vs double sided
> VIAs
> rivets
> wires through holes
> plated through holes
> Resist methods
> drawing with resistive ink
> manual
> plotter
> photo resist
> inkjets
> laser resist papers
> laser resist on paper
> laser direct on PCB
> Etching
> etchants
> commerical
> DIY
> storage
> dry
> liquid
> concentrate
> reuse
> disposal
> nutralization
> recycling
> proper disposal methods (healthy and 'earth friendly')
> Silk Screen & solder resist to cover non-soldered areas
> Plating connections, include pro's, con's, relative pricing
> gold
> other
> Holes
> mounting
> via's (see above)
> component
> drilling
> by hand
> cnc
> Surface Mount compatable
> Compliance
> How to do things so that the files and resultant PCBs are viable
> for regulatory agencies.
> We want our FAQ users to understand their roll in making quality
> products. Much of this
> depends on where they are and use of the PCBs.
> Suppliers
> Group suppliers (discounts?)
> commercial
> list of commercial suppliers, generically what they sell,
> their phone numbers and web sites, and general market area
> (market areas are like North America, Europe, Asia,
> Central Americal, Africa, Middle East, South Americal, Austraila,
> New Zealand, etc, etc. Yes, I left a lot out, but this
> is just a thought, please modify as appropriate)
>><> ... Jack
2010-05-13 by Sebastien Bailard
On May 13, 2010 02:07:51 pm Stefan Trethan wrote:
> I think there are many good ideas in there.
> I'd like to put my notes about toner transfer (especially creating a
> laminator from used printer parts) and homemade drill stand somewhere.
> I used to host them on my own site, but the webspace no longer exists.
> Also I have a neat PCB holder for etching which I would like to
> document some day. It allows clamping boards without getting dirty.
> Four or five years ago I would have started the wiki, right now I
> don't think I can muster the dedication, after all I only make a board
> myself very rarely now, but I'd sure want to contribute, beats writing
> the same thing over and over here.
> ST
> > Let me suggest...
> > PCBs. Also, where to find the email discussion group (how to subscribe
> > Techniques:
> > Design/layout:
> > DIY by hand
> > software
> > Mechanical:
> > subtractive etching
> > range/sensativity.
> > rigid
> > flexible
> > fiberglass
> > phenolic (sp)
> > others
> > VIAs
> > rivets
> > wires through holes
> > Resist methods
> > manual
> > plotter
> > photo resist
> > inkjets
> > laser resist papers
> > laser direct on PCB
> > Etching
> > etchants
> > commerical
> > DIY
> > storage
> > dry
> > liquid
> > concentrate
> > reuse
> > disposal
> > nutralization
> > recycling
> > gold
> > other
> > Holes
> > mounting
> > via's (see above)
> > component
> > drilling
> > by hand
> > cnc
> > Compliance
> > Suppliers
> > commercial
> >><> ... Jack
> > Photos: http://groups.yahoo.com/group/Homebrew_PCBsYahoo! Groups Links
> ST
>> Let me suggest...
>> Techniques:
>> Design/layout:
>> DIY by hand
>> software
>> Mechanical:
>> subtractive etching
>> range/sensativity.
>> rigid
>> flexible
>> fiberglass
>> phenolic (sp)
>> others
>> VIAs
>> rivets
>> wires through holes
>> Resist methods
>> manual
>> plotter
>> photo resist
>> inkjets
>> laser resist papers
>> laser direct on PCB
>> Etching
>> etchants
>> commerical
>> DIY
>> storage
>> dry
>> liquid
>> concentrate
>> reuse
>> disposal
>> nutralization
>> recycling
>> gold
>> other
>> Holes
>> mounting
>> via's (see above)
>> component
>> drilling
>> by hand
>> cnc
>> Compliance
>> Suppliers
>> commercial
>>><> ... Jack
>This is exactly the sort of criticism that makes me nuts. Go look at
> information online.
