Homebrew_PCBs
Index last updated: 2026-03-31 12:10 UTC
PCB Probs
PCB Probs
2008-07-19 by Howard
Hi All
I have got some fotoboard 2 pcb (Rapid electronics) and a
LV 202E Exposure box, the tubes are about 2" from the glass.
Anyone know how long to expose this make of board ?
Also i did a board the other day using fotoboard 2 (about 5 mins exposure)
and it came out crap, all the edges looked pitted and the tracks had what
looked like lines etched in them!!
I use ohp transparency film (www.5star.co.uk), and it is for inkjet
printers (Epson, Canon)
and my printer is the Epson R300.
Howard
Re: [Homebrew_PCBs] PCB Probs
2008-07-19 by Leon
Sent: Saturday, July 19, 2008 4:50 PM
Subject: [Homebrew_PCBs] PCB Probs
> Hi All
Try using JetStar film, also available from Rapid.
I used to get get good results with Fotoboard 2 and JetStar with an Epson
printer. I now use JetStar Premium with an HP printer, which works even
better.
Leon
Re: PCB Probs
--- In Homebrew_PCBs@yahoogroups.com, "Leon" <leon355@...> wrote:
> From: "Howard" <hj.payne@...>
> > Hi All
exposure)
had what
Epson
> better.
> Leon
Hi
Thanks for that info Leon.
is the exposer time ok for Fotoboard 2 (aprox 5 mins)?
also i think that the developer (costic soda) was abit strong
it started to work as soon as i placed the board into it !!
it was done in a mater of seconds hi hi.
Howard
2008-07-19 by DJ Delorie
"Howard" <hj.payne@...> writes:
The tool for this job is a "step transmission gauge" which helps you
calibrate exposure times. I did some big writeups about this a few
weeks ago; you can buy them from www.stouffer.net for about $7 plus
S&H.
Re: [Homebrew_PCBs] Re: PCB Probs
2008-07-19 by Leon
Sent: Saturday, July 19, 2008 5:29 PM
Subject: [Homebrew_PCBs] Re: PCB Probs
>> > Hi All
> exposure)
> had what
> Epson
>> better.
>> Leon
> Hi
You have to experiment to get the correct exposure time, I use 11 mins. Use
a test strip and move a piece of cardboard across the PCB every minute to
get the optimum exposure.
I use about 12 g/l of NaOH. It takes about 20 secs but depends on the
temperature. You might have it too strong.
Look at your transparencies with a lens and make sure that they are opaque.
That might be the cause of the problem.
Leon
