Homebrew_PCBs
Index last updated: 2026-03-30 17:29 UTC
Determining copper weight
2008-11-05 by Don Jackson AE5K
A little different subject from most message traffic: Anyone know of a
method to (hopefully easily) determine the copper weight on unetched
material (probably FR-4)?
In my case, I've collected various pieces of copper clad board but have
no idea if copper is 1/2 oz., 1 oz, or more.
Don
Re: [Homebrew_PCBs] Determining copper weight
2008-11-06 by leon Heller
Sent: Wednesday, November 05, 2008 2:46 PM
Subject: [Homebrew_PCBs] Determining copper weight
Peel off a piece of copper and measure the thickness.
Leon
2008-11-06 by Harvey White
I think you'd have to sacrifice a very small area, and peel the foil
back with a knife. Measure that thickness, and then compare.
Harvey
>Thanks,
>Don
2008-11-06 by Don Jackson AE5K
Thanks for the suggestion(s) for determining copper weight of some
copper clad material. I'll see if the old micrometer can tell me
something. All three suggestions were to peel a little piece of the
foil and measure it.
I wonder if another simple method might be to measure overall thickness
of unetched material and then subtracting the resultant thickness of
totally etched (no copper left) material. (Take into account single or
double sided.)
I didn't easily find a reference to "ounces versus thickness", so for
anyone looking, this website has a nice chart:
http://www.standardpc.com/laminates.htm
or here is the info:
1/2 oz. 18 um 0.7 mil
1 oz. 35 um 1.4 mil
2 oz. 70 um 2.8 mil
3 oz. 105 um 4.2 mil
For various thickness of materials, here's the mm to mil conversions:
0.4 mm 16 mil
0.6 mm 24 mil
0.8 mm 32 mil
1.0 mm 40 mil
1.2 mm 47 mil
1.6 mm 63 mil
(OK, no quibbling over round offs!)
If anyone finds a neater form, let me know. I did spend a lot of time
looking at this groups resources online and may have overlooked this
information.
Don
RE: [Homebrew_PCBs] Determining copper weight
2008-11-07 by Hugh Weinrich
Here are the details for Cu thickness & clad weight:
Copper Weight: it defines the number of ounce copper on 1 sq. ft. area, such
as 0.5, 1.0, 2.0, 3.0 oz, etc. Usually this parameter is used to specify the
thickness of the copper on each layer of the board. It is very easy to work
out the thickness of 1.0 oz copper on 1 sq. ft. board based on the copper
density (8.9 g/cm3), which is 34.29 µm and rounded up to 35 µm. So we have
the following list.
0.5 oz means 17.5 µm copper thichness
1.0 oz means 35 µm copper thichness
2.0 oz means 70 µm copper thichness
HughAW
_____
On Behalf Of Don Jackson AE5K
Sent: Wednesday, November 05, 2008 6:46 AM
Don
