[Homebrew_PCBs] Direct Toner - Challenge
2008-04-05 by mlerman@ix.netcom.com
Now that I can print single sided  boards, I think I've found a way to print double sided boards, with excellent registration, in a single pass. This will need more than a simple hack, but I'm pretty certain it is doable.
I'm considering the commercial applications. Is anyone on the list knowledgable enough in the field to provide some expertise and thoughts as to the commercial viability of such a product? I would especially be interested in someone who is interested in partnering in the project. BTW, I have several successful inventions on the market and have some financial resources to pursue this if it is viable.
Mark
Re: [Homebrew_PCBs] Direct Toner - Challenge
2008-04-05 by Stefan Trethan
The main point against commercial application for doublesided boards
would be the inability to "tent" vias. Few commercial boards are
doublesided but not throughhole plated.
Also, laser printer distortion could be a problem.
It would be good if we could go through all that again, 'cause i don't
yet understand how you did it. I thought it was impossible, and still
have my reservations about it's practicality. If you have the patience
to answer my questions i'll try to replicate your results.
Back when i was working on direct inkjet printing i was contacted by
some PCB manufacturer in the US very interested in having me
demonstrate it to him "all expenses paid". I had no intentions to do
so but if you are interested i can probably find the contact details.
ST
>  Mark
>  Be sure to visit the group home and check for new Links, Files, and Photos:
>  http://groups.yahoo.com/group/Homebrew_PCBsYahoo! Groups Links
2008-04-05 by Mark Lerman
Hi Stefan,
I'm not sure whether I am actually interested in a commercial venture
- I have more than enough to do right now - but I am interested in
considering it. I haven't really done much with the process so far,
but I'll try and do more in the next few days. If it has commercial
viability, it would be only as a prototyping system, not for
production. It certainly seems much better and faster than the cnc
board mills that go for thousands of dollars.
My approach to things of this sort tends to be empirical - try it and
see what happens - rather than look at whether it can be done from a
theoretical point of view. You'd be surprised how often things that
"can't be done" really can!  Here is a link to my other products -
they are "out of the box" type products, as well. <http://www.markkenny.com>.
I'll be happy to answer and questions that you might have. I'm tied
up for the moment, but I'll try to go through what I did in a step by
step fashion so that it can be repeated. I can do it on the web site
or in this forum - any preferences?
Mark
At 11:47 AM 4/5/2008, you wrote:
>Hi,
>ST
> >  Mark
> and Photos:
Or do you want to take this off list?
Mark
At 01:18 PM 4/5/2008, you wrote:
>Hi Stefan,
>Mark
> >Hi,
> >ST
> > >  Mark
> > and Photos:
Hi Mark,
I'm perfectly happy to keep this on the list so everyone may benefit.
One of my questions is about the mechanics. If one sends a rigid PCB
through a laser printer i would expect the edges to eventually damage
the sensitive coating on the drum. Even with careful de-burring
potential for damage seems high.
Another thing is toner density. When i tried printing on metal foil i
noticed i can only achieve 50% of normal toner density, because the HV
that normally holds the toner is shorted out. I did not consider it
possible to achieve enough toner density to resist the etchant.
Generally i much prefer laser printers, i hate the messy ink business.
But with an inkjet the head moves some distance from the surface, so
that is no problem.
Did you use some type of carrier sheet or was the PCB large enough to
be transported by the printer?
ST
>  Mark
Stefan,
Before I got the mechanics straightened out, I did damage the drum in
2 places, but since then there hasn't been any. Granted I've only run
boards through a few dozen times, but so far, so good. I replaced the
toner cartridge and since then have been carefully smoothing the
edges of the boards with a 3M pad and rounding the corners a bit with
a fine file. I've also been using .031 (1/32) board, though I have
run some 1/16 inch board through with no problems. The board is only
in the printer for 1.3 inches.
The mechanics of my printer enable boards as small as 1.5 inches to
be fed through without a carrier. If I were to use a carrier, I could
probably obviate the drum damage problem by having the carrier always
in position so no edges are seen by the drum. This would take some
doing because you can't feed the board till the drum is charged.
The toner density seems fine to me - it certainly resists the enchant
in my experiments, so far. The toner seems TIGHTLY adhered to the
board. In fact, you can put the board on it's side and rap it against
a desk top without dislodging the toner.
I do have some mechanical issues. As you can see from the photo, the
drive roller steel rod doesn't go all the way across the printer,
limiting the width of the board. The board doesn't print well near
the edges of the drum and at the sides of the board. It works best if
the settings print the board at the center rather than to the right
side (it can't reach the left). The board should also be somewhat
wider than the desired image to keep away from the board edges. I can
fix most of this by changing the rollers to provide a much wider path..
Mark
At 01:54 PM 4/5/2008, you wrote:
>Hi Mark,
>that is no problem.
>Thanks
>ST
> >  Mark
