Etching tank, build or buy?
2007-11-23 by Dave
Is there some simple but professional plans to build an etchant tank? I
mean with heater and agitation, not just a jar and manual labor:) Or is
one available that is professional but not too pricey? I seen one for
$50 and I bookmarked it. http://www.web-tronics.com/lowcosetsysw.html
Is that worth the $$ or could I make something with aquarium parts
(heater, pump, etc). I was also planning on using ferric chloride as I
have a bottle from RatShack from when I started getting interested in
this some years ago. I know there are other etchants and comments are
welcome on whats best but I think other than the staining and inability
to see your boards progress, ferric chloride is probably as good as the
others??
Dave
Re: [Homebrew_PCBs] Etching tank, build or buy?
2007-11-23 by Dylan Smith
I've found a plastic food-style container and manual agitation works fine.
All I do is full a large outer tank with hot water, and float the ferric
chloride container in the hot water. This also allows me to give the board
a quick dunk in the water to see how its progressing. Etching times are
pretty damned quick.
> others??
I've not used other chemicals, so I can't comment on them, but ferric
chloride is less nasty than most, and it lasts a long time. I'm still
using a 250ml batch I made up in January, and I've done loads of boards in
it (some double sided 6in by 4in boards). I do tend to put a large "copper
pour" area (just drag a polygon over the design once I've finished it) or
ground planes, which reduces the amount of copper that must be removed.
(Although on the flip side, I also tin my boards so I go through more
tinning solution!)
Someone told me that a bit of table salt can help rejuvinate ferric
chloride, too. I did add some when I thought the solution was getting
tired.
2007-11-23 by Dave
fine.
board
 > > others??
boards in
"copper
 > tinning solution!)
 > tired.
Dylan,
  Good info. I was originally going to scheme up some type of agitator
like a see-saw or wobble device and use a plastic tupperware type
container. A small geared timer motor with a cam or something like that.
I was also wondering how long ferric chloride lasts but now I know it
lasts a while and is reusable. I started buying small parts and books
and solder and etchant and boards years ago but never got the time to
actually get anything done. I got as far as getting some photo paper and
a laser printer and ironed a test onto a board but never etched it. Now
I want to play with small simple circuits but also useful ones. I have
an interest in alternative energy (just not enough $$ to invest yet) so
I am going to play with small stuff for now....
Dave
>  ,_._,___
2007-11-23 by Harvey White
>others??
Walmart has a bread container that's inexpensive and makes a good
container for etchant.  An air pump with aquarium hose makes a good
bubbler.
You can use an aquarium heater, but you want the one that has a knob
on top that does not have stops.  You need to be able to turn this up
to broil setting for fish, mostly because the normal ones are limited
to 80 degrees F.
Harvey
>Thanks,
>Dave
2007-11-23 by Philip Pemberton
1) Buy one of those Tupperware-style cereal containers - the big tall
two-or-three litre things.
2) Glue a pair of 4" x 1" chunks of plastic (Perspex, Plexiglass, whatever's
lying around) onto the bottom on either side -- one 4x1 on the left, one on
the right. This should help stabilise the tank.
3) Buy an air pump, bubbler hose and fish tank heater from your local pet shop.
4) Glue the hose into the bottom of the tank - use something fairly inert and
heat resistant. Araldite works a treat, 5-minute epoxy is slightly better
(slightly stronger and more time to work with it before it sets).
5) Glue the heater support clip onto one side of the tank, then mount the heater.
6) Fill the tank about three-quarters full of water. Fire up the bubbler and
the heater. Leave it like this for a while to get any glue residue out. Drain
and repeat.
7) Fill the tank about three-quarters full of etchant. Fire up the heater
about 20 minutes before you need the tank, and turn on the bubbler once the
etchant is warm.
8) Drop your board in the tank. Wait for it to etch, then pluck it out. I
usually drill a hole in the corner of the board and thread some insulated wire
through it, then lift the board out by the wire.
Probably not the best way to do it, but it works for me!
I've got some photos of the thing if anyone's interested.
Phil.                         |  (\_/)  This is Bunny. Copy and paste Bunny
ygroups@...         | (='.'=) into your signature to help him gain
http://www.philpem.me.uk/     | (")_(") world domination.
2007-11-23 by Markus Zingg
Dave,
Just my 2\ufffd, but that web-tronics offer seems fairly good to me. Not only
is it a molded tank (and as such definately never leaking), but made for
the purpose including hangers pump etc. I mean, even if you put your own
etching system together, you are likely to spend a similar amout of
money let alone the time you need to get the different parts etc.
The reason I see why one makes his own tank could be lead and delivery
time to get said tank though :-) I also made my own tanks over time, but
I must say I'm really impressed by this offer.
Again, just my 2\ufffd here....
Markus
> <http://www.web-tronics.com/lowcosetsysw.html>
> others??
> Thanks,
> Dave
2007-11-23 by Kim Vellore
I have this tank with the glass heater which I found broke one day, I was
wondering what would have happened if I had turned it on with 120V, is the
acid conductive enough that it blows up, is it a safety concern? I have been
looking for the shatter proof heaters which can go that high a temperature
and cheap...
My 2C on building your own avoid gluing and build the tank it is not worth
the trouble, imagine the damage if it leaks, try to use a solid container. I
use a bigger secondary container too I had a spill once a small one when I
tripped over the tank it was a terrible mess, and it never gets 100% clean.
Kim
Sent: Friday, November 23, 2007 11:27 AM
Subject: Re: [Homebrew_PCBs] Etching tank, build or buy?
> whatever's
> on
> shop.
> and
> heater.
> and
> Drain
> and repeat.
> the
> etchant is warm.
> wire
> Bunny
> gain
> Photos:
Re: Etching tank, build or buy?
2007-11-23 by Andrew
Those tanks are actually molded from two peices and
glued together.  I have had several over the years.
Some HAVE leaked at the glue seam.  Now I am using
an acid based etchant the latest tank I have is
developing crazing and slow leaks in the walls.
I do store it ALL in a large HDPE box though so
leaks are not catastrphic.
--- In Homebrew_PCBs@yahoogroups.com, Markus Zingg <homebrew-
pcb@...> wrote:
> Dave,
> Just my 2¢, but that web-tronics offer seems fairly good to me.
Not only
made for
your own
of
delivery
time, but
> Again, just my 2¢ here....
> Markus
tank? I
labor:) Or is
one for
lowcosetsysw.html
parts
chloride as I
interested in
comments are
inability
as the
> > others??
> > Thanks,
> > Dave
Re: [Homebrew_PCBs] Re: Etching tank, build or buy?
2007-11-23 by Leslie Newell
The last place I worked at used to have a tank made of glass glued with
silicone. This technique is very common on fish tanks and they seldom
leak. Unfortunately after a couple of years the acid weakened the
silicone. One night it collapsed, dumping at least a gallon of etchant
on the floor. The room below now has a big yellow/brown stain on the
ceiling that no amount of paint will cover up.
Les
2007-11-23 by Dave
 > bubbler.
 > to 80 degrees F.
 > Harvey
Thanks Harvey for the added info.
Dave
> ._,___
2007-11-23 by Dave
whatever's
one on
pet shop.
inert and
the heater.
bubbler and
out. Drain
 > and repeat.
once the
 > etchant is warm.
insulated wire
Phil, I would like to see a picture of this contraption :)
Dave
2007-11-23 by Dave
 > Les
Glad to know this as I was thinking about the home made custom aquarium
tank.
Dave
2007-11-23 by Dave
I am thinking make it out of one-piece plastic and go with mechanical
agitation. No leak worries.
Dave
2007-11-23 by Dave
is the
have been
temperature
 > and cheap...
worth
container. I
when I
clean.
 > Kim
I am thinking no-glue with tupperware or something similar. Don't know
that I ever had a fish tank heater break before. Is this common?
Dave
2007-11-23 by Dave
Markus Zingg wrote:
 > Dave,
 > Markus
Markus,
  If they lasted without leaking (as someone else noted) then it would
be a great deal. If they end up leaking, or the possibility is there,
then I may as well just make one. Besides, thats part of the fun. I will
get to scheme up a mechanical agitator. :)
Dave
Dave,
The pictures (and description) in the link you gave made the impression
to me that the tank is molded as one piece. If now - acording to the
experience others obviousely have made this turns out not to be true -
you are IMHO right that its similar to doing your own then. If you also
get the air pump heater etc. for just $49 I still think it's a very good
offer but hearing that the tank is not made of one single piece is a
bummer....
Anyways, I do my tanks using polystyrene glass sheets that I cut into
the shape I need using a fine circular table saw and "glue" them
together. I use Methylenchloride as the glue and this chemically welds
the parts together. So this is not really the same as glueing in the
traditional sense. In fact, the this way chemically welded parts are so
strong that if you mechanically try to break such an area, it usually
breaks elsewhere. The key here is that if you cut the sheets into shape
you use a fine saw so as the areas which are glued together are even
with no unregularities or such. The nice part about the polystyrene
glass is that you can see the "glued" area all through the material like
if you would X-ray it if it were a different material and as such you
can optically check if it will hold forever or if there are areas where
it did not worked out well.
Obviousely, for a pure etching tank, using a redy made available
container is not wrong. I must admitt that the tanks I do are for the
trough plating station where space is  constrained and where bigger
tanks mean spending partially lots of money more for pricey chemistry
just because the tank is not optimally sized. For the first incarnation
of the tanks about four years ago, I welded the plastic using a hot air
gun because I too was afraid of leakage back then. Now with the
experience of using Methylenchloride I definately don't want to go back
to this hassle.
Btw, I always fill the tanks of my machines only for relatively short
periodes of time. I don't care leaving the fluids in there for a couple
of weeks if I'm in a phase where I do a couple of PCBs in a row but once
this phase is over, I always fill the fluids back into containers that
can be air sealed and which are made of one piece of plastics (Sorry,
don't know the propper term for them cause english is not my native
language, but I hope you know what I mean). I do so to avoid loss of the
partially pricey stuff (it otherwise vaporizes over time) and also for
security reasons. There are cheap (about 1$ a piece) hand pumps
available in flower/gardening stores which are excellent tools to fill
such fluids back and forth withouth ever spoiling a single drop.
Markus
Dave schrieb:
> Markus Zingg wrote:
> > Dave,
> > Markus
> Markus,
> Thanks,
> Dave
2007-11-24 by Harvey White
On Fri, 23 Nov 2007 15:17:28 -0600, you wrote:
You're welcome.  Some stuff on PC boards at www.dragonworks.info in
the PC board section.
Harvey
> > bubbler.
> > to 80 degrees F.
> > Harvey
>Dave
>> ._,___
On Fri, 23 Nov 2007 15:32:04 -0600, you wrote:
I have a commercial tank, GBC, I think.  I would not buy it again.
It has:
1) fitting lid
2) no heater (supply your own)
3) solid plastic molded everything
4) bottom molded plastic holder with bubbler tube
5) threaded nylon rod to pull out the holder and tubes
PROBLEMS:
1) holds a lot of etchant
2) rod broke at the bottom, stress, etchant, whatever
3) not a good seal at the top
4) holds 1 1/4 gallons of etchant.
Making my own holder from some fiberglass/nylon rod and making a
bubbler tube by drilling cheap fish tank tubing works well.
Bread container from WalMart seals better than commercial tank with
tubing holes....
Bread container needs less etchant
CONS:  Bread container will etch only one board at a time if the board
is large enough (say 5x7).
Harvey
>Markus Zingg wrote:
> > Dave,
> > Markus
>Markus,
>Thanks,
>Dave
2007-11-24 by Dave
 > Harvey
Nice informative website. It looks like I have a lot of catching up to do :)
Dave
2007-11-24 by Dave
Markus Zingg wrote:
 > Dave,
 > bummer....
 > to this hassle.
 > Markus
Markus,
 Thanks for the follow up info. Its all good. I have seen other people
use a similar, if not the same method gluing plastic like plexiglass
into molds (boxes) and it produces excellent results. As you said, the
key here is to be able to cut accurately so the chemical can weld the
plastic together. Usually easier said then done unless you have the
correct tools. I have a workshop and some wood working tools so maybe
some day I will try it. :) I think the term you were looking for when
sealing the bottles is "vacuum sealed" maybe? I like all the ideas so
far and this seems to be a friendly group. Just remember, I am a
beginner so even though the ideas are great, I may have to start with
simple ideas and methods until I get going...
Dave
2007-11-24 by Dave
 > It has:
 > 1) fitting lid
 > PROBLEMS:
 > tubing holes....
 > Harvey
Harvey,
  Your website is great. I have been reading and finding answers to some
of my other questions as well. Of course it will be 30 years before I
catch up but I will take what info I can absorb for now :)
Cheers,
Dave
On Fri, 23 Nov 2007 20:08:33 -0600, you wrote:
You're welcome.  Feel free to email with questions.
Harvey
> > Harvey
>Thanks,
>Dave
2007-11-24 by DJ Delorie
Harvey White <madyn@...> writes:
I have one.  What about fumes?  I was thinking of switching to
HCl/H2O2 (because it can be regenerated) but I worry about the
chlorine fumes, as I'd be doing it in my basement, which also contains
my woodworking equipment and some computers.  (it's too cold to do it
outside).
>outside).
The fumes from FeCl3 corrode metal for several feet around.  I think
that the HCL mixture will be worse, and that's just the acid.  I'd not
do any etching inside at all, I'd do it outside, even though it's
cold.  You'll want to warm the etchant anyway, and a fish tank heater
can do that.
I'm not happy about the chlorine myself, which has stopped me from
experimenting with the HCL mixture.  I am pretty much completely out
of F3Cl3, though, so if I want to make any more boards, I need to etch
with the HCL mixture.  Herbach & Rademan no longer sells the gallons
of FeCl3 that I had been buying.
I'll be etching way away from the cars and any machinery.
Harvey
2007-11-24 by Andrew
> thinking of switching to HCl/H2O2
> worry about the chlorine fumes, as
> also contains my woodworking equipment
> do it outside).
Try going straight to CuCl as it does
etch better edges than HCl-H2O2.  Also
there should be less vapour.
I would not recomend either in a close
space with your other equipment though.
Either get some venting to outside just
for the tank or try get some kind of
air scrubbing happening.  Else you WILL
have rust quickly forming on everything.
2007-11-24 by Dylan Smith
Actually, that's what got me going. A while ago, I wanted to get various
garden electrics going (night lights, pond pump etc.) and I was going to
have to get an electrician to lay all the cables, connect it all up etc.
So I thought - for that money, I could get a 2nd hand solar panel off an
ebayer that'd power it. I thought it would be a fun project.
Then I needed to make the night lights automatic, and having meddled a
little with electronics when I was about 17, I thought it shouldn't be too
hard. So I bought a couple of voltage comparator ICs, a few passives,
patch wires, breadboard, strip board etc.
... and got addicted.
... within a year of that little project, I had designed and built my own
8 bit computer. Now I'm making my own 2 sided PCBs for very fine pitch SMD
(0.4mm pitch LQFP-80, for adding ethernet to the aforementioned Z80
computer). Indeed, I can now make a PCB faster for surface mount (fewer
holes to drill) and hand solder many SMD components faster than I can
through hole (1206 and 0603 passives are very fast, no wires to clip! SOIC
is a doddle, as easy as DIL but without the holes to drill. SSOP is
rather slower though). A future project is to build a reflow toaster oven.
So beware. You, too, may find yourself drawn to the inevitability of
homebrewing your own computer!
2007-11-24 by Dave
I was looking on my old pc's to see what PCB software I used when I
first got interested but got to the Win98 box and it wasn't there so it
must be on the Win95 box! So I guess its been about 10 years since I
attempted this hobby but had no time. I am going to have to learn a
bunch of new terminology as I am not too familiar with SMD (surface
mount device) technology although it looks rather cool. Special
equipment like hot air and tweezers etc but I will be going the old
fashioned route for now :) I used to be into Commodore computers so I
know the 8-bit technology rather well, in fact I still have a bunch of
Commodore stuff. I used to run a BBS with hard drives (SCSI) connected
on a C64! I have some learning to do in the electronics department too.
I have lots of books though but am mainly familiar with simple
components. I am totally aware though that one could get carried away
with this stuff as its very interesting. So how did the solar panel
project end up working? All DC with battery storage or more panels and
more batteries and an inverter?
