Out-of-date pre-coated boards
2008-06-03 by Leon
I've just noticed something that might be useful to other people using
pre-coated boards.
I was using up some rather old off-cuts while I waited for some new material
to arrive, without much success. The new material arrived this morning and I
noticed that the faint yellow pattern on the resist after UV exposure was
much more noticeable than it had been on the old stock.
Leon
Leon Heller
Amateur radio call-sign  G1HSM
Yaesu FT-817ND transceiver
Suzuki SV1000S motorcycle
leon355@...
Re: Out-of-date pre-coated boards
2008-06-03 by Andrew
> useful to other people using pre-coated
> boards.
> while I waited for some new material to
> the resist after UV exposure was much
> old stock.
Leon,
At least with the brand I have they will
still work years out of date.
The issue is that they loose a lot of
sensitivity and a little bit of contrast.
As long as your photo tool is nice and
dark just try increasing the exposure
time and see how you go.  As an example
2 year out of date boards with a vellum
photo-tool will take me 10 minutes where
as fresh stock will be about 3 minutes.
Re: [Homebrew_PCBs] Out-of-date pre-coated boards
2008-06-05 by Adam Seychell
> pre-coated boards.
They could be a different brand/formula photoresist. could you explain
what problems you had ? Is it negative or positive resist ?
Was it a exposure, developing issue, or copper residue problem. The only
problem I've experienced with aged resists (>2 years) is a stubborn
residual invisible film left behind on the copper surface after
developing. It requires rigorous developing to remove it, and etching to
remove the rest.
Adam
2008-06-05 by Matthew Smith
Quoth Adam Seychell at 2008-06-05 18:23...
> remove the rest.
Adam - I'll fire the same question back at you - with which brand did
you have this specific problem - Kinsten?  If so, I'd be interested to
hear as I've got a load of "mature" Kinsten stock that I'm about to use,
having been out of the game for a couple of years.
Matthew Smith
Smiffytech - Technology Consulting & Web Application Development
Business: http://www.smiffytech.com/
Personal: http://www.smiffysplace.com/
LinkedIn: http://www.linkedin.com/in/smiffy
2008-06-05 by Leon
Sent: Thursday, June 05, 2008 9:53 AM
Subject: Re: [Homebrew_PCBs] Out-of-date pre-coated boards
>> pre-coated boards.
>> material
>> and I
> remove the rest.
The actual material was Fotoboard 2 (positive resist). The main problem
(with my standard exposure) was incomplete removal of the resist during
development. I could probably have got over the problem with more separation
between the tracks and rubbing the board during development, but I wanted to
use 10/10 mil tracks. It was easier to dump it and order some fresh boards.
I've had the problem before.
Leon
Leon Heller
leon355@...
>> remove the rest.
I think the resist was Macdermid brand, negative active. I got a roll of
it several years ago and apply it myself. Because I develop the PCB
almost immediately after applying, I never have the residue problem.
Apparently the professionals never leave resist on any more than 24
hours or it becomes too difficult to develop.
The only way around the problem is to develop about 2 or3 times longer.
If its really bad then the resist will get damaged due to excessive
developing before all the residue has had a change to be removed.
I develop in 1% NaCO3 30~40 deg.C as you do for all negative resists. I
I use a paint brush for the scrubbing.
The problem I found is the residue is invisible so it looks like the
developing is complete. But when you go to etch , the photoresist
residues are quickly revealed by un-etched copper areas.
2008-06-05 by Russell Shaw
>>> remove the rest.
Beware of swimming pool NaCO3 as it seems to be contaminated with something;)
2008-06-05 by Andrew
> that I'm about to use, having been out of
Matthew - it is kinsten stuff I had that I
found to have lost a lot of sensitivity and
a little bit of contrast when many year out
of date.
However sometimes when I order the Kinsten
boards from Perth they come in different
shades depending on batch.  They range from
drab green to bright green.  So there may
even be marked difference in the "past used
by" performance in the one brand.
Re: [Homebrew_PCBs] Re: Out-of-date pre-coated boards
Quoth Andrew at 2008-06-06 08:46...
> of date.
Thanks Andrew.  The moral of this story is, therefore, to run a test
strip on every batch of stock.  Have a small strip of board and a film
of parallel lines.  Partially cover the strip, expose for a minimum
length of time.  Uncover a bit more strip, expose for a little longer.
Rinse, then repeat.  Develop - and possibly even etch - the strip and
see which exposure time worked best.  I think that the term is 'bracketing'.
Cheers
M
Matthew Smith
2008-06-06 by DJ Delorie
Matthew Smith <matt@...> writes:
Or just get a step transmission gauge and calibrate your exposure.
