PCB EDM (again!)
PCB EDM (again!)
2008-04-26 by curt_rxr
Hi all,
When this list first started, I posted about my attempts to turn an HP
Deskjet into an EDM machine for PCBs, but I abandoned the project
after Stefan and others developed toner transfer into a reliable
system.  The EDM was just too slow compared to TT.  I've moved on to a
modified Xerox Phaser printer that puts wax directly on a thin sheets
of epoxy PCB and allows me to 'print' my board and etch it rapidly.
I know that Graham and others kept up the work on EDM and I was
wondering if anyone on the list had made any breakthroughs?   I still
think that there must be a way to reliably generate pulses fast enough
to create a PCB in a reasonable time, especially if a drill head was
incorporated to allow drilling and 'etching' with one setup.
Curt
Re: [Homebrew_PCBs] PCB EDM (again!)
2008-04-27 by Herbert E. Plett
--- On Sat, 4/26/08, curt_rxr <curt_rxr@...> wrote:
> I've moved on to a
> thin sheets
> etch it rapidly.
is this modification/process "proprietary"? or can you share it? (please)
Be a better friend, newshound, and
know-it-all with Yahoo! Mobile.  Try it now.  http://mobile.yahoo.com/;_ylt=Ahu06i62sR8HDtDypao8Wcj9tAcJ
Re: PCB EDM (again!)
2008-04-28 by curt_rxr
> > I've moved on to a
> > thin sheets
> > etch it rapidly.
Hi Herbert,
The original idea came from a subscriber to the list who was IIRC an
EE professor at Oregon or Washington and posted his procedure for
making  printed circuit boards using a Xerox Phaser solid ink printer.
 It's in the archives, but the 'gotcha' is that the cheapest Xerox
solid ink printer starts at $2400!   I found one a year later for $50
at a business closing and remembered the post.  The only mods needed
are are to trim a little plastic to make the 'paper' path for the PCB
easier and I imagine the mods would be specific to each type of machine.
The solid ink holds up really well with Adam's CuCL etching system.
All I do is scrub the copper with Cameo copper cleaner before printing
and then etch.  The board is done in about half a hour.
If you look for Xerox Phaser printers make sure you are looking at a
solid ink printer as Xerox sells some low priced laser printers under
the Phaser name.
Curt
RES: [Homebrew_PCBs] PCB EDM (again!)
2008-05-04 by Alexandre Guimarães
Hi, Curt.
	I could not find in the archives the schematics of the power supply
you used for the EDM process.. Could you post it ? Could more "cutting"
heads be used in paralell to speed up the process ? It seems to be a very
"clean" way to make the pcbs. I would be interested in continue
experimenting with EDM for pcb making !
Best regards,
Alexandre Guimaraes
-----Mensagem original-----
De: Homebrew_PCBs@yahoogroups.com [mailto:Homebrew_PCBs@yahoogroups.com] Em
nome de curt_rxr
Enviada em: sábado, 26 de abril de 2008 13:14
Para: Homebrew_PCBs@yahoogroups.com
Assunto: [Homebrew_PCBs] PCB EDM (again!)
Hi all,
Deskjet into an EDM machine for PCBs, but I abandoned the project after
Stefan and others developed toner transfer into a reliable system.  The EDM
was just too slow compared to TT.  I've moved on to a modified Xerox Phaser
printer that puts wax directly on a thin sheets of epoxy PCB and allows me
think that there must be a way to reliably generate pulses fast enough to
Curt
Be sure to visit the group home and check for new Links, Files, and Photos:
http://groups.yahoo.com/group/Homebrew_PCBsYahoo! Groups Links
2008-05-07 by ralucas4277
Hi Curt,
After your previously posted details of your system, I carried out some
more tests on pcb spark erosion. What became immediately clear was the
requirement for an accurate wire feed for the electrode.
I put together a mall stepper driven wire roller feed mechanism, using
a gearbox and a butchered capstan mechanism from an old tape recorder,
with fixed orifices above and below the vertical roller wire drive,
thus giving the step in/out for the spark initiation. This worked using
10 mil wire, (smaller dia wires are more difficult to source easily in
small quantities in the UK, if anyone knows better, please let me
know), but the need for a more precision unit was needed, and other
things intervened. I bought a micro lathe intending to put together a
higher precision unit. A servo motor rather than a stepper may give a
speed increase.
The reason that I still intend to develop this system, is that direct
printing is, as far as I can tell, still a bit of a black art, (and I
never really got toner transfer to work reliably 100% of the time), the
inks are expensive to import to the UK, you still need to etch, and you
have to modify a printer anyway.
PCB EDM can eliminate these costs at the expense of speed, whilst
simultaneously using a mini cnc for drilling and etching.
If the feed wire mechanism can be made to work at reasonable speed, I
think that the next bottleneck would be the turn on/off times of the
spark controlling mosfets. I thought that this could be overcome by
using multiple spark generators sequentially fired, if necessary.
Of course, the whole thing may be constrained by the speed of the cnc
machine used, but then this whole approach is not really a problem when
the machine could run in the background unattended. Speed is as
Einstein pointed out relative anyway.
I intend to do some more development this summer. Is anyone else
interested in this approach, do you think?
Good to hear you still have an interest in the method.
Roger
--- In Homebrew_PCBs@yahoogroups.com, "curt_rxr" <curt_rxr@...> wrote:
> Hi all,
> Curt
Re: [Homebrew_PCBs] Re: PCB EDM (again!)
2008-05-07 by KeepIt SimpleStupid
--- ralucas4277 <ralucas4277@...> wrote:
> Hi Curt,
> I carried out some
> electrode.
> old tape recorder,
> roller wire drive,
> to source easily in
> please let me
> needed, and other
> to put together a
> stepper may give a
> speed increase.
In the US small quantities of
1 mil stainless, 5 mil tungsten and 5 mil tantalum are
easily sourced at www.smallparts.com.  Search for "wire".
2008-05-07 by Cristian
>Roger
I'm interested too.
I owe a Bungard's CNC (drill/mill) and, as I'm an electronics
engineer, I can do some
electronics to help you.
Cristian
Why not use horizontal wire movement? You can use the CNC to drive it.
Cristian
2008-05-07 by javaguy11111
If you have not already come across this group, you may find it
helpful for EDM experimentation.
http://tech.groups.yahoo.com/group/EDMHomeBuilders/
I bought a copy of the moderators book on homebrew edm and it is very
good. Several people have built his design and have pictures in the
photo section. I hope to build one of my own at some point , but not
for pcb edm purposes.
--- In Homebrew_PCBs@yahoogroups.com, "ralucas4277" <ralucas4277@...>
wrote:
> Hi Curt,
> speed increase.
> Roger
> --- In Homebrew_PCBs@yahoogroups.com, "curt_rxr" <curt_rxr@> wrote:
> > Hi all,
> > Curt
Cristian,
Horizontal would not work using the cnc axis as a wire feed (as far as
I can see anyway), since the wire is consumed in the erosion process,
the roller feed also automatically compensates for the loss of
electrode. Also, how would you submerge the electrode and workpiece in
the dielectric?
Your offer of electronics design could be helpful. I will dig out my
work and review it.
Roger
using
recorder,
> Cristian
2008-05-07 by Andrew
> group, you may find it helpful for EDM
> experimentation.
> <SNIP>
I am more than happy doing PCB photo-etch
but am very interested in PCB EDM anyways
(EDM it is just gosh darn interesting)
Two alternate yahoo groups for EDM stuff
are
http://tech.groups.yahoo.com/group/HomeBrewEDM/
and
http://finance.groups.yahoo.com/group/EDM_CNC/
The first of the two has just recently
started as people where getting upset at
the discussion of non RC/relaxation-oscilaltor
machines on the group intended as support for
that book on EDM.
All input is welcome over there.
