[Homebrew_PCBs] creative use for PCBs
2007-09-24 by Stefan Trethan
Saw a novel use for PCBs yesterday on Mythbusters.
They had to get past a fingerprint lock.
The way they did it was lift a fingerprint, scan it, touch it up, etch
a PCB from the image, and then cast latex or gelatine over it to make
a 3D finger.
It worked! The simple PC lock was fooled by it, when it did not take a
simple printout on paper. The supposedly advanced door lock was even
fooled by the paper print, once it was licked to simulate the
conductivity.
Shows how simple these locks are to fool. I mean, come on, using a key
that leaves an exact print of it's shape hundreds of times a day for
anyone to pick up, just crazy!
Anyway, really interesting use of a PCB to make a precise
two-and-a-half dimensional mold of the fingerprint. They used
photoprocess by the way, and FeCl.
ST
Re: creative use for PCBs
2007-09-24 by Len Warner
>a 3D finger.
>[snip] They used photoprocess by the way, and FeCl.
If they had used something like gelatine-dichromate, they could
probably have omitted the copper etch by producing a relief
direct in gelatine. A tanning developer and gelatine removal is also
a way of making artistic (and very durable) photo prints.
Regards, LenW
Re: [Homebrew_PCBs] Re: creative use for PCBs
2007-09-24 by Jennynj1975@aol.com
In a message dated 9/24/2007 4:01:20 P.M. Eastern Daylight Time,
novost@... writes:
If  they had used something like gelatine-dichromateIf  they
Regards, LenW
I hope you use your knowledge for good and not evil.  :)
Jen
************************************** See what's new at http://www.aol.com
2007-09-25 by Stefan Trethan
I didn't know there is such a thing, and they probably also went with
what they already knew. But i don't doubt there are better ways to
make those fake fingers.
What was really amazing is that the printout on paper worked on the
good quality lock which has "never been defeated" according to the
manufacturer. I mean that takes 10 minutes with a simple office
scanner and printer, and you can probably find the fingerprints you
need to copy close by.
It was also interesting to see which tricks worked on the ultrasonic
and IR motion detectors, but none involved a PCB.
If you think about it, carrying a RFID key, keycard, or even a simple
barcode tag would be safer than a fingerprint lock.
ST
> Regards, LenW
2007-09-25 by Cristian
You can read the specifications: they all are AC coupled with poor
response at very low frequency.
slow movement
slow movement or thermal isolation (can use a cardboard)
no, but everyone is interested in security
right
2007-09-25 by Len Warner
>novost@... writes:
> >If  they had used something like gelatine-dichromate [snip]
I blame Stefan Trethan.
Ever since he introduced me to sniffing ammonia bottles
my view of the world has been distorted
(but my mind has seemed much clearer).
Regards, LenW
2007-09-25 by Jennynj1975@aol.com
In a message dated 9/25/2007 10:08:02 A.M. Eastern Daylight Time,
novost@... writes:
LOL! That is the best.  I joined this group to really study the  Chemistry
behind the whole process.  I am a BSChem.  The husband is  the BSEE.  We've been
into the PCBs for a little while now, but nothing  really serious.  He is the
designer and I, the maker of the Boards.   Mostly just for fun, but we are
trying to expand on our work to make some  money.  :)
Nice to see the group is a little chatty.
So what's everyone's backgrounds and interest in making PCBs?
Jen
Backgrounds [was Re: creative use for PCBs]
2007-09-25 by DJ Delorie
Jennynj1975@... writes:
Hmmm... I've beem making boards at home on and off since, um, the
early 80's?  I was in high school at the time, maybe younger.  Back
then I used the press-on decals and pen, now I use toner transfer.
I make my own boards when I want it quickly and/or quality doesn't
matter enough to warrant sending it out, or when I feel like it
(making the boards is part of the fun!).  Usually, it's for test
circuits, adapters, or anything so simple that it can be done without
too many vias.  The last set I made each just held a couple of
pushbutton switches at the right spots behind moving bits.  I.e. the
PCB was more mechanical than electrical.
I've also done many smt to breadboard adapters, for parts I want to
experiment with that don't come in breadboard-compatible packages.
And for reference, the most complex board I've ever designed and had
fabbed was a 386SX PC/AT motherboard.  Yes, it worked :-) I worked at
Data General back then, designing motherboards and writing BIOS code.
Now I work at Red Hat, writing embedded development tools, so I get to
play with hardware a bit still.
The simplest was a SOT-23 adapter for my breadboard.
2007-09-25 by Harvey White
>novost@... writes:
www.dragonworks.info the electronics sections in particular.
Harvey
>Jen
RE: [Homebrew_PCBs] Re: creative use for PCBs
2007-09-26 by Tony Smith
> poor response at very low frequency.
> slow movement
They defeated the ultrasonic detector by simply holding a sheet (as in one
off your bed) in front of them, and walked at a normal pace.  (Might have
been a blanket.)  Not quite what you were thinking.
If you're think 'OMG that won't work', well, so did everyone else!  OMG, it
does!  Yes, I tried it.
One way they beat IR was to get behind a pane of glass (but I already knew
that one).  BTW, that's new glass, some really old glass will pass IR.
Rather than walk around holding up a sheet of glass, they put a small piece
on a rod, and hung it over the detector.  That was actually quite clever.
I recall a documentary once where the thieves beat the IR detectors in a
warehouse by building a wall of boxes (TVs fridges etc), like you said.
Once the wall was high enough they could do what they pleased behind it.
They knew the building layout though.
Where I once worked had an IR sensor that unlocked the door when you were
leaving (so you didn't have to press a button).  I didn't have my pass one
day, so I slid a piece of metal that had been lying in the sun under the
door.
Cool doors, glass with electromagnets to hold them closed.
Tony
2007-09-26 by DJ Delorie
"Tony Smith" <ajsmith@...> writes:
I asked about the magnets once.  It's a fire code thing; the doors
automatically unlock in the event of fire or power loss, just because
the magnets stop working.  With a "power open" lock, people might get
trapped in a burning building.
2007-09-26 by Cristian
At 08:25 PM 9/26/2007, you wrote:
>"Tony Smith"
><<mailto:ajsmith%40rivernet.com.au>ajsmith@...> writes:
they usually use accus as a back-up power supply
>, just because
And what about the multiple reflection paths?
2007-09-26 by Andrew
> pane of glass (but I already knew that
> (TVs fridges etc), like you said.  Once
Freezer suits will give you a few minutes
immunity to IR detectors.  Just long enough
to put it on, run around with some paper
and sticky tape and cover all the sensors
up.
2007-09-27 by pgdion1
Mostly I make pcb's on the hobby side. Some RF stuff (I'm a HAM), some
fun things, lots of test type equipment. The pcb's are way easier and
a lot more fun to make than hand wiring. I like toner transfer since
it's easy. I can draw a schematic, lay down a board, etch it and
populate it faster than I can hand wire and I can use parts that are
way more sophisticated in the TQFP packages. I'll also use the photo
method but I always head for Toner Transfer first. Lately I've also
been laying out and etching proto-types and one-off's for work. Way
cheaper and then I get to do the layout myself. Like you, I'm getting
better at it and I might try to sell a few of my designs (whole
finished units, proto-type design, custom test equipment, ect.)
Only problem is ... so many projects, so little time. :-)
Phil (KA0HBG)
 We've been > into the PCBs for a little while now, but nothing
really serious.  He is the > designer and I, the maker of the Boards.
  Mostly just for fun, but we are > trying to expand on our work to
make some  money.  :)
> Jen
2007-09-29 by Tony Smith
> sheet (as in
> >one off your bed) in front of them, and walked at a normal
> pace. (Might
> >have been a blanket.) Not quite what you were thinking.
What multiple reflection paths?  Bounce of the wall behind the person, hit
the person, bounce back to the wall and back to the sensor?  Right.
I guess that means you take two blankets.
Tony
> > (TVs fridges etc), like you said.  Once the wall was high
> enough they
> Freezer suits will give you a few minutes immunity to IR
> detectors.  Just long enough to put it on, run around with
> some paper and sticky tape and cover all the sensors up.
Mythbusters tried that too.  Didn't work all that well, by the time they
stuffed about getting the suit on it had heated up.  Then there was the
problem with the face plate...
With enough enthusiam it could be made to work.
Maybe you could just freeze a blanket, held in front of you that'd take care
of both IR & ultrasonic sensors.  You can put it top of the razor wire when
scaling the fence, around your arm when smashing the window, and over the
guard dog when it shows up.
Blankets.  Is there anything they can't do?
Tony
Accus?
Tony
2007-09-29 by Andrew
> Tony Smith wrote:
> <SNIP>
> in front of you that'd take care of both IR
> of the razor wire when scaling the fence,
> and over the guard dog when it shows up.
isn't it towels ?
There is a hoopy frood that really knows wher
his blanket is.
Does not quite work.
2007-09-30 by Tony Smith
> > take care of both IR & ultrasonic sensors.  You can put it
> top of the
> > razor wire when scaling the fence, around your arm when
> smashing the
> > window, and over the guard dog when it shows up.
> isn't it towels ?
> There is a hoopy frood that really knows wher his blanket is.
You're absolutely right.
Sucking tea from the corner of a blanket after (or even during) a successful
break-in would be just wrong, a towel it is.
Tony
2007-09-30 by Jennynj1975@aol.com
In a message dated 9/29/2007 1:16:23 P.M. Eastern Daylight Time,
ajsmith@... writes:
>  > Accus?
> I would guess at accumulators - as in lead-acid -  batteries
Gosh, do people still call them  that?
Tony
I have never heard that term before, you are referring to car  batteries?
Jen
> >  > Accus?
> Tony
>  batteries?
> Jen
It's a very old term, certainly older than cars!  I haven't heard it for
years.
It means anything that'll store a charge, such as lead-acid car batteries.
Capacitors used to be called accumulators as well.  I'm not sure when it
died out, but it'd be rare to see it in post-WWII writings.
I was surprised to see someone use it, next we'll be hearing about the
aether (luminous or otherwise).
Tony
2007-10-03 by Stefan Trethan
It's used in german for any rechargeable battery, that's why it hasn't
gone away completely.
ST
On 9/30/07, Tony Smith <ajsmith@...> wrote:
> > >  > Accus?
> > Tony
> >  batteries?
> > Jen
> years.
> Tony
