USB hub module
USB hub module
2009-07-31 by David Griffith
I've been wanting to add downstream USB ports to a few projects for some
time.  To deal with this now and for the forseeable future, I decided to
put a 4-port hub on a DIP.  The idea is that a so-called hub-on-a-chip
is merged with its support stuff onto a piece of PCB the size of a DIP-32
or probably a DIP-40.  To add downstream ports to a design, put this
microhub after the female USB-B jack, then hang your gizmo[1] and female
USB-A jacks off the microhub.
How many of you would be interested in something like this?  I have a
quick-and-dirty schematic at http://frotz.homeunix.org/microhub/.  The
.sch file is from gEDA and you'll need the TI symbols I just uploaded to
http://www.gedasymbols.org/user/david_griffith/.
[1] Something using an AVR ATmega with V-USB
(http://obdev.at/products/vusb/index.html) loaded on it.
David Griffith
dgriffi@...
A: Because it fouls the order in which people normally read text.
Q: Why is top-posting such a bad thing?
A: Top-posting.
Q: What is the most annoying thing in e-mail?
Re: [Homebrew_PCBs] USB hub module
2009-07-31 by Stefan Trethan
So how is this better than just buying a $2 hub ready made?
ST
> David Griffith
> dgriffi@cs.csubak.edu
> A: Top-posting.
No need to figure out how to shoehorn it into whatever you're making.
David Griffith
dgriffi@...
k
Well, a DIP-40 isn't exactly tiny either, I'm sure there are some
pretty small 4-port hubs ;-)
I guess once the case is removed the PCB isn't large:
<http://www.dealextreme.com/productimages/sku_9476_1.jpg>
<http://www1.dealextreme.com/productimages/sku_2164_3.jpg>
<http://www.dealextreme.com/productimages/sku_3655_2.jpg>
And when you really don't have any space left inside your project, you
can always mount one of these to the outside with a decorative effect
<http://www.dealextreme.com/productimages/sku_10128_3.jpg>
I'd just modify some ready made units, that's what I do when I need a
serial port, just remove the case and SUB-D plug of a USB/RS232
converter and solder it to my circuit boad. I couldn't make it that
cheap even if I wanted - the FTwhatever chip probably costs more than
when I buy a whole converter.
Anyway, have fun, but personally I don't see the need.
ST
> David Griffith
> dgriffi@...
> k
[snip]
Here's what set me off on this merry errand:
http://www.schatenseite.de/dulcimer.html.  This uses an ATmega and little
else to replace the controller board of a Model M keyboard, making it
natively USB.  What I want is a downstream port or two to connect a mouse
as is common with Mac and Sun keyboards.  I have a Sun Type7 keyboard,
but I can't give up my Model M.
David Griffith
dgriffi@...
A: Top-posting.
But it doesn't even have any windows keys!
Are there any active PS2 / USB converters that could be used? The ones
I know are just pin/pin adapters for mice which can already talk USB.
If there are any adapters they could probably be put inside the
keyboard with little difficulty.
In any event there is lotsa space in those old keyboards, I'm sure you
could fit several USB hubs. Unless of course you just have to have the
indides of your ancient keyboard looking like they were made that
way.....
ST
> [snip]
> David Griffith
> dgriffi@...
> A: Top-posting.
And that's just the way I like it!
I bought one from clickykeyboards.com for that purpose.  Shortly
afterwards, I found two projects dealing with using a microcontroller to
entirely replace the driver board.  It's much cleaner that way.
> way.....
Yes, there is quite a bit of space in the Model M.  The problem is how to
keep things straight with the cabling.  I've nearly abandoned a Paia
Fatman synthesizer for the very same reason in favor of a newer
double-sided board.
David Griffith
dgriffi@...
2009-07-31 by Piers Goodhew
Sounds intriguing, but i got ein "Fehler 404" from that link.
I have one of them ole ADB Mac keyboards that it would be great to
revive...
PG
Ah the trailing full stop (period) confused my email client, now I can
get the german dictionary out ....
PG
> little
2009-07-31 by DJ Delorie
Stefan Trethan <stefan_trethan@...> writes:
Dude, this is the "Homebrew_PCBs" group.  We don't need an excuse to
build it ourselves ;-)
>> little
Click the UK flag in the upper right corner.
David Griffith
dgriffi@...
A: Top-posting.
