Winboard pcb layout vs. Dell 1720 laser printer
2010-01-19 by grantfair2001
I can't print any of my many PCB layouts with my new printer.
I have a lot of PCBs laid out with Winboard 2.25. (The company selling it went out of business years ago). My old laser printer died so I bought a Dell 1720. It won't run on any software older than WIN2000.
I am running XP on a couple of my computers. Winboard is running under WIN95 on some old computers. Winboard does not run under XP.
(Someone loaded a patch for Winboard 2.25 to make it 2.27 to a public website. I haven't been able to get it to install).
SO I can't print any of my layouts.
Does anyone know of other PCB software which could read the Winboard PCB files and runs under XP, so I could print them?
Any other solutions?
Re: [Homebrew_PCBs] Winboard pcb layout vs. Dell 1720 laser printer
2010-01-19 by Stefan Trethan
print to pdf or even post script on the old machine, load on XP and print out.
It used to be possible to use the "wrong" driver via LPT. Just install
any similar printer and it might just work. Not an option over USB.
ST
> Thanks
2010-01-19 by Bob Huish
And for WinDraft too.
I have many old projects and can't print them out. My old system died
and when I tried to install on a win98 system it said that the Key was
out of date. I tried every Key that they sent me too.
Bob
> Thanks
Re: Winboard pcb layout vs. Dell 1720 laser printer
I don't know how to print to PDF, can you advise?
Grant
--- In Homebrew_PCBs@yahoogroups.com, Stefan Trethan <stefan_trethan@...> wrote:
The only thing worse than the Ivex programs was their support. All very shoddy, and very frustrating.
Did you try this site?
There they have the CD Ivex flogged as it went out of business, including some registration codes.
http://www.box.net/shared/ky83sl8o4g
It says you have to download all the files into one directory before you use RAR to extract them.
Maybe it will help.
RE: [Homebrew_PCBs] Re: Winboard pcb layout vs. Dell 1720 laser printer
2010-01-20 by Marc Sulfridge
Google CutePDF.
> From: grant.fair@...
> Date: Tue, 19 Jan 2010 22:04:16 +0000
> Subject: [Homebrew_PCBs] Re: Winboard pcb layout vs. Dell 1720 laser printer
> Grant
Your E-mail and More On-the-Go. Get Windows Live Hotmail Free.
http://clk.atdmt.com/GBL/go/196390709/direct/01/
2010-01-20 by Donald H Locker
Print to pdf (pdf995 is one product) then print that to the Dell.
HTH,
Donald.
To: "Homebrew PCBs" <Homebrew_PCBs@yahoogroups.com>
Sent: Tuesday, January 19, 2010 4:24:57 PM GMT -05:00 US/Canada Eastern
Subject: [Homebrew_PCBs] Winboard pcb layout vs. Dell 1720 laser printer
2010-01-21 by Ben L
I use to run Winboard on a XP machine.  Was not even installed on the machine.  I had the old drive from the old computer in a external drive case connected to USB on the XP machine.  Go to the Ivex Dir. Winboard then double click on the winboard start file and it would come up and run.  Would get a error when you try to close it.
Don't recall the version # but should have been their last version.  I just tried to connect up this old drive it seems to have died.
Anyway try copying the Ivex Dir from the old computer to your XP machine and see if it will run.
Ben
2010-01-21 by grantfair2001
Thanks. Apparently from posts on the net, Winboard 2.27 works with XP.  I have made some progress with downloading related fi;es and may get it to install, I need time to try things. If that fails, I will try your suggestion.
> Ben
Re: [Homebrew_PCBs] Re: Winboard pcb layout vs. Dell 1720 laser printer
2010-01-23 by Bob Huish
I went to
http://www.box.net/shared/ky83sl8o4g#
Down loaded the files and installed them on my XP system. Now I can
print out my old drawings.
Bob
>> Ben
2010-01-26 by grantfair2001
I got Winboard working on my XP computer and can print my layouts on the new printer. Time to warm up the laminator!
Thanks to everyone for the good responses; Bob I'm glad the same fix worked for you
--- In Homebrew_PCBs@yahoogroups.com, "grantfair2001" <grant.fair@...> wrote:
