Immersion silver
Immersion silver
2008-03-28 by Leon
I've just had a double-sided prototype made by PCB Train using their
low-cost Express prototype service (no solder mask or silk) - I got the
board in three days for 30 GBP. They use immersion silver for all their
PCBs, which is new to me. It seems just as easy to solder as HASL tinning.
It might be a useful alternative to immersion tinning for homebrew PCBs,
with much better solderability. I don't know how easy it is to use, though.
PCB Train is here, if anyone else is interested in this service:
http://www.pcbtrain.co.uk/welcome.php
They actually make the boards in 24 hours. They don't do any checking of the
Gerbers for this service, so you need to make sure that the design conforms
to their specifications.
I'm very pleased with the board. It's nearly all surface mount with an
Altera MAX II CPLD in a TQFP-100 package. I've assembled enough of it to
check that I can program the CPLD via the JTAG connector with my USB Blaster
and it's OK so far. I haven't even got any decoupling capacitors or JTAG
pullup/pulldown resistors on it yet, so I was a bit surprised that I could
program it.
Leon
Leon Heller
Amateur radio call-sign  G1HSM
Yaesu FT-817ND transceiver
Suzuki SV1000S motorcycle
leon355@...
Re: [Homebrew_PCBs] Immersion silver
2008-03-28 by Leslie Newell
Hi Lean,
Immersion silver works great if you use it fairly quickly. However if
the boards stand for more than a month or so, the silver oxidises and
they become quite difficult to solder.
Les
> program it.
> Leon
2008-03-28 by Adam Seychell
> program it.
I don't know anything about immersion silver. I was surprised Google
didn't show up much. http://www.freepatentsonline.com/EP1391536.html
mentions a preferable silver immersion solution contains 0.2 to 5g
silver nitrate with some acid. I'd try citric acid as a start, but my
AgNO3 is packed away so I can't easy test it. AgNO3 is available from
any photographic supplier store. Its not cheap. Alternate is buy some
silver and dissolve it in concentrated nitric acid. But nitric acid
isn't always easy too get.
Its good to see other low runs PCB companies competing with some of the
cheap manufactures in Asia. It might mean we expect to see prototype
PCBs keep dropping in price as the companies improve their process
efficiency.
The nature of PTH PCBs fabrication doesn't make it easy for anyone to
cut corners.
2008-03-29 by Dylan Smith
Incidentally, I'm just about to (once I've thoroughly checked the PCB
layout for correctness!) send off a 4 layer PCB to PCB Train. How does
immersion silver hold up on edge connectors? I think it's the only plating
they offer for 4 layer boards.
2008-03-29 by Leon
Sent: Saturday, March 29, 2008 12:07 PM
Subject: Re: [Homebrew_PCBs] Immersion silver
I think it's only 1 micron thick, so it'll get scraped off quickly. You
really need gold plating on them, or use an indirect connector.
Leon
Leon Heller
Yaesu FT-817ND and FT-857D transceivers
leon355@...
2008-03-29 by Matthew Smith
Quoth Dylan Smith at 2008-03-29 21:37...
Dylan (and others interested in immersion silver) - have a look at this:
<http://www.pcbfast.com.au/wp-content/uploads/2007/02/surface_finish.pdf>
Gives the pros and cons of the varying finishes that this board house
offers - including immersion silver.  (And no, it's no good for edge
connectors.)
Cheers
M
Matthew Smith
Smiffytech - Technology Consulting & Web Application Development
Business: http://www.smiffytech.com/
Personal: http://www.smiffysplace.com/
LinkedIn: http://www.linkedin.com/in/smiffy