> * Topics make no attempt at all to be complete. Individual commentsWhat? Sooo... if someone starts a wiki, and doesn't finish the entire thing in one whack, but just starts adding what is known and hopes for further content and assistance in the future, that makes the whole thing trash?
> * It is hard to see where the content ends and the ads and navigationFirst off, they ARE a different style. The color, I agree, is the same. If you make them a different color, people don't look at them.
> I am sorry, to me it is confusing and disorganized. My reaction toIt for damn sure is in a bad spirit and I'll tell you why: It would be one thing if you said: "You know, that site would be a lot better if you installed this style sheet on it, or if you set the font to X or the background to Y or if you added these categories or this outline or whatever" But you don't. You just say "it's bad" and you stop. You pretend to take time making a list, but the list also doesn't offer ANY advice on what to do to make it better.
> I'd help with a FAQ or wiki, as long as I can get my head around it,Bull Shit. It's been there for years, you've been invited repeatedly, I'm always open to specific suggestions for improvements. You just want an excuse to do nothing.
> co-exist.
2010-05-13 by Harvey & Betty McRae
Sent: Wednesday, May 12, 2010 10:00 PM
Subject: Re: [Homebrew_PCBs] Re: Best Way to Cut PCB
> Frank P wrote:
>> Eddie,
> is what I would nornally do), or otherwise cut a 2 inch notch first with
> some other means e.g. hacksaw and them score and snap along the 3" side.
>> reason to
>> cuts
>> tipped
>> although
>> a pinch.
>> file
>> > does the trick.
>> > Just my 2c
>> > Eddie
>> > > > Thanks.
> Photos:
2010-05-14 by Kerry Wentworth
> This is exactly the sort of criticism that makes me nuts.Amazing, isn't it? You make Strawberry Shortcake for everybody, and
2010-05-14 by Stefan Trethan
> Specifically, what topics are not well named?One example, Holes.
> First off, they ARE a different style. The color, I agree, is the same. If you make them a different color, people don't look at them.Does it occur to you that I might not be interested to actually read
> Does it occur to you that the ads might have value? That people advertise things that relate?
> I have tried the scoring method, but I must be doing something wrong, as
> mine always break back under the copper cladding.
2010-05-14 by Harvey & Betty McRae
Sent: Thursday, May 13, 2010 10:21 PM
On Thu, May 13, 2010 at 10:49 PM, jamesmichaelnewton
One example, Holes.
If you click the "holes" or "drill holes" you get the same scattered
comments about installing copper tubes as vias. That's not what I
understand as holes, or drilling holes, that's homebrew methods for
plating holes maybe. There isn't a bit of information about actually
making the holes.
the ads, or at least I might want to know I am reading a commercial ad
instead of the page content? The ones to the right are fine, but for
example the line inserted on top looks just the same as your links.
Maybe you should check your own copyright notice: "©2010 These pages
are served without commercial sponsorship".
Tricking people into clicking on ads is not commercial sponsorship?
You aren't interested to accept any criticism as maybe having a valid
point, but you want others to contribute to a flawed base.
This isn't something new, I had exactly the same thought when you
added the inkjet content years ago. I kept quiet and hoped the site
would improve, or maybe it was just me that didn't understand it, but
it didn't, and it isn't just me.
Anyway, now you know why I, and probably a few others, don't want to
actively contribute to your site. You've actually given me money to
host some stuff about inkjet printing, but you could have way more,
and all for free, if the environment was just a little more inviting.
Just look at the archive of this yahoo group too see how much people
will give.
ST
On Fri, May 14, 2010 at 8:16 AM, Harvey & Betty McRae <hlmcrae@...> wrote:
> I am a relatively new member.. I have enjoyed this site a great amount. I looked at another site, and I did not feel it was what I was wanting. I made a comment that a ceertain thread had been beaten to the ground, and I would like to see something else on the menu.. I was politely told that no one was twisting my arm to keep me on board, and if I was not happy then I should "Unsubscribe" which I did.
