patent: Ink jet fluid composition and ink jet printing using same
2007-06-11 by GiuseppeG.
You guys might like to see this: http://www.freepatentsonline.com/5849066.html Quite close to the inkjet technique described in this forum. There is also a nice mention at the bottom about the composition of the Epson Glossy Paper. [Non-text portions of this message have been removed]
2007-06-11 by Herbert E. Plett
very very interesting... seems to be possible to just mix the mentioned fluids and works on both Epson and HP (thermal) printers. somebody has access to these chemicals??? http://patft.uspto.gov/netacgi/nph-Parser?Sect1=PTO1&Sect2=HITOFF&d=PALL&p=1&u=%2Fnetahtml%2FPTO%2Fsrchnum.htm&r=1&f=G&l=50&s1=5849066.PN.&OS=PN/5849066&RS=PN/5849066 or just search for number 5849066 at http://patft.uspto.gov --- "GiuseppeG." <ggpp23@...> wrote: > You guys might like to see this: > > http://www.freepatentsonline.com/5849066.html > > Quite close to the inkjet technique described in this > forum. > There is also a nice mention at the bottom about the > composition of the Epson Glossy Paper. > ____________________________________________________________________________________ It's here! Your new message! Get new email alerts with the free Yahoo! Toolbar. http://tools.search.yahoo.com/toolbar/features/mail/
2007-06-11 by Gordon Couger
If I remember right a clean PC board spin coated with a gelling agent and ammonium or potassium bichromate and then painted with methanol or methyl alcohol in an ink jet should make a water insoluble track that can be developed to more resistant coating after the the unhardened stuff is removed. The date of discover was a lab spill in 1958 or 1959. Gordon W5RED GiuseppeG. wrote:
> > You guys might like to see this: > > http://www.freepatentsonline.com/5849066.html > <http://www.freepatentsonline.com/5849066.html> > > Quite close to the inkjet technique described in this forum. > There is also a nice mention at the bottom about the composition of > the Epson Glossy Paper. > > [Non-text portions of this message have been removed] > > > > <http://groups.yahoo.com/group/Homebrew_PCBs/message/18792;_ylc=X3oDMTM2OWNxc3BzBF9TAzk3MzU5NzE0BGdycElkAzQ1MDUzNjEEZ3Jwc3BJZAMxNzA1MDgzMjkxBG1zZ0lkAzE4NzkyBHNlYwNmdHIEc2xrA3Z0cGMEc3RpbWUDMTE4MTUzMzU2MgR0cGNJZAMxODc5Mg--> > <http://groups.yahoo.com/group/Homebrew_PCBs/post;_ylc=X3oDMTJxbXY1NmxpBF9TAzk3MzU5NzE0BGdycElkAzQ1MDUzNjEEZ3Jwc3BJZAMxNzA1MDgzMjkxBG1zZ0lkAzE4NzkyBHNlYwNmdHIEc2xrA3JwbHkEc3RpbWUDMTE4MTUzMzU2Mg--?act=reply&messageNum=18792>
I would try starch and potassium bichromate on the board. Chromate are hexivalent. If you need to make it stick a little geletain. Keep it out of green light and shorter wave lengths. And use the not so nasty stuff in the pinter. Bichromates were used for years as the photo active agent for making circuit broads. Potassium Bichromate in geletan exposed to UV will harden and the rest can be washed off and then etched. You are looking for something to take the place of light. It only needs to catalyze the binding of the hexivalent Chromium to the binder on the broad. Gordon Herbert E. Plett wrote:
> > very very interesting... > seems to be possible to just mix the mentioned fluids and > works on both Epson and HP (thermal) printers. > somebody has access to these chemicals??? > > http://patft.uspto.gov/netacgi/nph-Parser?Sect1=PTO1&Sect2=HITOFF&d=PALL&p=1&u=%2Fnetahtml%2FPTO%2Fsrchnum.htm&r=1&f=G&l=50&s1=5849066.PN.&OS=PN/5849066&RS=PN/5849066 > <http://patft.uspto.gov/netacgi/nph-Parser?Sect1=PTO1&Sect2=HITOFF&d=PALL&p=1&u=%2Fnetahtml%2FPTO%2Fsrchnum.htm&r=1&f=G&l=50&s1=5849066.PN.&OS=PN/5849066&RS=PN/5849066> > > or just search for number 5849066 at http://patft.uspto.gov > <http://patft.uspto.gov> > > --- "GiuseppeG." <ggpp23@... <mailto:ggpp23%40gmail.com>> wrote: > > > You guys might like to see this: > > > > http://www.freepatentsonline.com/5849066.html > <http://www.freepatentsonline.com/5849066.html> > > > > Quite close to the inkjet technique described in this > > forum. > > There is also a nice mention at the bottom about the > > composition of the Epson Glossy Paper. > > > > __________________________________________________________ > It's here! Your new message! > Get new email alerts with the free Yahoo! Toolbar. > http://tools.search.yahoo.com/toolbar/features/mail/ > <http://tools.search.yahoo.com/toolbar/features/mail/> > >