Dave
2007-11-24 by Dave
 > Harvey
Thanks. I will probably take you up on that once I get some qualified
questions. I will ask my beginner questions here to start so I don't
wear out my welcome.
Dave
> _._,___
2007-11-24 by Dave
Harvey, Eagle CAD Notes (under electronics) brings up the Making PC
Boards page. I tried to email at the site but it bounced. :(
Dave
> Harvey
>Thanks,
>Dave
OK, no problem.  I'll fix the link as well as look at the email...
http://www.dragonworks.info/Electronics/making%20PC%20boards/pc_board_design.htm
That's the direct link.
Although the subjects are similar....
Harvey
>> Harvey
2007-11-24 by James Newton
tank? I
Or is
for
as I
in
are
inability
> others??
> Thanks,
> Dave
It has been my experience that bubblers and other agitation methods
are not worth the hassle. The generally make it difficult to contain
the etchant (leaks, spray, etc...) and require more echant be used
than is really necessary.
Floating the board on the surface of hot echant is almost as
effective as the bubbles anyway. The removed material falls away as
it etches clearing the way for fresh etchant to be applied to the
next layer.
I would suggest a simple system of a metal pan of hot water on a
stove or hot plate with a shallow plastic pan of echant in it. Pour
in a little echant, just enough, then  float the board and check on
it until you can see through from the top. For double sided, do one
side at a time and tape the side on the top.
2007-11-25 by Dave
> next layer.
Simple is good. Is it necessary to heat all etchants or just ferric
chloride?
Dave
> ,_._,___
2007-11-25 by Dave
 > >Thanks,
 > >Dave
 > Harvey
Thanks Harvey. I have the error messages etc from the bounced mail if it
helps you resolve the problem. Let me know if you want me to post it
here or send it to you. It says something about inactivity and also has
a phone number to contact support.
Dave
2007-11-25 by Dennis Waggoner
If your using HCL and H202 Use only a plastic or rubber container. No
metals!
I use 1 part HCL and 3 parts H202 in cold weather and 1 part HCL and 4
parts H202 in warm weather. Not nessecery to heat the solution.
For a 6X6" PCB or smaller I have a tupperware square container about
10" square and cover the pcb with about 1/2 to 3/4' of a inch of etchant.
I found that I you gently pry up one side of the PCB with a plastic
fork or knife so that it is lifted up out of the etchant back and
forth the removal will go faster. About five minutes to etch a 6x6" board\
Dennis Waggoner
2007-11-25 by Roland F. Harriston
Errrr............
I don't think you want to use metal around Ferric
Chloride! Unless it is a high grade stainless steel.
Roland F. Harriston, P.D.
> metals!
> Dennis Waggoner
2007-11-25 by Dave
 > metals!
board\
 > Dennis Waggoner
Thanks for the added info. I like the part about "no heat" necessary.
Dave
2007-11-25 by Dave
Roland F. Harriston wrote:
> Errrr............
> I think James said to put the metal outer pan of water with a plastic
> container inside of it like a double boiler. Dennis said to use rubber
> or plastic.
Dave :)
2007-11-25 by Harvey White
> > >Thanks,
> > >Dave
> > Harvey
Yeah, I'd be interested in seeing that message.  Depends on the email
address what the problem is, though.
Harvey
>Dave
Repeat..............
Don't use metals around Ferric Chloride.........period.
 > or plastic.
2007-11-25 by Dave
> Thanks
> Harvey
Ok, sent you the info to the "madyn" address.
Dave
--- In Homebrew_PCBs@yahoogroups.com, "Roland F. Harriston"
Please let me clarify the HCL and H202
HCL is standard Muriatic Acid (aprox 33%)availible at walmart $4.00/gal
H202 is 3% about a dollar per quart also at walmart the kind used to
treat cuts
I might add neither are temperature sensitive. I store both in a
outside garage with extremes of temperature both summer and winter.
Just make sure you dont store the HCL near anything metal because some
fumes will leak out and corrode it.
Water dilutes the acid and I alway have a full 5 gallon bucket of
water near me when I etch. After the etching is completed I carefully
remove the pcb and rinse it in the bucket. Then I just dump the
etchant into the five gallon bucket. This makes the disposal easier as
the solution is then only mildly acidic.
