Re: SMD Tweezer Tester with Multimeter
2010-03-21 by alienrelics
--- In Homebrew_PCBs@yahoogroups.com, Peter Harrison <peter.harrison@...> wrote: > > > On 21 Mar 2010, at 17:04, Mark Robinson wrote: > > > > Steve, this is simply nuts. > > > > You don't own the internet and have no business imperiously directing people to > > use another of your precious lists. You can try and close down discussions here > > that don't fit with your great plan for the world if that's how you wish to do > > things but honestly it just makes you look like a bit of a dick. > > > > Mark > > > > I for one support Steve on this. I have left several lists on other topics where there was no control. They just end up being used by a clique to chat about the weather, politics, etc... Signal to noise approaches zero and suddenly there is no venue for discussing the apparent subject at hand. > > Pete Harrison Exactly! Thank you, Peter, well said. I, too, have left several lists where off-topic chatting overwhelms the purpose of the list. Mark, you can join or not join any list you wish. The list description has been there since the list started, if you don't like it you should not have joined. I never said I owned the internet, nor did I tell you what you can or cannot do elsewhere. However, I do run this list, I try to be as hands-off as possible. But I'm not going to allow the list to be overrun with off-topic stuff, nor do I allow name-calling. You are now moderated. I am now using my ghod-like moderator powers to say that this topic is closed. I'd rather allow off-topic threads like this to simply fade away, but this one is looking like it is going to be one of those shambling undead zombie threads that won't die. Steve Greenfield
