Resist ink pens
Resist ink pens
2010-04-28 by andrewmv@ymail.com
I'm often finding that my toner transfer boards are ALMOST usable, but have a few trace breaks that need to be touched up by hand before etching.
I've seen it said several places that ordinary Sharpie markers make suitable resist-ink for this purpose (I actually remember buying an old Radio Shack home PCB kit that came with a Sharpie and called it a "resist ink pen").
I recently tried this using a Sharpie-brand "ultra fine-point, super-permanent ink" pen, but the FeCl ate right thought the ink.
Has anybody had lucks using Sharpies as resist-ink?  Are there any recommendations on something better?
Re: [Homebrew_PCBs] Resist ink pens
2010-04-28 by Tony Smith
I think it's the red ones that work.
Tony
2010-04-28 by Kerry Wentworth
They say that WhiteOut works well, but I've never been able to get fine
enough lines with it.  If it's only a couple of spots, you could try
masking it off first.  For that matter, you could lay some tape down and
cut away what you don't want masked with an Exacto knife.
Sharpies work, but you need to get a thick layer.  Dab at it to get the
ink flowing.  This also make fine lines difficult.
Kerry
Kerry Wentworth
The Skunk Works
85 N Main St
Boscawen, NH 03303
603 753-8933
2010-04-28 by Leon Heller
Staedtler makes very good ones. I used to use them.
Leon
Leon Heller
G1HSM
2010-04-28 by Andrew Villeneuve
> ink pen").
> Leon
> Leon Heller
> G1HSM
What particular Staedtler pens did you use as resist-ink?
-Andrew
RE: [Homebrew_PCBs] Resist ink pens
2010-04-28 by Roger Blair
I am doing double sided etching of Brass, Beryllium Copper, and Phosphor Bronze to make small parts, and I find that when using a
Sharpie or Staedtler, a quickly stroked line that is semi-opaque will resist FeCl for only a few minutes. However, if carefully laid
down so as to be fully opaque, will resist for over an hour. CuCl seems to penetrate more quickly. Just my experiences.
Roger
From: Homebrew_PCBs@yahoogroups.com [mailto:Homebrew_PCBs@yahoogroups.com] On Behalf Of andrewmv@...
Sent: Wednesday, April 28, 2010 07:17
Subject: [Homebrew_PCBs] Resist ink pens
before etching.
2010-04-28 by Dave Bobb
Yes, the ones we use at work are "red" label black sharpies. Ore
specifically, industrial acid resistant.  It takes forever to scrub
these off with 91% alcohol.
On Apr 28, 2010, at 10:21 AM, "Tony Smith" <ajsmith@...>
> Tony
Re: Resist ink pens
2010-04-28 by rlspell2000
Very poor luck with the sharpie pens, they "sort of" work, even the special red ones only "sort of work". They come off in the tank. (bubbling HCl/H2O2)
Best I have found is nail polish...
Even better is the toner, so most times it easier to reprint and re-transfer the board than to fix a bad one.
> Sent from my iPhone
> > Tony
2010-04-29 by Stefan Trethan
Staedtler lumocolor permanent OHP pen red.
Also get the refill tank, you need to lay down a solid line which
works best with a fresh pen.
Recently I came across a really fine line paint marker, Edding 780.
<http://www.nierle3.com/pic/4341p.jpg>
I got the white one to mark black plastic. It lays down a thick laquer
that doesn't come off with alcohol. I really think that would work
well, and unless other paint markers the line is reasonably thin,
under 1mm.
ST
> -Andrew
2010-04-29 by LEON HELLER
Sent: Wednesday, 28 April, 2010 18:18:06
Subject: Re: [Homebrew_PCBs] Resist ink pens
> ink pen").
> Leon
> Leon Heller
> G1HSM
-Andrew
Lumocolor Permanent.
Leon
2010-04-29 by michael tenore
Use fine piont CD/DVD Marker pens available at staples or even at the statioary aisle at the large pharmacies.