Be carefull dont get your eyes anywhere close to the etchant.
Dennis Waggoner
2007-11-25 by Dave
Serious question. How far is the minimum safe distance from metals where
ferric chloride can affect them? I mean just the fumes and not a direct
spill or slash. Does the Muriatic-Hydrogen Peroxide require the same
rule exactly or is ferric chloride the worst one?
Dave
2007-11-25 by Dave
 > treat cuts
 > Dennis Waggoner
Dennis, So in the unmixed form is the muriatic acid going to corrode by
fumes leaking or only when mixed with the hydrogen peroxide? I have a
steel building and need to know how far from the walls I need to store
it so I don't mess it up.
Dave
> _
> _,_._,___
Ferric Chloride, my experience is about 3-4 feet to be safe.
Harvey
>Thanks,
>Dave
> Thanks,
> Dave
> > _
> > _,_._,___
When its mixed with 3%H2O2 it is even less concentrated. The
combination of both generates less fumes. I usually etch outside and
you dont even notice the fumes. When you store Muratic Acid. If the
lid is not tight fumes will leak out and corrode any metal withing a
foot or so. That is the only percaution you need to take storing.
When mixing be very carefull not to splatter the mixture into you
eyes. Pour the acid into the h2o2 not the h2o2 into the acid. That is
the most dangerous part of the operation and there are some very
noxious fumes generarated at this point. One again keep you eyes away
from the mixture. Use goggle would be the best bet when mixing. And
also if you are manually agitating the pcb up and done in the etchand
to speed the process again you can generate spatters so watch you eyes
here also.
Dennis Waggoner
Re: [Homebrew_PCBs] --- In Homebrew_PCBs@yahoogroups.com, Dave
2007-11-25 by Dave
 > here also.
 > Dennis Waggoner
Dennis,
Thanks for the info. I have used NaOH (sodium hydroxide) for making soap
so I always added that to the water so I understand the reason. I also
have full face safety shields so I am good there too.
Dave
> _,___
2007-11-25 by Dave
 > Harvey
Ok, sounds reasonable. I guess in its original sealed plastic bottle it
is fairly harmless? I had mine under the kitchen sink for years. Radio
Shack 16oz bottle.
Dave
> ._,___
Dave:
I personally think that Ferric Chloride is one of the worst compounds to
have around in a domestic environment, or in any environment that is
not specifically designed to accommodate this material. Most of the
technical descriptions that I have seen regarding this material
describe it as "highly corrosive". It emits fumes even at normal room
temperature.
Muriatic+Peroxide is also corrosive, but not as bad as Ferric Chloride.
Employ measures to protect.
> > Repeat...... ........
> > Don't use metals around Ferric Chloride.... .....period.
> Thanks,
> Dave
On Sun, 25 Nov 2007 11:28:13 -0600, you wrote:
> > Harvey
If the bottle has a relatively narrow mouth, and the cap is tight, I
think you're ok for most stuff.  I'd put it in a plastic ziplock bag
(freezer type, heavy duty) as an additional precaution.
Just being paranoid.
Harvey
>Shack 16oz bottle.
>Thanks,
>Dave
>> ._,___
2007-11-25 by Dylan Smith
In my opinion, they are all pretty nasty, and ferric chloride is the least
nasty of a nasty lot... after all, hydrochloric acid is one of the harmful
products of mustard gas (a WWI chemical weapon). The EPA classes HCl as a
toxin, and at concentrations above 25% it's highly corrosive.
Ferric chloride is nasty stuff, but at least you notice small spills of it
straight away because of its distinctive colour, where a spill of HCl
won't necessarily be recognised as such until bad stuff starts to happen.
I keep the ferric chloride out of the house, in a container in a stone
built shed. Less nasty stuff I keep in those 'bellows style' photographic
chemical bottles, which I think are excellent to have around (fill them
with liquid, then push them down to eliminate as much air as possible, and
they have good chemical resistant, gas tight caps). I try to do as much
etching as possible outside (if it's cold and nasty I will do it inside,
but with plenty of absorbent material under the etching area to try and
catch any splashes/spills).
