Homebrew_PCBs
photoresist sensibility chart ref UV wavelength - PCB LDI using a PS3 diode
2008-06-12 by dandumit
Does anybody has access to the sensibility chart related to wavelength
of exposing light source ?
I would like to know if a KES-400AAA PS3 laser module
(http://www.fineartradiography.com/hobbies/lasers/blu-ray/) would be
usable to directly expose the photoresist from a pcb.
This laser diode has a wavelength of 405nm (it's not uv is near uv)
but maybe it would impress the resist from pcb at an acceptable
exposure time.
Any comments are greatly appreciated.
Daniel
Re: [Homebrew_PCBs] photoresist sensibility chart ref UV wavelength - PCB LDI using a PS3 diode
2008-06-12 by Cristian
It is OK.
Cristian
>(<http://www.fineartradiography.com/hobbies/lasers/blu-ray/>http://www.fineartradiography.com/hobbies/lasers/blu-ray/)
>would be
>exposure time.
2008-06-12 by Markus Zingg
IMHO it should work, but you are aware that you would have to expose
every pixel for quite a while with the beam and thus the overal exposing
time would be alot higher. I mean I would love to look at such an
aproach etc.
Just my 2ยข
Markus
dandumit schrieb:
> Hi,
> <http://www.fineartradiography.com/hobbies/lasers/blu-ray/>) would be
> exposure time.
> Daniel
Re: photoresist sensibility chart ref UV wavelength - PCB LDI using a PS3 diode
2008-06-12 by warrenbrayshaw
The following article may be of interest
http://www.circuitree.com/Articles/Column/18623649067d7010VgnVCM100000f932a8c0____
> exposure time.
2008-06-13 by dandumit
warrenbrayshaw - Thanks ! indeed the article is very close to what I
was searching.
It seems that the peak sensitivity is around 370 nm and some resists
are better at 405nm. I have found on a forum about using laser diodes
from BlueRay players that they have achieved 60mW and more (depending
a lot on optics used).
In order to see how much time is needed to LDI an pcb we must see how
much time should be exposed. Also on net I have seen that various
photoresists and soldermasks needs about 100 mJ/cm2 exposure (I have
seen some with 10mj and some with 200mj).
Considering such a laser diode focused on a 0.1 mm diameter spot
(that's other issue because a laser diode doesn't generate a circle
spot) means = 3.14*(0.05)^2 = 0.00785 mm2 =~
0.008mm2=0.000008cm2=8*10-5 cm2
100mJ/cm2 means equivalent 0.008mj/0.008mm2
0.008mj means 0.008mW-Second. the blueray diode has 60mW this would
mean that it could "expose" 7500 spot's per second.
a pcb of 320mm wide would be exposed with a speed of 0.2mm per second
if the pcb is 320mm long it would take 1600 seconds ~ 27 minutes.
A higher sensitivity resist would reduce the time.
If someone could tell me if I am wrong or what could go wrong in this
calculation please don't hesitate to contribute.
Until now I don't know if it is possible to focus that diode to
0.1mm2. In disc readers the track width it's more narrower.
Daniel
--- In Homebrew_PCBs@yahoogroups.com, "warrenbrayshaw"
