Homebrew_PCBs
Printing multiple boards on one sheet
2008-12-07 by Matthew Mucker
Does anyone have a tutorial or other instructions for using Eagle to print
multiple boards onto one sheet of paper? I'd want to print multiple of the
same board, and/or two different projects on the same sheet.
Thanks!
Re: [Homebrew_PCBs] Printing multiple boards on one sheet
2008-12-07 by Fernando Araújo
I don't think Eagle does this. But you can try a copy and paste of the
board.
Fernando Araujo
Zsa Zsa Gabor - "A man in love is incomplete until he has married. Then
he's finished."
> Thanks!
2008-12-07 by marc olanié
[>] >I don't think Eagle does this. But you can try a copy and paste of the
[>] >board.
I'm not an Eagle pundit either, and I've never found how to do this:-(. So,
I've adopted a more "brutal" way : I "print" each eagle mask with PDF
Creator, and then I merge the different images with a pdf editor (this is a
good way to optimize the placement when you are using an expensive support
like PnP Blue or other transfer films)
My 2cts
Marc
2008-12-07 by leon Heller
To: <homebrew_PCBs@yahoogroups.com>
Sent: Sunday, December 07, 2008 6:00 PM
Subject: [Homebrew_PCBs] Printing multiple boards on one sheet
You might be able to combine Gerbers with something like GC-Prevue and print
from that.
Leon
Re: Printing multiple boards on one sheet
2008-12-08 by Gerald Schwarz
--- In Homebrew_PCBs@yahoogroups.com, "Matthew Mucker" <matthew@...>
to print
of the
> Thanks!
hi,
I think, you can do this with the CAM Processor. Please read the help
in Eagle, how you can create a multiple output file, e.g. gerber-274x.
You can create more then one section with there layers and placing
offsets.
Normaly, Eagle has no "Import" button.
Because DRC and ERC inconsistent, it is not possible importing an
external PCB-file.
Example: PCB 1: R1, wire 1 on Pin 1;.... PCB 2: R1, wire 10 on Pin
1;.... PCB 3: R1, wire power on Pin 1;....
Gerald
Re:Printing multiple boards on one sheet
2008-12-08 by t.ward@lightboxdesigns.com
If printing boards myself, I generally create a PDF (using a driver like the
free CutePDF one), and then combine or step and repeat them with another
program (I use the non-free, but inexpensive CutePDF Pro, but I seem to
recall that I have loaded PDF drawings and combined them with Illustrator
before - I think even the free InkScape program can load PDFs - you might
want to try that)
2008-12-08 by Markus Zingg
Matthew,
The way to do this in eagle is to:
a) open your board in question.
b) Mark everything and click on the cissors (Eagle does not have a cut,
but cut means copy as you surely know)
c) close the board, open a NEW board file
d) past the design into this new "pannel" board as many times as you wish
e) print this "pannel" board.
HTH
Markus
> Thanks!
2008-12-08 by Herbert E. Plett
do not try to edit anything because you will get a mess...
> have a cut,
--- In Homebrew_PCBs@yahoogroups.com, "Herbert E. Plett" <cachureos@...>
> > have a cut,
hi,
With this methode, copy and paste, there is a little problem:
that overwrites pad-dimensions and the drilling tool table, because
the Pins all are in flash-appertures, not drawing rings.
(drawing rings are not so beautiful than flash rings)
The Pad properties will be also copying.
I think, it's better to make multiple gerber files with the PCB
offsets, a drill and apperture file with the CAM processor in a new
working folder.
Than open it with a gerber program (auto insert) for the next working
steps.
If you have a different apperture list, drilling tool list, be shure
that they correspond with the PCBs.
The working time with this methode is the same than drag and drop in
some few minutes.
Controlling and/or repairing the drill - apperture file needs a
little bit more time.
The benefit with gerbers, you can than work with drilling/milling
plotters, if you have one.
For hobby or (semi) professional use, i think, the working steps and
times are the same with there individual methodes.
regards
Gerald
Re: [Homebrew_PCBs] Re: Printing multiple boards on one sheet
Gerald,
Not sure if I understood propperly what you mean with "overwrites
pad-dimensions and the drilling tool table" but IMHO you can prevent
problems by loading the identical design rules as your current design at
the point in time you create the empty board and bevore you start
pasting. At least for me this worked well.
Working with gerbers is probably the same amount of time as you say.
However, at least where I live there are many board shops which directly
accept Eagle board files and with those shops, avoiding the geber hassle
is a plus.
Markus
> <mailto:Homebrew_PCBs%40yahoogroups.com>, "Herbert E. Plett"
> <cachureos@...>
> > > have a cut,
> hi,
> working folder.
> steps.
> some few minutes.
> regards
> Gerald