Mike
--- On Thu, 4/29/10, LEON HELLER <leon355@...> wrote:
> From: LEON HELLER <leon355@btinternet.com>
> Date: Thursday, April 29, 2010, 4:41 PM
> ____________ _________ _________ __
> From: Andrew Villeneuve <andrewmv@gmail.
> com>
> To: Homebrew_PCBs@
> yahoogroups. com
> On Wed, Apr 28, 2010 at 12:44 PM, Leon Heller <leon355@btinternet.
> com>wrote:
> > On 28/04/2010 15:17, andrewmv@ymail.
> called it a "resist
> > ink pen").
> "ultra fine-point,
> thought the ink.
> > Leon
> > Leon Heller
> > G1HSM
> -Andrew
> Leon
2010-05-03 by Andrew Villeneuve
This is actually exactly what I was using the first time around with
terrible results.
I've done a little experimentation, and gotten the industrial fine-point
sharpie pens to work perfectly - they seem to resist as well as the toner.
I found I was making two mistakes:
1) As has been pointed out by just about everybody on the list, I was
marking too lightly. Even a slightly darker line makes a significant
difference. I've gotten in the habit to retracing all my resist lines after
the ink dries - it doesn't take more than a few seconds.
2) I was originally etching using the "tankless" method of putting a few
tablespoons of room-temperature FeCL on a sponge and rubbing the copper off
the board.  This actually does work as advertised, but ONLY ON TONER - the
friction rubs every bit of resist ink off the board well before the etching
is complete.
It's also remarkably tedious and time consuming - I don't believe this
method is worth the trouble.
Using a simple hand-agitated etching tank, I couldn't tell the difference
between sharpie-resist and toner-resist.
-Andrew
> Sent from my iPhone
> On Apr 28, 2010, at 10:21 AM, "Tony Smith" <ajsmith@...<ajsmith%40beagle.com.au>>
> > Tony
2010-05-03 by Leon Heller
Many years ago I used cellulose paint as resist, thinned somewhat and
painted on the copper with s fine paintbrush. I used a centre punch to
mark the holes through the pattern drawn on graph paper. I then put a
small blob of paint on the punch marks and joined them up. The paint was
very effective as a resist, and was easy to remove.
Leon
Leon Heller
G1HSM
2010-05-03 by Bob Butcher
I have used several similar ideas, some with more success than others. One technique I use sometimes is to polish the copper board with a Schotch Brite pae, then spray paint the entire board with spray can enamel (Krylon or similar). Then I locate the holes and use my cad program to draw outlines around the traces that are connected together, making each net an "island". I use a scribe to remove the paint in thin lines between islands, then etch only the copper exposed in the thin lines. This uses very little etchant since it leaves nearly all the copper on the board. This technique is quite time consuming drawing the lines to isolate the islands, but on a fairly simple board it works well. I will post a sample file online to help clarify the technique.
Years ago I had access to a CNC laser system that could be programmed to burn off the paint between traces, and that worked well, but the average hobbyist won't have that luxury!
I have also used paint pens rather than the Sharpie ink pens to draw traces on the board. These can be purchased from graphic art stores, such as Aaron Brothers, and are good for drawing fine lines. The paint resists etchant well, but takes a while to dry, so it takes longer to draw the lines on the PCB.
I have not had much luck with toner transfer and usually cannot get it to release from the dry transfer sheet. This is probably due to my Brother laser printer which others have reported does not work well. I think the toner used in  Brother printers has too high a melting point or something similar. I had problems with an HP laser printer drawing lines made up of tiny dots that were not quite touching each other, resulting in a circuit board trace that looked like a screen, usually with breaks at numerous locations.
