what about an inkjet head to a cnc was Re:attaching a pen to a cnc?
2008-10-04 by Henry Liu
Seems like a pen might not be ideal.  What about an inkjet head
attached to a cnc?
The reason for the CNC is that I already have a CNC with .0001"
repeatable resolution which means I don't need to do anything.
If you don't have CNC, you can build one pretty easily and it has a
lot of other useful features.
Anyway, I can set an M function in the G-code to trip a relay to turn
the ink on and off.
All I need to do is figure out how to turn the inkjet head on and off.
I know some people have modified an inkjet to take larger stock but I
haven't seen a mod which basically tells the ink jet head to shoot
ink.
After I figure out how to turn ink on and off, all I have to do is
position the Z axis to a useable distance away from the plate and let
it run.
I have several DXF-> G-code converters made for nesting parts for
laser cutting/milling so the programming the XY movement is no
problem.
Can someone point me to some resources that basically takes an inkjet
head and turns it into a mini watergun with on/off control?  From my
understanding, there's a small piezoelectric disk that when you apply
a voltage shoots a bubble.  Is it as simple as hooking up a wire with
TTL logic from the inkjet head to an empty M function relay on my CNC?
This would also be very cool as I figure out how the inkjet head
works, perhaps I can fill it with some sort two part glue instead of
ink.  Two inkjet heads would shoot to the same spot making a hard
cured epoxy spot.  Voila -> cheap 3d printer with a HUGE print area!
Thanks.
Henry
www.fullspectrumengineering.com
2008-10-04 by Steve
> attached to a cnc?
> the ink on and off.
> ink.
A gentleman named Fogassa is building a 3D printer using a Lexmark. He
is not using the printer electronics to run the head, he's using his
own drivers and firmware.
http://tech.groups.yahoo.com/group/diy_3d_printing_and_fabrication/
Steve Greenfield
2008-10-05 by TonyB
Hi PCBers,  Mostly lurking, but thought I'd comment on this thread.
Have U ever heard of MicroPen?  I used to work with their equipment
about 10yrs ago.  I was depositing gold traces on 2in x 2" ceramic
substrates.  MicroPen could also do resististance lines with a "carbon
ink".  Also, could do insulative ink for crossing over the gold lines
with other gold lines.  I believe the company is still in business(?)
 U would need an X/Y table with a Z-axis dispenser.  The ink came in
little syringes and had date-codes like solder-paste.  For a small
pcb, this would be great.  I could put 3 or 4 teeny tiny lines between
.1 centers easily.  The system had a built-in microscope-camera-color
monitor.  I thought it was really cool!!  I think a Sherline CNC mill
could be adapted.  I've been thinking of trying, but other things in
life seem to get in the way  :-p   PM me for more info/chat  T
--- In Homebrew_PCBs@yahoogroups.com, "Steve" <alienrelics@...> wrote:
> > attached to a cnc?
> > the ink on and off.
> > ink.
> Steve Greenfield
2008-10-05 by Steve
What is wrong with sharing it here? I'm sure a lot of us would like
to hear about this.
Steve Greenfield
"carbon
lines
between
color
mill
2008-10-06 by Steve
Which looks remarkably like the Micropen that Tony referred to.
http://www.micropen.com/
Not to be confused with the Cross Micropen nor with PDA styluses. ;')
Steve Greenfield
--- In Homebrew_PCBs@yahoogroups.com, "John Kent" <moonshadow@...> wrote:
> The last posting reminded me of the air pen.
> http://www.silkpaint.com/airpen/