> I feel this thread has been chewed, spit out, and rehashed far to long.. I say to you Stefan, no one is twisting your arm to stay with this group, and if you feel it is so worthless then follow the instructions that was given to me by the other group.
> If your not that dissatisfied, that you want to leave the group, then shut up, sit down and quit making life misserable for the everyone else.
> That's my thought on this thread.
> Harvey ..
> From: Stefan Trethan
> One example, Holes.
> making the holes.
> will give.
> ST
2010-05-14 by Eddie Stassen
> Same here.
> I always thought they might use different PCB material than I tried.
> Also there is the question about how deep one needs to score the boards?
> ST
> On Thu, May 13, 2010 at 10:55 PM, Harvey & Betty McRae
2010-05-14 by Leon Heller
> I use standard FR4 0.8 or 1.6mm s/s and d/s. I tend to apply a lot ofThat's what I do, as well. I put it in a vice to snap it, and I get
> pressure and make 3 or 4 passes so I am through the copper and well into
> the board. On the other side a bit less is needed, juts make sure you
> are through the copper if double sided and have a decent scratch in the
> board. I know thats not very scientific description, but you get a
> 'feel' for it after a few boards
> I am not sure how well this works for other PCB types. I have some old
> phenolic board and will give it a try.
> On 14/05/2010 09:42, Eddie Stassen wrote:Pardon my ignorance, but what is FEC-1?
> quite a clean break. It only needs a bit of cleaning up with a file.
> It's tough stuff, though. I don't use FR4 very often, FEC-1 is *much*
> easier to cut.
> Phenolic is easier.
> Leon
2010-05-14 by Piers Goodhew
>Sorry, I meant CEM-1.
> I suspect phenolic, although soft, may have problems with
> cracking/chipping.
2010-05-14 by jamesmichaelnewton
>You have combined two areas of complaint and so avoided both objections I raised about those complaints.
> One example, Holes.
> making the holes.
> > First off, they ARE a different style. The color, I agree, is the same. If you make them a different color, people don't look at them.Seriously? If you can't see "ads by google" on each ad block, then you are pretty darn easy to trick. What do you need? a flashing red outline?
> You aren't interested to accept any criticism as maybe having a validI've ALWAYS accepted any SPECIFIC and CONSTRUCTIVE criticism. If all you can say is "It's fugly" or "it doesn't make sense" then you can piss up a rope.
> This isn't something new, I had exactly the same thought when youFine. go start your own. or don't use mine. But STOP PUBLICLY SLAMMING MY SITE WITHOUT OFFERING ANY SUGGESTIONS FOR IMPROVEMENT.
>IN WHAT /FREAKING/ WAY? You continue to bash my site and yet you absolutely refuse to offer ANY suggestion for how to make the "environment" a little more "inviting" whatever that means.
> will give.
> ST
2010-05-14 by alienrelics
>I agree. Although the Massmind site may not be perfect, if people don't like it, offer to help!
> people complain that you used frozen strawberries. Well, I appreciate
> your efforts. I think it's a very good start.
> Kerry
2010-05-15 by jamesmichaelnewton
>Erk... My bad... I was confusing "Stefan" with "Steven" for a moment there.
> I could say any number of nasty little things about your group or your leadership of it, but I've always been supportive of your decisions and your style, even when I didn't agree with it.
2010-05-15 by alienrelics
--- In Homebrew_PCBs@yahoogroups.com, "Harvey & Betty McRae" <hlmcrae@...> wrote:
> I guess all I can say is I'm "SORRY" for jumping the gun.
> It is annoying to see anyone walking all over an administrator, who is donating his time, and then not willing to take part of his load.
> I guess what caught me off guard was why was a totally different thread from the other group brought into this group to be discussed.????
> I have enjoyed this group, and feel there is much valuable information to be gleaned from all the members.
