Re: [Homebrew_PCBs] Digest Number 2503
2008-06-12 by Donald H Locker
A little slow on the reply, because I'm on digest, but it looks to me like you
laid your LEDs out perfectly.  The overlapping circles on the backside should
mirror (so to speak) the pattern on your PCB.  Hexagonal close-packed.  Can't
get better distribution than that.
Aim and distance to the board are the only variables I would change if I were you.
Donald.
> 2a. UV LED box
>     From: DJ Delorie
> 2a. UV LED box
>     Posted by: "DJ Delorie" dj@... djdelorie
>     Date: Tue Jun 10, 2008 7:05 pm ((PDT))
> Just finished wiring mine up...
> http://www.delorie.com/pcb/uvled/
> I layered the LEDs between two sheets of plywood hoping they'd keep
> things aligned, but not quite good enough I suppose.  Time to fiddle I
> suppose.
> I happen to have a lab-grade timer to run it with, too.
[snip]
2008-06-12 by DJ Delorie
Donald H Locker <dhlocker@...> writes:
> if I were you.
Distance is actually further than optimal by 25% or so.  It's aim
that's the problem here, I've since lit up individual LEDs to see, and
some are off by half a diameter or so.  I'll have to map out the
deviations and adjust the holes in the board accordingly.  When I have
time ;-)
