Toner Dusting your Silkscreen (an idea)
2008-10-18 by warrenbrayshaw
To date component placement silk screens have been limited to black using toner transfer. With colour laser printers you should be able to toner transfer a vivid yellow. Toner transfer has a couple of issues when nice readable paterns are required. 1. It is difficult to get a complete image due to the differing heights of the copper and the missing copper. 2. You need a very good paper that releases well and does not leave any paper fibres or clay behind. Direct printing to the PCB using an inkjet printer and then toner dusting could provide a better screen print. Using direct printing the process requires baking the pigment ink such that it goes brown. If you direct print the solder mask a black toner will not be of much value. Yellow would be the colour to use and the printing industry may even have a white toner they use as a base coat for their photographic processes on transparent material.(To be confirmed) A printer other than a pigment ink Epson may also be successful. This will depend on the binding characteristics of the toner once wetted and then dried. Taking this thought one stage further, a water/alcohol mix may be usable through a dye print head if the toner stays bound to itself and the PCB once dry. Although it would be better if the toner did not blow away once the ink has dried, the method may not depend on any adhesion once dry. Just keep the PCB horizontal and carefully get it up to temperature in the next stage. Once the PCB has been dusted the toner needs to be flowed. Ideally this should be done using heat but no pressure. I don't know if it can be done without pressure as the plastic particles in the toner need to get together if the final result is to be strong. I suspect having most of the ink liquid evaporated before applying the higher melting heat would be best to stop boiling the ink as this will move the toner. I would then evenly raise the temperature of the PCB to prevent stress and then locally heat the toner to melting point. An oven or heat gun are the tools to try here but over temperature will likely burn the plastic and loose the vivid yellow/white that the toner promises. Those with direct printing ability may like to give it a try and report back. Warren