Dylan Smith:
Well.................
Out in my neck of the woods, it is quite common to see 2 or 4 gallons of
Muriatic in the pool shed or in the garage of many homes. I personally
keep a bottle of Hydrogen Peroxide in the medicine cabinets in my home.
And right now, I have two gallons of Muriatic acid in a wooden storage
cabinet in my garage, right next to my two automobiles, and have had so
for going on 11 years now.
I can't ever recall of a single incident regarding these materials
during the
time I have lived in southern California and southern Arizona, and that
amounts to over 40 years. You have to remember that the HCI that we
call Muriatic acid only 30 Baume, and the H2O2 is only a 3% solution.
To each his own. But I pleased that I don't have to have that nasty
brown stuff around the house anymore.
2007-11-26 by Russell Shaw
> Dave:
> temperature.
I just put a block of wood over the Ferric Chloride etching tank when
i'm not using it. I typically do 30+ PCBs in it and change it once a year
or two. I add a bit of HCl every few months to keep it more active.
Much more economical than Muriatic+Peroxide and doesn't degrade with time.
Your gut contains a large amount of HCl.
Beware the dangers of dihydrogen monoxide. It can be deadly;)
2007-11-26 by Roland F. Harriston
Let us be realistic!
Example: The volumetric area of my garage is 3600 cubic feet.
If I were to do my PCB etching in this area, how much effect is the
"possible, but very remote" generation
of a minute amount of dihydrogen monoxide that might be generated
by approx. 12 ounces of a 80 Baume muriatic acid and 3% hydrogen
peroxide going to have in this volume of air ??
The danger in a well-ventilated area is reduced to virtually nil.
If I put a hood over my head over the solution in an open tray, I might
have some
problems, but I don't do that kind of stuff (anymore).
Life as as an intelligent human generally revolves around some
sense of practicality.
> compounds to
> least
> harmful
> as a
2007-11-26 by Cláudio E. Elicker
> > least nasty of a nasty lot... after all, hydrochloric acid is one of the
> > harmful products of mustard gas (a WWI chemical weapon). The EPA classes
> > HCl as a toxin, and at concentrations above 25% it's highly corrosive.
Yup. Very dangerous ;-)
http://www.dhmo.org/
2007-11-26 by Dylan Smith
Specifically, your stomach, but you still don't want to get HCl on you.
Your stomach goes to enormous lengths to prevent the HCl from damaging
other tissue. HCl is not quite so good on the skin, and is really bad on
the lungs or mucous membranes.
My point is all these etching chemicals are pretty nasty, and you don't
really want any on you.
2007-11-26 by Myc Holmes
A couple of thoughts on Ferric Chloride...
Ferric Chloride will slowly dissolve an aquarium air stone.
It is the Ferric Chloride mist that causes problems in the area around
the etching tank. Unlike the HCL, with a much lower vapor pressure,
which also becomes a gas and affects a much larger area.
Yes, Ferric Chloride reacts with most metals, so use plastic.
Ferric Chloride will stain everything.
Overall. Ferric Chloride is less dangerous to work with than the
Muriatic (HCl) Acid..
Be Safe! Use eye protection and rubber gloves.
Myc
(retired Industrial chemist)
2007-11-26 by Dave
Wow, I didn't expect to generate all this by posing the best etchant
question but I did learn a lot from it. The bottom line is treat it like
any other chemical that is highly dangerous and be careful and safe and
all should be ok. I will etch outside, wear eye protection and work
upwind when possible and not breathe the fumes. And of course I won't
get any on me. Common sense is the key. But I am still glad I asked. :)
Also, some interesting reading on the DHMO.
Dave
> ,___
2007-11-26 by agscal -AGSCalabrese
I recommend you get an assistant and let them
take the risk.
Cedric
Dave
 > ,___
2007-11-26 by Dave
 > take the risk.
 > Cedric
:) Thats one way to be safe!
Dave
> ._,___
2007-11-27 by Herbert E. Plett
> deadly;)
specially if you swallow more than four gallons at a time...
Get easy, one-click access to your favorites.
Make Yahoo! your homepage.
http://www.yahoo.com/r/hs