> Harvey
2010-05-16 by Ben L
> There's been a lot of discussion, quite recently, about this as well. My vote is for a metal-cutting bandsaw and fine-tooth metal-cutting blade -- about $160 from Harbor Freight (on sale or with 20% coupon). Yes, that's a lot to pay just to cut PCB, but if you have any need to cut metal on any sort of regular basis, this will work for both tasks.Just standard blades will wear fast cutting FR4.
2010-05-16 by Ben L
> Ian
> > > Ken H>
2010-05-16 by Ben L
>That should work good, also being a wet saw will keep down the dust.
> Now you have given me a new idea.......Try a 4" diamond saw ...I have one of these wet saws in my shop but never thought to try that avenue. I have the blade that litterly has no teeth, that cuts through cement brick and blocks. Soon as I get to my next cutting project that is what I will try..
2010-05-16 by Bill
Date: Saturday, May 15, 2010, 10:26 PM
Not sure why a band saw would be safer than a table saw, they both have blades that can cut you.
If you build a panel jig for the table saw should be safe easy way to cut. Dry/Wet Diamond blades are easy to fine that will fit the table saw, the 7-1/4" blade is what I have use on my 10" table saw. That is the cleanest, most accurate way to cut FR4. I have a Kepro shear but get more accurate cuts with the table saw.
Ben
> Ian
> > > Ken H>
2010-05-16 by Harris Creek Central.
>My clinic went over big time. 8 members out of ten present.
> !!!!!!!!If I needed 20 boards I think I'd seriously consider looking at a commercial offering.!!!!!!!!!!
> I'm putting on a little clinic on etching boards for our model railroad group. Although I have been aware of having to put on this clinic for two months, I dilly dalied around until last night when I am scheduled to do this clinic on this coming wednesday night...
> Further to this, I am making up a little parts bag, and each person will etch his own board.....(I have pre-drilled the holes) then each one puts the parts together solders them in place, and hopefully after a couple of evenings working as a group, each member will go home with a "working" model of a dual flashing light.
> Pray for me for Wednesday night, that all goes well.. This is the first clinic I have done on this subject.
> Harvey L. McRae
> 838 McKenzie Rd.,
> From: sailingto
> Ken H>
2010-05-17 by Andrew
> What would be better than a band saw is a table saw or bench model table saw with a Dry/Wet Diamond Blade, set up good dust collection with a fine filter and also protect the motor air intake with a filter to keep from it sucking in the fine dust.
> Ben
2010-05-17 by sailingto
> My clinic went over big time. 8 members out of ten present.Congrats on the successful clinic - isn't teaching/learning LOTS of fun?
2010-05-17 by Leon
2010-05-17 by Stefan Trethan
> I prepared the boards, predrilled the holes, plus marked the lines with the Markers for etching resist.
> Etching solution was prepared in little baby food jars, so basically three people could etch their board in the same little jar. (Preheated to warm to the touch) Every board turned out excellent. The components were handed out, and a careful eye watched to make sure all the little legs got stuck in the right holes. After all components were in place we called it quits for the night but each one took home a homework project to solder the items in place.
> Once complete, each member will have a dual flashing unit for things like a police car, ambulance, fire truck etc..
> Here is just one of my comments recieved from one member:
> Good morning Harvey.
> Thanks for a great study! I always thought that a special kind of varnish is needed to protect the copper from being eaten away by the acid. A simple felt marker makes the whole process a lot easier.
> So all in all we had an excellent group reaction.
2010-05-17 by Harvey & Betty McRae
Sent: Sunday, May 16, 2010 6:29 PM
Subject: [Homebrew_PCBs] Re: Update on my clinic.
Ken H.
No virus found in this incoming message.
Checked by AVG - www.avg.com
Version: 9.0.819 / Virus Database: 271.1.1/2878 - Release Date: 05/16/10 11:26:00
2010-05-22 by Donald H Locker
> lot of
> nice clean
> you
> doing
> James.
> Photos:
