>From: listgroups08@...
>Sent: Apr 2, 2008 9:14 PM
>To: Homebrew_PCBs@yahoogroups.com
>Subject: Re: [Homebrew_PCBs] Direct Toner - First Try Results
>Hello Mark,
> That is great to here!
>I can't immediately think what is causing the pitting to be in lines or
>streaks. If would have been great if you took a high resolution scan and put
>it somewhere where it can be downloaded. I have web space if you need.
>As for the opto sensor and registration, it may be worth mentioning that all
>opto sensors are not created equal. The worst problem with the mechanical
>flag type setup is that variations in movement from one activation to the
>next is the main cause. A direct opto sensor setup without the pivoting
>actuator is hundreds of times better.
>The common garden variety sensor used most in domestic electronics is a
>0.5mm. In other words the optical path is 0.5mm wide. These may be fine for
>some boards but if you are working down to 2mil resolution then they may not
>be so good.
>Physically and electrically identical opto sensors are available that only
>differ in optical path width. These go down to 0.01mm. If you can tell me
>approximately where you are then I will find a supplier close to you.
>You can get more registration reliability from the more common sensors by
>reducing the influence of optical and electrostatic noise and bias. Just put
>it in a metal shield to block out electrical interference and ambient light.
>The darker the sensors environment the more consistent it will be. As the
>actual sensor part of it is a semiconductor (photo transistor) it can also
>be influenced by electrical noise.
>The split board method will always solve this problem but I feel that it
>causes unnecessary work. In my project (inkjet direct etch resist) I will be
>drilling two registration holes in the board to clip onto pins in a truly
>flat bed printer.
>I am looking at my old laser printer now and wondering if I should bother to
>buy a new inkjet printer. Perhaps after your success I should go directly to
>laser direct etch resist.
>I looked in the shed the other day and I have quite an amount of single side
>laminate that is about 0.2 - 0.3mm thick along with plenty of single sided
>FR4. Perhaps I should try the thinner laminate in the laser.
>I have a spare image drum to, so perhaps my laser printer should be getting
>nervous.
>Keep up the good work, your getting excellent results, well capable for SMD
>work.
>My hobby work is digital so I need good resolution as well.
>Thanks, Robert.
>----- Original Message -----
>From: "Mark Lerman" <mlerman@...>
>To: <Homebrew_PCBs@yahoogroups.com>
>Sent: Thursday, April 03, 2008 9:31 AM
>Robert,
>My second try was MUCH better. I noticed that the pitting was
>actually more like streaks, all going in the same direction. Perhaps
>caused by the gel?? Or not enough fusing?? Anyway, this time I used
>no gel, then ran it through the laminator 4 times, once in each
>direction. I etched it, and the results seem about perfect. No
>pitting, no smearing. The 2 mil traces are perfect! I suspect I can
>get them closer together than the 10 mil centers I am using now, but
>these are pretty fine traces and more than adequate for what I usually do.
>I used a precision optical sensor to find the leading edge of the
>board as it enters the printer. I wonder if I can make double sided
>boards with adequate registration? For now I think I'll stick with
>what I have. A double sided board can easily be made using thinner
>board and gluing two boards together using registration holes and pins.
>Mark
>At 06:59 PM 4/2/2008, you wrote:
>>Hello Mark,
>> An afterthought or two.
>>I find that when I have to visually examine something in fine detail, it is
>>easier to scan it on my scanner at maximum resolution and then scroll
>>through the image on the PC screen. Perhaps you can do this with the fuser
>>PCB to look for clues.
>>If the problem is air pockets then it may pay to go over the PCB with very
>>fine sand/emery paper (1200) before printing.
>>Robert.
>>Sent: Thursday, April 03, 2008 7:16 AM
>>Subject: [Homebrew_PCBs] Direct Toner - First Try Results
>>I just made my first (single sided) board using my modified laser
>>printer that deposits toner directly on the board. A few observations
>>and questions:
>>1- I used the Eagle Demo2 board, but inserted four 2 mil traces
>>between 2 of the dip pads, each connecting to one of 4 adjacent pads.
>>These are 2 mil traces on 10 mil centers, with the traces on the
>>sides being 7.5 mils from the pads.
>>2 - I used some of Dave's gel on the 1/32 inch thick board - will try
>>without it later.
>>3 - I then ran the board through a laminator once - no carrier.
>>4- I etched using muriatic acid / peroxide, room temperature, a
>>little agitation by hand rocking the board.
>>The board came out okay, but there is some pitting that I am not
>>happy with. All four 2 mil traces are intact, none of them are
>>shorted. Questions:
>>1 - Should I have run the board through the laminator more than
>>once? I bought the laminator at Staples, no model number on the box,
>>but I believe it is one of those recommended on the laminator link.
>>I'll have to measure the temperature sometime. Any other thoughts re
>>the laminator?
>>2 - Would I be better off using an oven or hotplate to fuse the
>>toner? I can control the temperature quite well, but will the toner
>>fuse well without the pressure?
>>3 - What causes the pitting? Too long in the etchant? Toner not
>>completely fused? All the traces and pads seem equally pitted, so I
>>don't think it's the trace width.
>>Lots of questions, but I realize that I am on somewhat uncharted
>>territory here. It's going to take time and experimentation to work
>>it all out, but I'm excited by the possibilities of this technique.
>>Mark
>>Be sure to visit the group home and check for new Links, Files, and Photos:
>>http://groups.yahoo.com/group/Homebrew_PCBsYahoo! Groups Links