Bob
Bob,
I've seen several tutorials on the laser engraving approach, which seems to
work very reproducibly.  Naturally, these all came from shops that had
access to an industrial laser engraver for other reasons.
small-shop laser engraving machines have started to emerge on the market in
the past few years - I've seen one as low as US$4,000.  Well outside of my
budget, but compared to some of the CNC milling approaches that I've seen
discussed here, it's actually very viable.
I've not specifically seen any of these low-end machines used for PCB
etching, though I wouldn't imagine there would be a problem.
-Andrew
> the technique.
> PCB.
> locations.
> Bob
2010-05-03 by kimvellore@sbcglobal.net
The Chinese laser engravers have gone down in price.. I have seen some as low as $1500.
The problem I see with the lasers are, they work by burning off the paint and most of the paints I have tried leave behind a residue which needs a solvent to clean up which also removes the original paint. With the residue the copper does not etch well, it has always been a hit or miss on the boards I tried. I would like to see a boards done using a laser and also the details of the type of paint used so I can try it out once again.
Kim
Date: Monday, May 3, 2010, 11:28 AM
Bob,
-Andrew
This tutorial claims to have solved this problem by using a laser engraving
machine with a vacuum system, and doing the engraving starting away from the
vacuum outlet and working toward the vacuum:
http://www.instructables.com/id/Custom-PCB-Prototyping-using-a-Laser-Cutter/
It notes that if you failed to get all the paint off on the first pass, then
the second pass will ruin the first one.
I had nothing to do with putting this tutorial together - I just recall
finding it a few weeks ago.
The machine used in the tutorial is a Epilog Legend 36 EXT.
-Andrew
> low as $1500.
> Kim
> --- On Mon, 5/3/10, Andrew Villeneuve <andrewmv@...<andrewmv%40gmail.com>>
> wrote:
> From: Andrew Villeneuve <andrewmv@... <andrewmv%40gmail.com>>
> To: Homebrew_PCBs@yahoogroups.com <Homebrew_PCBs%40yahoogroups.com>
> Bob,
> -Andrew
To be fair, I didn't immediately recognize that this was a $25k industrial
laser system.  Still, I wonder if a simpler device could be fitted with such
vacuum solution.
-Andrew
> then the second pass will ruin the first one.
> -Andrew
>> low as $1500.
>> Kim
>> Bob,
>> to
>> in
>> -Andrew
The particular laser I used was designed for another purpose and was a high power pulsed YAG laser capable of cutting thin metal. It would remove the paint cleanly, and multiple passes was not a problem. I am not sure what it cost, but a BMW would probably be much cheaper. The vacuum table was about 3 X 4 feet square! I just used it because I had access and it worked.
Excimer lasers are a good match for this application as well, since the UV light actually ablates the paint (a term for breaking chemical bonds and turning it into vapor). Again, cost is prohibitive. Now if someone wanted to make a small CNC table that moved a scribe around the board, that is more realistic, and perhaps there are new diode lasers that might be OK.
Bob
Re: Resist ink pens
2010-05-03 by bownes
I have had great luck using fine point sharpies stuck into home made adaptors and plotting directly onto FR4 with a slightly modified HP 7475  plotter. (modified to allow the use of full height pens)
--- In Homebrew_PCBs@yahoogroups.com, Andrew Villeneuve <andrewmv@...> wrote:
> terrible results.
> is complete.
> -Andrew
> > Sent from my iPhone
> > > Tony
Re: [Homebrew_PCBs] Re: Resist ink pens
2010-05-04 by Andrew Villeneuve
Simple and effective...I love it!
> --- In Homebrew_PCBs@yahoogroups.com <Homebrew_PCBs%40yahoogroups.com>,
> > terrible results.
> toner.
> after
> off
> etching
> > is complete.
> > -Andrew
> > > Sent from my iPhone
> 40beagle.com.au>>
> > > > Tony
Re: Resist ink pens
2010-05-04 by ae5ew
I won't be buying one any time soon.  Charles  AE5EW
> vacuum solution.
> -Andrew
